My take to the "Reference" TDA1541A DAC with I2S-BUS architecture
Joined 2009
After the finalizing of my 4x TDA1541A DAC, i thought there is still potential to upgrade especially in the PSU section.
Unfortunately not with a ready build PCB. So i decide to make a new DAC project with this main goals:
- Modular architecture to get max. flexibility
- DAC cascadable
- Compl. I2S-BUS architecture
In the modular design i see the main advatage. Every stage could be build upon the requirements:
- Input section
- DAC section
- Output section
- PS section
- Regulator section
This idea is surely not new. Doede Douma made a perfect modular system with his DDDAC 1543 MKII on his side.
He had the same goals but build his DAC only around the TDA1543.
His Input section with a separate USB to I2S PCB and SPDIF to I2S PCB, both with precise TentLab low jitter clocks, are superb.
So i only must think about a new TDA1541A, PSU & Regulator PCB to integrate it in his environment as shown in the next picture.
I designed a new PCB for the TDA1541a, cascadable for two, four, eight ore more DAC´s.
The Power Supply is also strict modular with a +/- PS-Board and two Regulator Boards with Salas great Shunt design.
One only for the TDA1541a and the other for the Buffer-IC on the DAC-Board and add. Digital Modules like Doede´s Input PCB´s.
So here are my new modules:
As you could see, the Buffer-IC is completely independent from the DAC power lines!
So you could use a separate regulator for it if you want.
For the Output-Stage i will connect my Tube-I-zator PCB, but everything else is surely possible.
After days of drawing the new PCB´s, i must relax a bit before the next step begins, the production of the PCB´s. 😛
Many thanks to Doede Douma for his brilliant concept and to Salas for his outstanding regulator design. :worship:
Best regards to the community,
Oliver
:cheers:
This is what I am looking for.
TDA1541 module should be able to stack to 2X, 4X or 8X........
External Dem-clock fit into Pin16 and 17 of this modular design will be perfect.
I have 10 TDA1541A sitting here for this project.
The PCB layout underneath of the TDA1541A should be improve, please check with the layout from those manufacturers as a reference.
If the external Dem-clock Pin16 and 17 can fit into this modular design will be perfect.
That would be no problem. I have a little space to insert a connector for that.
Perhaps it is a good idea to integrate the DEM clock circuit on the Module? 🙄
That is what I have sugessted on thread #5 😀😀😀
One base board with the external dem-reclock and I2S with indepand supply.
stackable TDA1541A and power supply modules over the base board
The base board module will supply power line, the dem-reclock and I2S signals to stackable TDA1541 modules.
@ fastvideo
Is this the circuit from ecdesigns that´s in your mind for the DEM-reclock?
This circuit doesn't work well to me, I have to change it this way to work:
with the same ics, 5V supply to both ic, removed D1, D2, R1, R2, R3, R4, R5. signal goes directly to U3 pin1, 2.
Originally Posted by -ecdesigns-
connecting pin 16 to -15V through a 2K2 resistor, and pin 17 to -15V using a 2K2 resistor. The DEM signal can then be injected using 10K Ohm between inverted and non-inverted DEM clock pin 16, and inverted DEM clock pin 17.
So we have this schematic! But if we have more than one board, how is the connection than? Should i insert this schematic on the module, so every 1541A has it´s own or extenal (one re-clock circuit for all DAC´s)?
What´s about the I2S attenuator? Is it still necessary in a buffered input like on my module?
I would go this way:
Base PCB. Power line, Dem-reclock and I2S attenuator. (May be it can have the first TDA with it)
Then the TDA1541 portion will be on a smaller stackable PCB. (The missing portion of your original)
One on top of the other one, I think this is the shortest path.
That would be one way, yes. But with the shunt regulators for each power line, you don´t get it much smaller.
Think about a 8x TDA, than we would have a skyscraper witch won´t fit in any case.
The outline of this module is about 125x125mm, so a compact design. As i posted before,
i won´t change my base concept. So i will try to insert the DEM-reclock, but will the 74HC02 drive all DAC´s on it´s output,
or do we have a 74HC02 for each DAC´s if we use more than one?
Do you have some experiences with the I2S attenuator after the buffer? I don´t know if it is necessary after it. 🙁
