Friends,
I would like to order the EnABL kit and apply it to a Funktion-One horn speaker model Resolution 1.5 (see site and navigate to the "products" section to see the RES 1.5 speaker).
FUNKTION-ONE : OFFICIAL WEBSITE
my home system:
Picasa Web Albums - Herman
Basically, it's a 112db, 5" horn loaded driver incorporating an unusual phase plug that covers 600 to 15Khz.
1. I'd like to order the EnABL kit.
2. I will apply the kit and post my findings and pictures.
Thanks,
Herman
my home system:
Thanks,
Herman
Hi Herman,
Good to talk to you on the phone.
Ed's EnABL kit here
From the Funkion 1 website i'd say that the "thing" in the middle is more a part of the horn, than it is a phase plug. I built something similar, but much cruder, in the early 80s.
dave
Ed's EnABL kit here
dave
PS: is that a MacBook Pro or an old PowerBook (kie mine)?
dave
That's just a Dell Latitude D620. A weird creature that needs all wifi to be disabled to play audio, otherwise it starts to stutter. 😕
Also, I sent an e-mail to Ed, with my order request. Thanks for your help.
Herman
Some initial comments from a position of current, specific, ignorance.
I would treat the woofers first. Then I would treat the mid / woofer compression cone driver. Then I would listen for a good bit of time. Then I might treat the compression driver of the horn, but detailed high rez pics b4 you do that PLEASE!!!!!! Last I would treat just the outside edge of the horn flare. Then I would slowly work my way into the horn flare body and that of the wave guide plug.
You MUST be slow and attentive to horns. They can easily get so forceful and hard edged that you cannot listen to them. It is quite possible that the horn flare and wave guide plug will need no more than a parting edge treatment. It is also possible, though less likely that the CD will not need any treatment. It is certain that it will not need very much.
You really really really need a reference driver that teaches you about EnABL and how it portrays music before you tackle something as complex as this system. If you have a couple of hundred dollars to spare you could not do better than a pair of Planet 10 Fostex 127 eN drivers in small cardboard boxes. At no point in your life will you feel you have wasted that money! If you are intent on biting off this much, I would really like to feel confident you can survive and a clear target, which the 127's will provide, will help immensely.
Bud
Bud
