Hello everyone. As I am sure many of you have done. I also have been reading tons and tons of posts on building a DIY DAC. However, I have been frustrated with the shear number and differing opinions among the DIY audio community.
This thread is my own selfish attempt to help "weed" through the growing forest of DAC threads. To hopefully, "see the forest from the trees". I.e. the big picture. What really matters most. Most "bang for your buck" so to speak.
It is my hope that I will come up with a list of clear and somewhat agreed upon techniques for making a successful (both sonically and measured) DIY DAC design.
I do not want to make a thread which is 1000 posts long. I simply want to compile a list of "Design guidelines" for achieving an excellent quality DAC for a modest price. $200-$300 without enclosure.
Originally this started as a personal email to ThorstenL, as I have read many of his posts and I respect his opinions and experience. He recommended that I start a thread; and so, HERE IT IS. Let's hope this thing doesn't explode out of control.
I think it will cover such topics as follows:
1) DAC chip selection: is there a single chip which gives the best chance of great sonics? regardless of implementation?
2) Power supplies: are shunt regulators needed for great sound?, are they worth the extra complexity?
3) Is an ASRC good or bad? are you better off without it? In what conditions is it good? When is it bad?
4) Decoupling caps: do we really need to use film to get great sound? Whats wrong with ceramic?
5) How important is implementation (artwork) compared to parts selection?
6) etc. etc.
To kick it off, here is my original email to ThorstenL (his reply in italic) and his answers to some of the questions, hopefully this will help some others on the forum as I am hoping it will help me. In the end, I hope to have some concrete design descisions made and I will offer up my results to the DIY community.
So all you experts, lets get it on! Keep in mind, I want this to be short and concise. A simple design guideline for a great DAC. Not a long debate.
Design Goals:
1) natural and transparent sound, but not overly transparent (I like a bit
> of softness/warmth). My current amplifier is a Passlabs Aleph 2 clone, which
> I absolutely love although my experience with other high-end gear is very
> limited. I just like it to be very musical and non-fatiguing.
> 2) something a "cut above" the mainstream products that I can afford (which
> is not much).
> 3) SPDIF input with balanced and single ended analog outputs.
> 4) transport insensitive (in other words, my CD player is not great). It
> needs to sound good regardless of the transport.
> 5) All components easily obtainable (mouser, digikey, etc.)
Have you looked at Nelson's whole DAC? It delivers all that and well.
Might even be possible to get one 2nd hand at sensible money and
restore/tune it.
> Here's what I was planning:
> 1) WM8804 SPDIF receiver
If you want to use 176.4KHz you need to control it via MCU. In that
case 8805 allows multiple inputs, might as well use that. Correctly
implemented it is currently the best "low jitter" receiver.
> 2) SRC4192 ASRC chip (to "clean-up" jitter)
I'd just leave it out. Not worth bothering.
> 3) PCM1794 with Pass Labs D1 I/V stage (IRF610 as common gate stage)
I'd use BJT's (or diamond transistors like OPA861) for the I/V in
common base instead, but I doubt I'd use PCM1794.
Differential PCM1704 is worth doing if you want to be able to play
higher resolution/sample rate recordings.
> 4) Pass labs Aleph P preamp stage and resistor ladder attenuator for volume
> conrtol
Why not combine I/V and Volume control? You could use the I/V resistor
for coarse attenuation and fine attenuation after that.
> 5) regular three terminal regulators for each supply rail
Nothing is better than it's powersupply. The common 3-Pin regulators
as sole PSU are not very good.
> Is the ASRC chip really that bad of a sonic degradation?
In my experience? In most cases yes. In some cases (CD's) it does
improve the sound. On anything better than CD it is really bad.
> Is the PCM1704 worth the money? (I originally wanted to use this, but the
> cost was a bit scary without knowing if I would like the result).
IMHO, yes.
> Can you give me an example circuit for how to implement a secondary PLL
> instead of the ASRC for jitter removal? Do you just need to keep the PLL
> loop bandwidth low? If so, how low?
Nelson's DAC had a secondary PLL, with the 8804/05 you can probably do without.
> How big of a difference does a shunt regulator make on the sound? i.e. are
> they worth the extra circuit complexity. Where are they most important?
Powersupplies are a huge topic. There is no single "silver bullet"
regulator. Important is to select the circuit in the powersupply so it
is optimal for a given application, including decoupling and bypass
capacitors, ferrite beads/inductors where useful etc. et al.
> Can I decouple the DAC supplies as recommended (cermaic caps), or do I need
> to use Film caps as many poeple say on the forum. I am very skeptical that
> the decoupling cap on the supply of the DAC can be audible.
