I don't believe cables make a difference, any input?
Is there anyone out there that can OBJECTIVELY see what the situation is here, and what will happen. Why, for example, does SY or anyone else need to be in the test at all? IF we can not trust an objective 'subjectivist' how are we going to trust an non-objective 'objectivist' to administer the test?
John,
You should really read up on 'controlled test'. The object is to avoid having to rely on trust.
From your posts it seems however that you are not interested in a well-designed and run test; you seem to be interested in trying to derail it at all cost. That's a shame, literally.
jd
Ive always thought that would make a great 'topic' for one of these meets, or get-togethers, whatever the correct term is in your part of the world.
A back to back of these two polar opposite views. Plenty of scope for the 'rules'..dunno maybe set a budget and then each camp goes about following thier particular religious belief.
Yes it would be an interesting execise, but from my experience, very few followers would cross the divide.
From the way you posed it, it does look like they can never reconcile, and that each is as valid as the other.
Each is valid to the individual's value system - likes/dislikes, or what they have programmed themselves to listen for.
People will often hear differences that fall in their "so what" category, but these differences are very important to someone else.
To me, the way thru that is to look at the entire chain and apply the following 'algorithm' to it...'fix the worst spot first' or somesuch.
The view of source etc being the most important contains a fatal flaw (I feel)...that each part is equal or as important as the other. From whatever angle you want to look at it, the speaker/speaker room is where things go south the most.
I would agree that there are very few systems that are beyond some fairly easy improvements.
Let's take a hypothetical single driver system as an example....if any electronic component had as bad a response as that it would never make it out the door. It would be rejected as completely flawed and unusable.
Can this be resolved?? dunno, but it would make for a fun meet wouldn't it??
If you had asked me 5 years ago, I would have agreed with you, but I have heard a couple of high efficiency full range speakers that have been so good in a particular aspect - midrange dynamic life - that I am using such a driver (in a 2.5 way system) in the speaker that I am currently building.
The single most effective demonstration of dsp I have come across is to flick from uncorrected to corrected on a single driver. No-one misses the difference. Better or not is a personal decision.
I am sure that this would be so, but others might prefer to do the equalisation in another way.
It would only take a slight modification of the protocol to accomplish it, two source chains (one with an emphasis on the source and amps and cables etc, representing that side of the coin) and another with dsp and bog standard cables and source representing the other.
Each hidden (to the listener), swap the end of each chain in turn and listen.
No 'egos' on the line (as there can be in cable audibility etc), just 'which is better?'.
It's all well and good for us to sit back and blab on forums...valves vs ss, cd vs vinyl, on and on.
It's always best to learn if we can, and I for one would love to be a part of something like that.
And the best part is it would be fun, unlike tests were there are reputations (for lack of a better word) at stake.
Are you talking about a behind the curtain style demo?
yeah, why not? that's what makes it fun.
all you can go on is what you hear. fun, and entertaining.
what's not to like?
so you use a 'single driver' but in a 2,5 way? (not sure if I understood you) that's fine. most single drivers need a bit of help😀 The point is tho, you need to hear *side by side* the single driver with it's ;horrendous' FR, vs that very same single driver without that horrendous response.
Then and only then can you say whether or not it is an advantage to have that FR or not. And whilst I am on this quickly, whatever attributes you particularly like about a single driver are NOT taken away by having it's FR 'fixed'...well, unless you particularly like that response!~!~
Make that single driver flat (or at least flatter) and bang, increased detail, intelligibilty, soundstage opens up.
We can agree at least it does quite a bit more than a mere cable.
Thanks for opening up the conversation, cables are so, hmm, outdated.
Apparently I had it wrong and SY no longer approves of the use of an ABX box for DBTs.
Seriously, rdf, you're still making things up. Why? I had thought you were capable of honest debate, but I'm starting to have serious doubts. You certainly read the protocol for TG's test, because you commented and discussed it extensively; the test wasn't suddenly developed in the last few days. Then suddenly, you throw an ABX box red herring into the mix (which you have never used, listened to, tested, whatever) and follow up that misrepresentation by attributing positions to me that I've never taken. That is, frankly, dishonest, and I am terribly disappointed that you, of all people, would resort to that sort of below-the-belt tactic.
Semmelweis's hypothesis, that there was only one cause, that all that mattered was cleanliness, was extreme at the time, and was largely ignored, rejected or ridiculed.
(For lack of data.)
While today, over 150 years later, Dr. Semmelweis is appreciated for his discovery, it was NOT true at the time, EVEN with the evidence that he had gathered.
Well, there it is.
Sy's mention of religion was spot on. Every good religion makes you a martyr.
