Stumbled across this one searching for info on J2 ...
VERY interesting simplified schematic 😎
http://www.electori.co.jp/FirstWatt/M2.pdf
tnx 😉
baaad Papa , baad !
depletion mosfets , 2x18Vac xformer , 4x150R repeater coil ...... nice way to Musical Heaven ;
Mu F. as option , 2x150:2x300 (600:1200) repeater coils ..... even greater bliss
as I said several times before - in time of F4 , Papa is givin' us history lesson - just imagine big toobz as 845s on output , and you have what was known as Booster amp
baaad Papa , baad !
Joined 2009
I'm gobsmacked - I have a similar design on my drawing board - only with BJT outputs. Maybe not the same, I'm looking for the trafo to be my voltage amplifier - or maybe it is the same ? I have two Broadcast quality transformers waiting on hand... now I know I'm on the right track 😀
This is a transformer voltage amp. Interesting discussion about are in this thread also:
http://www.diyaudio.com/forums/tubes-valves/150788-transformer-voltage-gain-element-9.html
Francesco
Francesco
What is First Watt? What is First Watt?
FirstWatt は Nelson Pass "kitchen-table By Nelson Pass FirstWatt the "kitchen-table", is a brand of handmade production. FirstWatt FirstWatt effective efficiency, high-quality speakers
And we aim to develop low-power audio amplifiers and high quality for very simple.
JFET/Auto-former & Mos-FET JFET / Auto-former & Mos-FET\
M2 J2 FirstWatt 25W+25W (8 Ω ) J2 FirstWatt M2 is followed by a second work, a unique 25W +25 W (8 Ω) class A is Shinguruendosutereopawaanpu.
Single-Ended Triode/SET、。 Single-Ended Triode / SET, the output triode single amplifier was designed under the theme beyond the limits of harmonic distortion. Nonfidobatsu
Sounds like a vacuum tube design in the clock, I'm happy to provide a fresh feel to the audio files are certain limitations to these
M2 。 M2's efforts to develop.
M2 NFB JFET M2 configuration of non-NFB, Class A JFET input buffer operating mode, and features passive voltage amplifier (drive power stage) for the O
Mos-FET 。 Totoransufoma, one of a pair of triode valve has become a Mos-FET output circuit. Here are fresh and unique amplifier design.
。 It is very reliable, simple and stable.
100k Ω 20 4dB、 200 μ V、150W . Input impedance is 100k Ω, damping factor of 20, gain is 14dB, the noise 200 μ V, Pawadoro is about 150W.
。 Here is no plateau 10A です。 The maximum output current is 10A. 。 For the output stage bias circuit has been newly designed. この新 New
Shii circuit temperature, voltage, bias current constant value of locked for hours. するAnd異Na in order to protect the amplifier output overcurrent
Ru only. It does not require adjustments.
(RCA)1 1 Unbalanced input (RCA) 1 in the system, speaker output system 1 is a binding post. LED Left and right front panel blue LED
ch, ch, has a power indicator. Power switch is located on the rear panel.
M2
M2 circuit design is simple and very reliable and requires no adjustments. し It is warm and relaxed, Soshi
Energetic, and combines the precision and detail. Single-Ended Triode/SET、 Excellent speaker system when connected to a high effective efficiency, Single-Ended Triode / SET,
Will be surprised to fine and velvety sound like you are ringing in the triode single amplifier, and bass resolution and better
。 Be relaxed, I become to hear the progress of spatial sound reproduction.
60 。 Wonderfully well in the vacuum tube preamplifier, as fresh and lively in the 60's golden era has been generous, evolving from Rimasu. I
M2。 M2 is to be hoped that the deployment would again like to listen again to have your record collection by. It is many years Kaka
Might Ru, M2 in Please enjoy. Nelson Pass 。 Nelson Pass it now will be delivered from the kitchen.
What is First Watt ? What is First Watt?
First Watt is a "kitchen-table" effort by Nelson Pass First Watt is a "kitchen-table" effort by Nelson Pass
very simple / high quality / low power for sensitive loudspeakers very simple / high quality / low power for sensitive loudspeakers
FirstWatt M2 FirstWatt M2
25W+25W JFET/Auto-former & Mos-FET Stereo Power Amplifier 25W +25 W JFET / Auto-former & Mos-FET Stereo Power AmplifierPage 2 Page 2
Product Specifications
■ Gain: 14 dB
500mV/1W 、3V/ ■ Input Sensitivity: 500mV/1W output, 3V / rated output
+0,-0.5 dB at 20 Hz 〜 25 kHz ■ Frequency Response: +0, -0.5 dB at 20 Hz ~ 25 kHz
25W /1%THD 1kHz 8 Ω ■ Output power: 25W / 1% THD 1kHz 8 Ω
■0.025% THD, 1W 1 kHz, 8 Ω ■ Distortion: 0.025% THD, 1W output at 1 kHz, 8 Ω
■:100k Ω ■ Input impedance: 100k Ω
■ 20 ■ Damping Factor: 20
■500 uV 20-20 kHz ■ Output Noise: 500 uV Anueito 20-20 kHz
■ Balanced CMRR:-60 dB @ 1 kHz ■ Balanced CMRR: -60 dB @ 1 kHz
■160 watts ■ Power Consumption: 160 watts
■ 430 W x 385 D x 143 H mm ■ Dimensions: 430 W x 385 D x 143 H mm
■ 11.62kg ■ Weight: 11.62kg
■ 300,000 ■ Price: 300,000 yen (excluding tax
M2
■ Gain: 14 dB
funny ZM - now I realize that "Mu F." can be read as Mu follower
what I meant is "my favorite " - repeater coil 600:1200 , toroid nickel core
Seems nice, but that much Pawadoro is just too much for me. Less Pawadoro, please ! 😀...
100k Ω 20 4dB、 200 μ V、150W . Input impedance is 100k Ω, damping factor of 20, gain is 14dB, the noise 200 μ V, Pawadoro is about 150W....
More on the M2 below...I'm not sure but I think I've been recruited as NP official photographer for 6moons...😀. My pleasure Mr. Ebaen!
6moons audio reviews: FirstWatt M2
tnx Blues ......... even if all I can read in article ( at least partially new) is another confirmation that Asians are again smarter than Westerners
that's so natural - they share my love for Iron ( not in Curtain , but xformers
The fact is the Iron Curtain was melted and made into distortion free transformer cores...and some made it to NP's warehouse.
Allen,
for the curious : does your head look half the size of Papa's, or is NP's head twice as big as yours ?
http://www.diyaudio.com/forums/atta...d1274489367t-np-seattle-may-20-papas-arms.jpg
I think there's a little bit of harmonic distortion on that picture...I wasn't holding the camera you know?
Too bad I cut my hair because summertime is approaching...you guys would have seen excellent stereo balance and imaging...
- First Watt M2