They are quite audible, I'd not worry too much about the ceramic caps,
keep the for very high frequency noise. Use suitable "good sounding"
caps on the analogue supplies of a DAC and any reference pins. I like
Elna Silmic best. And yes, this stuff is quite audible.
> Are AC coupling capacitors as bad as some people say? I would guess not,
> since most tube gear and Pass Labs stuff has them.
They are as bad as "they" say. What "they" often omit is to note that
"coupling" capacitors are not always in series with the signal. They
may sit in power supplies, in servo circuits and so on. This is one
area where well implemented shunt regulators can help, they can
replace the "coupling" capacitors between ground and supply. Equally,
sometimes a simple high quality coupling capacitor is less damaging
sonically than all the stuff that is needed to avoid it, sometimes
it's not.
> So basically, I am asking if you have a simple recipe for success for a DIY
> DAC.
If you can live with 16/44 get something using TDA1541A, no
oversampling or filtering, 8804/8805 receiver, I2S attenuators and DEM
reclocking as per ECdesigns Schematics. I'd use a Tube stage with that
(I designed one that can be used), but I would also consider using a
pair of OPA861 per channel as common base diamond transistor I/V and
Buffer. You can also use the OPA861 as powersupply regulator to give
the TDA1541 (or other chips) +/-5V, using it for the -15V needs a
little more effort.
If 16/44 is not enough, things get more interesting. Keep the
receiver, use a suitable logic to split the signal for 2 (or 4 pcs
balanced) of PCM1704, suitable analogue stage (tubes or other non nfb)
and supplies.
Sorry for the long post, they will be shorter from now on.
6) etc. etc.
Design Goals:
> is not much).
restore/tune it.
> conrtol
IMHO, yes.
it's not.
> DAC.
little more effort.
and supplies.
Here are my replies to ThorstenL,
Yes, I have the D1 schematic. It is too hard to get the PCM63 chip. I was planning to use the I/V stage though.
96kHz is all I will ever need.
No problem leaving it out. Note: I do have a CMAC OCXO with state of the art low jitter (<1ps RMS over the audio bad). Would this give any sonic benefit if I used it as a master clock for the ASRC? or just over-kill?
I also would like to use this as a preamp. I need to have RCA inputs to the preamp stage. So I need both the I/V and a preamp stage. I will have relays to select the input as RCA external or DAC direct.
I listen to all CD. Would the ASRC be an improvement in this case?
Please explain (technically and sonically) why are BJT's better? Pass Labs D1 uses IRF610 and has great reviews. With just regular CD, is the PCM1704 still worth the cost?
Are you saying that the shunt regulators should not have capacitors at the output? You depend on the regulator to be low impedance at high frequency?
My sources are all 16/44, but I think TDA1541 is too hard to get. I do like the PCM1704, cost is a big factor I need to consider.
restore/tune it.
This is one
little more effort.
and supplies.
You can keep the rest and use the PCM1704 instead of PCM63. Wilte not pin compatible (plus the 1704 has less output current) both DAC's share more than they have apart.
640K is all the memory anyone will ever need... ;-)
I find I now need 176.4 & 192 KHz.
It will certainly not do any harm compared to lesser oscillators.
You could threat the Inputs as current inputs (with voltage to current converting resistors), just for arguments sake... 😉
I find the ASRC a disimprovement in 95%+ of all CD's. If it is a choice of having it or not, permanently in the signal path, I'd leave it out. If I cannot have a remote to turn the ASRC on/off I would leave it out.
Technically BJT's often have lower emitter impedance and a more linear emitter impedance than Fets source impedance. BJT's are very to compensate for temperature changes. I prefer BJT's in "common base/source" applications, Fets in "common emitter/source" and usually Fet/BJT Sziklai pairs for "common collector/drain" applications, all else being equal.
Most shunts will need some capacitance to remain stable. Often this capacitance can be fairly low value. In 3-Pin regulators I like to have VERY LARGE value capacitor with fairly high ESR after regulator, with most shunts modest value film caps are possible, or very high quality Electrolytics that do not come in very large values.
The TDA1541A is now starting to become difficult to get. My first TDA1541 DAC was made with a chip pulled from a very dead and ultr-cheap Philips all plastic Chassis CD-Player.
On CD (and only CD) I find the TDA1541 still delivers a realistic and analogue sound that is not matched by any more recent design.
Ciao T
Ciao T
Hi there
I´ll try to see if I can provide something usefull.
I don´t think so.1) DAC chip selection: is there a single chip which gives the best chance of great sonics? regardless of implementation?
In most designs the DAC chip is by far the best component, so I´d pay attention to its surroundings and the load of it.
