lights on a Hifonics gen X..
got a hifonics samson gen x and although in full working order the strip of lights don't work! i took the strip out and there's about 6 small led's in there on 2 different circuits. does anyone have a schematic for gen X amps or know if this is a common fault and how to cure it? all the led's have blown on one circuit so i'm guessing there's issues on the main board somewhere 🙄
thanks Mark.
there's a plastic strip that runs the lengh of the amp at the bottom and behind this there's a long thin board that holds the led's/lights on..
You'll have to follow the traces back to the main board. From there you'll have to follow the traces back to whatever is driving them. In most cases, a transistor is used to drive them.
They may have blown because they were being driven too hard. Many times, the LEDs simply can't handle the current being driven through them.
The LEDs are likely being driven by 12v (most common way to drive them). You can calculate the current draw through the string of the new LEDs by multiplying the forward voltage drop of each LED by the number of LEDs in series. Then subtract that from the supply voltage. Divide the remaining voltage by the resistor value and that will tell you how much current will flow through the string. This won't do much good for the ones in the amp but you can use it to ensure that the new ones don't burn out.
