Opening an Ipod to get the I2S signal for a digital output
Hello
I want to use a mp3 player to play wav or lossless files with a digital output to feed a TDA1541A non-os Dac.
The Iriver H100, H120, H140, did have a SPDIF digital output but those models are hard to find.
So, I would find an old Ipod like the G1, G2, G3 or G4, or the Mini 1, and open it to bypass the Wolfson Dac to have the I2S signal for a digital output to feed a TDA1541A non-os Dac.
The first and second generation iPods used the- WM8721; the third generation ysed the- WM8731L. The fourth generation - WM8975 CODEC; and the fifth generation - WM8758 Audio codec.
But looking at those Wolfson Dac data sheets, I am not sure which pin of the Wolfson Dac I need to bypass to get the I2S signal ??
Any hints ?
Thank
Bye
Gaetan
Most iPods use a PP5020 or PP5022 SoC by PortalPlayer (now defunct, adsorbed by nVidia). As far as I can tell they use I2S between the cotroller and the DAC, so should be OK to connect to a DIY TDA1541A DAC.
I think I2S should be taped like below:
WS: (DACLRC) WM8721(4) WM8731*(9) WM8975(7)
BCLK: (BCLK) WM8721(2) WM8731*(7) WM8975(5)
DATA: (DACDAT) WM8721(3) WM8731*(8) WM8975(6)
* 28 QFN package, which I think most iPods use.
Looks like a good project, good luck.
Anton
Rather than an iPod, I'd recommend field-recorders like the Roland R-01, R-09, Sony PCM-D50, or (at higher cost), Sound Devices' 744T.
Both the R-01 and 744T are equipped with CF slots (the R-09 uses SD while the Sony uses MemoryCards) and the 744T also is designed for a 2.5-inch IDE HD (which can be swapped for an SSD), so you can avoid rotating media.
I have modified iPods for CF/SSD operation and they work fine, but these will require more work than the Rolands, Sony and Sound Devices to achieve solid-state operation, and extracting SPDIF or I2S output will be considerably more difficult than on the Rolands and Sound Devices.
The Rolands have Toslink, and the 744T has coax SPDIF. Getting I2S out therefore should not be that difficult, although a service manual or schematic would be useful.
Sound quality is outstanding.
hth, jonathan carr
I would still go for an iPod. They are much easier to find, and just because the Rolands etc. use S/P DIF doesn't mean you can access I2S directly in them (although you might be able to, I am not familiar with these devices), and a S/P DIF recovery circuit would add alot of complexity while being detrimental to performance.
I doubt iPods have low jitter clocks, just a standard grade crystal attached to an oscillator circuit onboard either the SoC or DAC. You may be able to install a low jitter clock, depending on what sort of clock layout the iPod uses.
I'd love to know what sample rates and bit depths the SoC is outputting. Unfortunately I can't find the datasheets for any of the iPod SoCs (PP5002, PP5020, PP5022), and the DACs used accept such a variety, so they don't help in narrowing it down.
Hello
Jcarr
Those field-recorders like the Roland, Sony and Sound Devices cost too much money for me.
I would not buy a new Ipod but a used or refurbished one, or a refurbisher Sansa (easyer to find at low cost but it use another dac chip).
Amc184
Here is the only portal player chips data sheet that I found (PP5002, PP5020, PP5022) , they are short version data sheets;
http://web.tagus.ist.utl.pt/~rui.neves/se2005/basedoIpod_5002_brief_0108_Public.pdf
http://web.archive.org/web/20061202...products/documents/5020_Brief_0108_Public.pdf
http://web.archive.org/web/20060908...r.com/products/documents/5022_Brief_Mar05.pdf
Thank
Bye
Gaetan
Yeah, I've already seen the product briefings, but they don't even come close to having the info of a datasheet. Looks like the datasheets were distributed with an NDA, probably only to a few OEMs. I doubt they'll ever see the light of day.
Hello
Btw, the player I will use will be stationnary and will be in a metal box on the top of my amp in my home.
Sansa player do not play wav, so no more Sansa. And Ipod do not play flac files.
But there is a very interesting player, the Rio Karma, it use a laptop hdd and it use the PP5003 and the WM8721.
And it play wav and flac files.
So I just need to find a used or refurbished Rio Karma.