I think you can achieve outstanding results from both AD, CS, TI, AKM, Wolfson, Sony or whatever you choose.
I´d choose shunts for the analog circuitry, you´ll hardly believe how difficult it is to design a PSU allowing your amplifier to become transparent, unless you choose the shunts.2) Power supplies: are shunt regulators needed for great sound?, are they worth the extra complexity?
I think the problems is mostly caused by the capacitors, which are lousy everyone of them. The best results with serial regs though I achived using no electrolytics, but film caps only after the reg itself.
This is a pretty good question, in my experience the ASRC brings in natural proportions in the sonic result, giving you much more natural ambience and 3D in especially AB stereo recordings - it is actually dazzling.3) Is an ASRC good or bad? are you better off without it? In what conditions is it good? When is it bad?
It also takes away what a lot of people call digital sound, because it in some strange way eliminates artificial emphasis on transient start ups
Ceramics sound terrible, that is the only reason.4) Decoupling caps: do we really need to use film to get great sound? Whats wrong with ceramic?
Use ceramics where absolutely needed and nowhere else.
Any analog need for decoupling, that be the reciever, or the DAC itself as well as your analog stage, is to be done with the very best film caps, which are without any doubt PPS caps.
A lot, you can really make good parts sound lousy by implementing them poorly.5) How important is implementation (artwork) compared to parts selection?
One good advice I can give is to keep in mind, that resonances are the main cause of listening fatique and distorted sound, so think of low Q supplies and amps all the time6) etc. etc.
The most funny thing is, that the more transparent you design your gear, the more musicality you will achieve. It is a myth that electronics are to hide or ad anything to become musical.Design Goals:
Precission in sound reproduction will reveal the character of the instruments in a both smooth and natural way, because real instruments are actually very smooth and beautyfull to listen to
Generally electronics are not that expensive> 2) something a "cut above" the mainstream products that I can afford (which
> is not much).
OK - the balanced interface is hardly used anywhere> 3) SPDIF input with balanced and single ended analog outputs.
Which is impossible> 4) transport insensitive (in other words, my CD player is not great). It
Good idea5) All components easily obtainable (mouser, digikey, etc.)
Seems OK> Here's what I was planning:
Also OK> 2) SRC4192 ASRC chip (to "clean-up" jitter)
It is a very good chip, but in puts out quite a lot of current> 3) PCM1794 with Pass Labs D1 I/V stage (IRF610 as common gate stage)
You ought to do a preamp instead> 4) Pass labs Aleph P preamp stage and resistor ladder attenuator for volume
> conrtol
They are not very nice> 5) regular three terminal regulators for each supply rail
No> Is the ASRC chip really that bad of a sonic degradation?
I like the PCM 1702/1704 a lot> Is the PCM1704 worth the money? (I originally wanted to use this, but the
They are indeed> How big of a difference does a shunt regulator make on the sound? i.e. are
All the caps are audible, but I would use ceramics on the digital supplies and film on the analog supllies> Can I decouple the DAC supplies as recommended (cermaic caps), or do I need
With tube gear you will hardly know the difference, but coupling caps in good SS gear are best avoided.> Are AC coupling capacitors as bad as some people say? I would guess not,
But it is not easy to design a DC servo circuit, that is completely transparent. But one of the rules of thumb is a very low cut of frequency, and use 1. order only.
But if you choose 1 point servo´s you might have a chance of implementing 2. order servo´s without the usual problems.
[/QUOTE]
Excellent advice. thanks guys! Let me digest this some and I'll post my response and any more questions I may have later.
I think a simple list of basic guidelines is not too far away.
Ok just to summarize what I have so far:
1) PCM1704 is a great sounding DAC. Worth the cost over the newer and cheaper DACs from BB, ADI, CS, Wolfson, AKM, etc.. However, it may be possible to achieve great sound with almost any of the new high end chips. If you only want 16/44 the TDA1541A is as good as they come, but is pretty hard to get.
2) Shunt regulators are well worth the extra effort due to the most times bad sonic signature of almost all large value electrolytic decoupling caps. The shunt regulator circuit should have low output impedance over a wide bandwidth and only incorporate small value high quality (film) capacitors at the output. These should be used for the analog sections and the DAC reference if available.
3) ASRC is usually a bad thing, but may in some cases yield some benefit. Certainly if the incoming jitter is very high the ASRC could be useful to clean it up. However, a 2nd PLL could also do the same thing without adding it's own signature to the signal. Putting it in the design is fine, but a BYPASS option should be included.
4) The WM8804/5 is a cut above the rest in terms of jitter rejection at the SPDIF interface. In fact, a secondary PLL may not even be necessary when using this reciever due to its very low jitter clock recovery architecture.
