Building a low-end sub for outdoor use
Hi all you wonderfull DIY'ers
I'm building a new and BIGGER setup for turing Denmarks festivals 😀
The new one is quite large, 1 meter wide and 3 meters long.
I am building 2 DR 280 speakers from Bill Fitzmaurices website and i need 1 or 2 subwoofers to go with them. just to ad a litte UMF 😉
Our old speaker setup used 8 Velleman VDSSP8/8 bas units and a couple of piezo tweeters. Velleman nv
I've been thinking about building a small horn for them. obviouslythere are NO designs for them, because they are ridiculously cheap/low-end 😛
My question is. do you know of any design for a small'ish horn that those drivers might work in.
I've been thinking about building 2 of these, but 60cm wide, so that i can contain 4 units
Speakerplans.com
Will this give anything near a diesent performance,
I don't look for anything under 45hz of usable output, simply because it is a low power rig og outdoor
Would really apriciate some input for you guys 🙂
PS here's a picture of the old setup
I've found more T/S specs for them than is listed on the website.
Impedance (Z) 8
Resonant frequency (fs) 35Hz
Max. frequency range f3-6,000Hz
Music power 350WMAX
Power rating (P) 250WRMS
SPL (1W/1m)Â 91dB
Suspension compl. (Cms) 0.25mm/N
Moving mass (Mms) 65g
Mech. Q factor (Qms) 4.95
Electr. Q factor (Qes) 0.66
Total Q factor (Qts) 0.58
Equivalent volume (Vas) 43 l
DC resistance (Re) 6,4
Force factor (BxL) 12.6
Voice coil induct. (Le) 0.8mH
Linear excursion (XMAX) ±6mm
And i have no idea of how accurate they are!!
http://www.speakerplans.com/index.php?id=hd15horn
You need to model it in Hornresp to see if 4 of those subs will perform with good results in that modified HD15.
http://hornrespdb.com/showparameters.php?id=105]HRDB - Hornresp Database
Horn Parameters
Ang : 1,0 x Pi Eg : 2.83 Rg : 0 Fta : 16.51
S1 : 544.8 S2 : 722.16 L12 : 27.38 F12 : 0
S2 : 722.16 S3 : 1054.92 Con : 15.25 F23 : 0
S3 : 1054.92 S4 : 1785.57 Con : 15.36 F34 : 0
S4 : 1785.57 S5 : 2206.16 Con : 8.97 F45 : 0
Chamber parameters
Vrc : 52 Fr : 40 Vtc : 20000
Lrc : 40 Tal : 4 Atc : 1982.4
When I was new to Hornresp, I also made the mistake of trying to derive new values for parameters like Sd, for example, by multiplying the Sd by the number of drivers. Hornresp works much better if you use the built-in Driver Arrangement wizard. Go to the Input Parameters, fix all of the parameters as they would be for a single driver, then click Tools and Driver Arrangement. Tell it how many drivers you will have in series, then how many of those groups you will have in parallel. You want to do it this way because the electrical parameters, for example, will determine the usable bandwidth and the upper/lower end of your design.
What kind of horn are you trying to design for these?
I think you will be _extremely_ limited in what you can build with 60cm(3). At the very least, I think you will end up with 3 or 4 boxes which are something close to 60x60x60, and perhaps a bit wider. That's probably better anyway, since you will be able to stack them in a row next to each other like 1-2-3-4 for a wider effective horn mouth, and thus, better loading on the low-end. With those dimensions you are pretty much limited to either a scoop (back-loaded horn), or a tapped horn. Of the two, my preference is the tapped horn, because of the better response all the way down to the resonant frequency of the driver. If you're interested, I have another thread in this forum about Tapped Horn Theory and you can (probably) follow along with the tutorial and the questions/answers with pertinent information.
Good luck!