Let's face it, who's ego would not want them to be the guy who figured something out first? I mean, that'd be good but, imagine if everyone said you were wrong; the experts, the pundits, your peers.... hell even your measuring instruments said you were wrong... But you showed them all! Hah!
Who could let go of such a fantasy, once it had its grip on them? Perhaps, not me either.
(Takes off psychologists hat. Way too tight. Like it is trying to shrink my head.)
Huh?
To be really successful, or at least ahead of the pack that includes companies with resources far beyond what we can ever have, we have to keep our eyes open for both practical improvements, that might first appear as only 'accidents' and yet apply every new idea proposed by others, and even older ideas not usually associated with audio.
Agreed.
Quantum physics is one of those areas that is often useful for understanding how to make better audio equipment. It is NOT my area of expertise. However, I find that using a concept derived from what I can understand and use of it, gives enough intellectual framework to go along with it.
I understand the thought process, but this I can´t agree with.
All I know about quantum physics is about stray particles that jump off the flow. They are not coliding with other particles, they just follow their own route for no apparently logical reason. But expecting sonic improvements from what happens at subatomic levels is just too extreme, I think.
Bybee´s "quantum purifiers" seem to me like a hoax...
it now seems true that a switch has never been a part of the upcoming procedure. Tg has been against it for a long while.
Hi Terry,
I've posted it before, but it seems that we need a little reminder
Subjectivist Fallacies:
Subjectivism
In an argument of this sort, a subjective state--the mere fact that we have a belief or desire--is used as evidence for the truth of a proposition.
We can see what's wrong with this argument by identifying the implicit premise. To make this argument stronger, one would have to accept the premise that whatever I believe or want to be true is true. That is, subjectivism implicitly assumes that we are infallible. And of course we aren't.
Subjectivism is not only a way of adopting conclusions on subjective grounds, but also--and probably more often--a way of evading conclusions by refusing to believe in them. Some people have perfected the skill of simply not seeing what they don't want to see, and most of us indulge in this habit occasionally. If the habit were put into words, it would take the form, "I don't want to accept p; therefore, p isn't true." That's subjectivism.
Whether it's written word, or hearing what one wants to hear, makes no difference. Not when you believe in something.
Exactly. This is why I have repeatedly proposed (only to have audiophiles flee in fear), that rather than comparing this and that woo, instead, compare it all. I will bring my entire soundwave system into the home/room of the audiophile and directly compare against their belief system (the only stipulation being if the room is stuffed full of acoustic gauze and bandaids, that they be removable). No individual parts, the whole kit and caboodle, in front of a listening panel. A real "listening competition" as JC alluded to prior, but failed to disclose details.
Know how many takers I've had amongst the online big talkers? 🙂
cheers,
AJ
p.s. The international big talkers are safe, that's a bit outside my range.
hi AJ. Not quite sure of why you posted your definition (again), not that I disagree with it. It's just you quoted me...I only quoted TG as rdf thought a switch box was part of the procedure. Tg would never allow it, just showing (as SY pointed out recently) that bthe switch box was just another misdirection.
The only changes I would make to your challenge (if possible).. it cannot be against someones 'established' system in their own room...they (all of us, we are human after all) could never admit wrongness of any description. So best off (as I alluded to earlier) simply having two representative systems of the philosophies at work in a new room.
(If I heard it against mine in my room, and did not want to admit the other was better, I can recognise mine and vote against the other. If I heard two new systems in a new room, had never heard them before I can make a value judgement on which I prefer)
That also means they need to be blinded. If I am 'anti dsp' (in my previous example) then I can simply 'choose to hear digital artifacts' if I know which is which.
If I am blinded, again I can only choose on preference. Unless of course I am a single driver guy and know multi driver systems have no such coherence, then I can safely choose the one with 'no bass and treble'!
Ha, chatted with a mate who was here recently about that (is it true that multi driver systems don't have the same coherence? etc etc), and to get around that I could decide (as I use dsp) to emulate at the LP roughly the same bass extension etc, ie hobble the bass on mine. Remove one of the major cues as to which might be which.
Wonder if that would get around the problem??
Anyway, I reckon that would be a fantastically fun day. You're safe from OS 'contestants', I (being out in the middle of our state) am pretty safe from australian contestants, more the pity.
Hi Boconner,
I was hoping to elicit some pointers, links etc from the purveyors of the esoteric theorems regarding signal transmission, as some people are 20-30 years ahead of mere mortals like myself I was hoping they would find the time to impart some of their knowledge for my perusal, as signal integrity is of paramount importance in the job I do, and I am beginning to fear that my education in the subject is flawed and I may have wasted 25 years of my life.