Let me know if I got this right?
a few more questions:
1) good point about >96kHz sampling rate. Can you give me an example or two of where one might need to have the higher rate capability? I am not very familiar with all of the audio formats out there. As far as I know my CD player will not send anything higher than 16/44 unless I turn the upsampling on, which is a bad idea.
2) I understand that BJT's are better suited electrically for the common base I/V stage, but does this translate to better sound? Does the particular BJT used matter much? or does it just need to have enough bandwidth and power handling?
3) What about DF1704? Do I use this with PCM1704? or NOS
The OPA861 is very interesting. I have not seen this part before.
How does it compare sonically to a discrete BJT in common base I/V?
I will have to read up on the DEM reclocking and attenuated I2S. I am not familiar with these. Can you give me the basic idea behind them?
Sadly those bashing ASRC-s never give solid evidence, and the 'net is full with the contrary . Upsampling as popular term appeared with the dCS 972 , so I suggest reading those reviews. It was about the time when pcm1704 was new. Also the dCS thing is somewhat unique piece of gear because not only it does resampling , but user can set many types of noise shaping , and highest order (7? -9? ) was found to sound best, especially with PCM/multibit converters. I think the ESS has only 4th order , so this might be not the best . : ))
Also I think Im goin to sell some 4-5 pc's of pcm1704K in a few weeks, old-old datecodes, pulled, no ROHS.
Low cost and good sound ?
Just use one piece CS8414 in slave mode, and a ES9022 with a 50MHz Crystek clock.
Simple 5V & 3.3V supply (LT1761s). No IV circuits etc to worry about.
Less than $50 without power supply (battery).
See
http://www.diyaudio.com/forums/digital-line-level/151846-anybody-using-new-ess-vout-dac-es9022.html
and PM John. He'll tell you stories. 😉
Patrick
See
Patrick
Actually, the CD-Players that I have designed include DSP Functionality that allows both integer and non-integer ratio upsampling (the integer ratio one is normally called oversampling) that can be switched off. I am unaware of any users that have preferred to use the Digital trickery over not using it (in the case of the CD-Players there is no source jitter issue involved, of course).
Further, while also anecdotal, the new PS Audio DAC includes a Wolfson Micro DAC with various advanced filters and upsampling hardware. Uses there also report "no upsampling is better", as they did with Shanlings CD-T100 CD-player which used the PDM200 HDCD Filter and PCM-1704 with a CS8420 "upsampler" that could be bypassed.
As for the dCS gear, I had the chance to repeatedly play with that stuff and we used in a number of "shootouts" with digital gear as "reference". At least in the case of Elgar & Purcell I always preferred the Elgar only, no upsampling. Using the Upsampler made the sound by far less real and natural, though it improved in some of the usual audiophile categories, to which I pay scan't attention.
I agree that a formal study seems warranted as such anecdotal evidence is of little absolute scientific value, but so far no-one has any interest to commission one (and pay for it).
As practically non of the "upsampling" DAC's and CD-Players allow the upsampler to be bypassed few customers (and DIY'ers) ever have the chance to make a formal and fair comparison.
Plus I agree that the way jitter is 'transcoded" by ASRC's results in less audibility, so if no effort is made to solve the jitter issues using traditional, solid means using an ASRC gives a shortcut to possibly acceptable measured (and subjective) performance.
Those who wish to make their minds up, seek out a retailer for CD-Players that allow ASRC to be bypassed or selected and have a listen.
Ciao T
Ciao T
I have not done that comparison using OPA861, Pedja Rogic has tested this extensively and he feels that the OPA861 performs very well. I suspect it can do as well as a discrete circuit, if not better.
These apply specifically and ONLY to the TDA1541 (and TDA1543 for I2S Attenuator). Details are covered in ECDesigns thread, with references.
If you will not use the TDA1541 you need not concern yourself with them. If you intend to use the TDA1541 reading the whole monster thread is very well worth it.
Ciao T
The OPA861 is very interesting. I have not seen this part before. How does it compare sonically to a discrete BJT in common base I/V?
Ciao T
DVD Audio goes up to 192 KHz and downloads of higher sample rate/wordlength signals are becomming more easily available and common almost every day. Three years ago I would have been dismissive about > 16/44 Material being worth bothering, nowadays I am no longer.
Different BJT's sound different. I like to use the 2N4401/4403 range, they have very low noise, low emitter impedance etc. There are slightly better Japanese types but harder to get.
Why not make it switchable and make up your own mind?