About the dac;
(quote)
Rio Karma DAC
The DAC is fed with standard I2S signal. The pins are:
Pin 2 - I2S bit clock
Pin 3 - I2S data
Pin 4 - I2S left/right clock
However, there is no external 256fs master clock signal, which may be required to drive an external DAC setup. The Wolfson DAC is special in that it will accept a 272fs or 544fs master clock, which is great if you have a 12/24MHz clock kicking about (e.g., a USB clock) but not very standard for audio components. Also, the lines are not buffered and are at 3.3v levels - you may run into signal integrity problems over a cable run and the lines are not particularly protected against static discharges as they were never supposed to run outside the case.
(end quote)
But the PP5003 do seem to have a SPDIF output but I only have the short version of data sheet, so I do not know from which pins it goes out.
Here is somes web sites links about the Rio Karma;
The Portal Player chip product briefings file;
http://web.archive.org/web/20070218...products/documents/5003_brief_0108_Public.pdf
The Wolfson WM8721 dac;
http://www.wolfsonmicro.com/uploads/documents/en/WM8721.pdf
Others Rio Karma web sites;
http://www.rockbox.org/twiki/bin/view/Main/RioKarmaPort
http://www.dapreview.net/p/content/content.php?content.193
http://www.schenkzoola.com/karmaopen.htm
http://www.karmalimbo.com/
http://www.karmalimbo.com/dnna_karma_description.pdf
Thank
Bye
Gaetan
I know this thread has been dormant for a while but I have got my hands on a 5.5G ipod which uses the WM8758 DAC (same pinouts as WM8978, I believe).
Looking at this datasheet I identify the following pins (these are different WM8978 pins than on the first page):
Pin 7 = LRC - Left/Right alignment clock
Pin 8 = BCLK - Bit Clock
Pin 10 = DACDAT - DAC data input
pin 11 = MCLK - Master Clock Input
I'll be using this to feed I2S to a ESS DAC which doesn't need the MCLK signal so "in theory" the ipod clock jitter & the PLL sysnthesis of the audio clocks from it (more jitter?) is not of huge importance due to the ESS jitter reduction technology (I know this is not strictly true but anyway - worth a listen).
Has anybody identified the LOD pins that are unused & I could route the I2S signals to 3 spare pins?
19, 20 (+12vdc firewire power)
22 (firewire data TPA -)
24 (firewire data TPA +)
26 (firewire data TPB -)
28 (firewire data TPB +)
these are all related to firewire data and power and since firewire was discontinued before the ipod video these should be fine. there are others reserved, which actually are probably relating to the encoded i2s stream anyway. I will be very interested in your results as I am in planning stages for a portable ESS dac/amp which I will be feeding with a cowon X5L or iriver H120, but I have a 240gb ipod video I would love to tap for this. many before you have tried and failed though mate, it seems the integrity of the signal is not great, perhaps this lack of a need for the MCLOCK by the ESS dac will get around this though. i'm using asrc if needed but would rather avoid it.
there are also multiple pins tied to ground in the ipod so some of these could be commandeered if you lift the legs on the dock connection to the PCB
Thanks, qusp
This is the trick I was hoping would help BUT I came across this post on Audiogon by Steve (audioengr) here AudiogoN Forums: Is iPod Digital Output Possible?
He says:
Johnmhuntbch - I took an iPod Video apart and mapped-out the signals. The problem in this particular unit is that the signals necessary for I2S are not present. The D/A chip is run from a 12MHz clock. It is a proprietary chip from Wolfsen, cannot find a datasheet. It also uses a half-speed bit-clock. With some effort and logic, I could generate S/PDIF from this externally, but it would be jittery.
The whole point of this was to get a low-jitter I2S out of the thing. Looks like maybe a different iPod is needed. The new ones evidently use the WM8741. This I have the data sheet for. This probably has I2S going in. Not sure which iPod to buy though. This is getting expensive. I managed to put the video iPod back together and I'm giving it to my wife for use when walking the dog...
The 5.5G ipod uses the WM8758 DAC (same pinouts as WM8978, I believe). So this looks like it might be doable - how good it will be is another matter 🙂 I haven't looked into this yet but is the half-speed bit-clock standard or non-standard implementation?
well there was never to my knowledge an ipod that used the WM8741, the ipod video, ipod touch 1g and iphone 3G were the last one to use a wolfston at all. they now use cyrus logic dacs. I could be wrong there, but i'm sure a fuss would have been made over an ipod using the WM874X dac over at head-fi and this would still be a very popular DAP if it ever did exist, which to my knowledge it never did.