The worst possible person to run a test is a committed subjectivist as they will move mental mountains not to have their preconceptions proven wrong (if that is what occurs)
Since some seem to like blowing flames between objectivists and subjectivists, I could just as well say: The worst possible person to run a test is a committed objectivist with preconceived ideas of what is audible as they will use inferior equipment, a poor setup and untrained listeners not to have their preconceptions proven wrong.
Now have we reached anything by this type of reasoning?
Further, IF you have everything else in the chain optimised, then then it would make sense too.
Wasn't that said many times before? Of course sort out the system first, then experiment with cables if you want.
Indeed. I did some dbt tests some time ago with cables and amps. I couldn't tell the difference between expensive cables and cheap ones. Same with well designed but significantly differently priced amps.
So I moved my attention elsewhere. Saved me heaps of time and serious $$$s. And Geddes is absolutely on the money with those thoughts that you quoted.
Indeed, if you can't hear a difference then don't bother just don't make it applicable to everybody else, results may differ.
Subjectivism
Subjectivism is not only a way of adopting conclusions on subjective grounds, but also--and probably more often--a way of evading conclusions by refusing to believe in them. Some people have perfected the skill of simply not seeing what they don't want to see, and most of us indulge in this habit occasionally. If the habit were put into words, it would take the form, "I don't want to accept; therefore, isn't true." That's subjectivism.
AJ. Your definition of subjectivism or subjectivists "MIGHT" be true for a very few subjectivists at the lunatic fringe but, they're a very rare breed. However as a subjectivist myself, I can honestly state I've never met a subjectivist who believes or practices your definition of subjectivism.
Years ago I coined the expression LFO ---{Lunatic Fringe Objectivist}--- for objectivists who also behave in a manner that should embarass any rational, truly scientifically oriented objectivist. I remember a couple of such fellows on Audio Asylum. There was one who didn't deny there were sonic differences in audio components but, he insisted SPL variations were what accounted for ALL of them. The other fellow insisted there has been absolutely no improvments made in speaker technology since the AR-9 was released. I don't want to start anything with you AJ but, even your recent statement about the EnABL'ed drivers, based on your disbelief was and still is unobjective, unscientific and very much the same behavior as what you're accusing the subjectivists of i.e., assumes that (you) are infallible, in your belief system and you don't want to accept; therefore, isn't true!
I get a laugh out of objectivists who use mult-way speakers with steep crossovers that are highly equalized, and then want to comment on how horrible my single fullrange drivers are! My POV on this "if" a person wants to use mult-way speakers with steep crossovers, I have no issue with that but, if they have to highly equalize their speakers to get acceptable performance ---{be they single or multi-way}--- then how good is the speaker design in the first place? I'm willing to listen to both before deciding which is the closest to live, unamplified music, but using the mult-way speakers with steep (or not steep) crossovers, unequalized, like mine are would be a more fair and true comparison of the two differeing designs!
There's a huge difference between rational subjectivism and what you described. Rational subjectivists do not dismiss science and measurements outright. We just question why an audio component that has the best measurements, doesn't always sound the most like live, unamplified music does. So we've come to believe that measurements are useful tools but as Olson says and Toole paraphrases "In all things audio, the ear is the final arbiter."
However I question what does any of this have to really do with the topic of this thread?
Thetubeguy1954
~Rational Subjectivism. It's An Acquired Taste!~
<<<Snip>>>
Oh how true Andre. I cannot tell you how much $$$$$ I would have saved if I couldn't hear a differences in amps, preamps, CD players, tubes, ICs, power cords, speaker wires, etc. That said, I don't believe my system would sound as good as it does today if I couldn't!
Thetubeguy1954
Thanks AJ!
AJ, I have forgetten to say Thank You for recommending Don't Smoke in Bed by Holly Cole. I love this CD especially the cut "Get Out of Town" It sounds like the three of them Aaron Davis on piano, David Piltch on Bass & Percussion and Holly Cole's Vocals, are right there in front of me! Actually it's four on this cut with Howard Levy playing an awesome part on the Harmonica! This might just be the cut I use for the IC DBT!
Thanks again! Excellently recorded CD. I am throughly enjoying it!!!!
Thetubeguy1954
Testing validity
Not a misrepresentation, just missing a caveat. The other caveat is that one has to be very careful how one designs the DBT.
Many excercises passed off as DBT are not well designed
dave
Then they aren't scientifically sound tests... this is relevant how?
Arguing that lousy scientific method and inattention to details results in erroneous results as some sort of condemnation of all of the various valid multivariate designs is like saying "my car won't run if I put water in the gas tank; hence cars are useless".
I agree with Auplater. And how is it that the use of poorly done DBT tests is criticized while the use of subjective listening - which no scientist would accept as having any validity - is not?
Floyd would say "First prove that you can actually hear what you claim.", then "The ear is the final judge". It's NOT a small caveat!!