Ciao T
Ciao T
I still don know what is it , that gets "butchered" , "corrupted" , "worse". Actually I think a good ASRC (like the TI ) is better with than without , because if you know how CD-s are made, you must know that the dither they apply is nothing low order, and if you re-amplify that properly dithered -60dB ,1khz sinewave, there are jaggies like , uhh. At least a proper polynomial curve fitting going to act and smooth those. : ))
Also downconversion during mixing a track involves 96 or 88.2 - to 44.1khz downsampling, guess how that impulse response look$ !
The music. Takes around five seconds switching back-forth with good acoustical music minimally recorded. Try it.
If it was possible to put this into technical terms we'd be much better off, but TI and people like you keep pointing at the measurements and keep telling us how good it is while others tell you "it does not sound good" and you and TI and many others complain "but what does that mean - which technical parameter is wrong?".
Sure, but I have little interest to listen to sinewaves. I listen to music. I suspect this is a repeat of the 0.00001% THD Amplifier disaster, where 1KHz simewaves measured perfect, but complex signals slewed the system heavily, leading to distortion that sounded really bad.
I remember one article where the designer of the TIM challenged amplifier proceeded to note that the amplifier "revealed" distortion in the source that lesser amplifiers did not reveal, taking the TIM produced by his amplifier as indication of it's degree of goodness. I told him his amp sounded like hammered sh...t and he kept pointing at the zeros after the decimal point in measured THD.
With hindsight I suspect the gentleman is quite ashamed of himself, but until someone (Ottala) proved the point scientifically many listeners complaind the amplifiers sounded bad but where dismissed.
Much will depend EXACTLY how the process is done. But I agree, many CD's are poorly mastered and that is before we are looking at jitter and ASRC. And yes, the poorer the mastering, the higher the compression and so on, the more of a chance is there that switching in the ASRC will improve the sound quality. The better the CD is mastered and produced the more likely that using an ASRC will disimprove the subjective sound quality.
Ciao T
Ciao T
Lets just argue about cd playback, because with high resolution material its obvious you wont need any dither or all kinds of filters. One with a PC can try all kinds of filters and dither anyway.
Upsampling is a term of filling in new samples in a _meaningful_ way, instead it became a mythology, folklore and religion contest. I for one goin to play with the denon al24 in few days. 😀
Until then, my entry for the contest:
I dont really care about thd spec either (unless it comes to NOS and -60 dB ) but those slow roll off filters are ridicoulus and utterly meaningless at 44.1khz 'cause once the additional samples are obtained by zero stuffing (I dont think I ever saw a datasheet about a DF with sinx/x compensation) , thats goin to look utterly ugly in time domain . Same song with NOS (consequences). I do care about how these waveforms look and I think I can decide that I dont want such things happen to "the music".
Ok, so it appears that (not surprisingly) there are differing opinions on SRC and ASRC. No problem. I think this just means that for a person designing a DAC; it is a good idea to keep the ASRC in the chain with a BYPASS option. This way one can decide for one's self if he/she prefers the sample rate conversion. I can live with that. Adds some complexity, but not terrible.
I think ThorstenL has said the same thing, but perhaps in his experience he prefered no ASRC 95% of the time.
Another thing to note here. The mentioned dCS972 is a very high-end piece of equipment, so it may still be that the "run of the mill" TI or ADI ASRC chips do not do a very good job.
Here is the most recent list of guidelines:
3) ASRC is usually a bad thing, but may in some cases yield some benefit. Certainly if the incoming jitter is very high the ASRC could be useful to clean it up. However, a 2nd PLL could also do the same thing without adding it's own signature to the signal. Putting it in the design would be nice to be able to try for one's self, but a BYPASS option should be included.
I am a bit unhappy with item#1, is it universally accepted that the PCM1704 is a great sounding chip? Meaning most people have preferred it. Or is this not true. I don't have much data here. Perhaps it is a result of its "different" internal architecture. or this could be a psychological effect on it's users.
make this simple:tritosine, what do you think of the rest of my list?
does it look reasonable?
-if you include ASRC use PCM1794, if not , PCM1704 (K) .
BTW there are lot better DSP chips nowdays than in 1995-7 , maybe SRC chips inherited some of this,for example the src4192 is 28 bit through-out, therefore I would think its better than a pmd100 or that nippon sm5842 for DF role, and for an ASRC , according to their patent its good enough, and jitter attenuation is measured to start at 1hz or below, whereas the wolfson receiver starts at 100hz . One of those TI chips has the receiver built in I'd just use that. There s some wordclock TX stuff there as well, maybe you can sync the source _to_ it , or to the dummy spdif TX.
- Digital Line Level
- Yet Another - I want To Make a DAC
