5v to 2.5v for 2a3 filament
Could you drop with an RC filter and eliminate some of the noise the other guys are commenting on?
If "R" part is doing the dropping it will heat up (inclusion of a capacitor doesn't affect that), as mentioned above. An alternative would be capacitive dropper, 2600 uF in series with the filament for 1R @ 60 Hz (mains frequency in the US). The problem is finding 2600 uF non-polarized capacitor, but one could substitute two larger capacitors in series (inverse) instead.
This might actually be the best solution as - just like transformer - it doesn't waste power in the form of heat, and on top of everything it also doesn't cost nearly as much or weigh as much as a suitable transformer.
