archives.telex.com/archives/EV/Speakers/.../EVX-150A%20EDS.pdf - Similar
Well, that didn't work............
Looking for high efficency
Xmax is .250
power handling is 1000watts long term.
Xmax is .250
EV themselves used that driver in their MT4 boxes
If you're not using it in a setup that requires much cone motion, I'm sure they're great. I'm sure they're great for a bass amp speaker, too, when properly high-passed.
Uh, no they didn't. The EVX150A is a 15" driver and the MT4 uses 4 18" drivers.
Just wondering if I could tune a EVX150A low enough to get some usable sub response.
Hi, Why not try the EVX150A driver in a T-TQWT?🙂
b
"EV themselves used that driver in their MT4 boxes"
The MTL4 used the small magnet 18s, not the large magnet 15s.
The EVX150A should work well in a tapped horn subwoofer for home use.
well, I remembered it all wrong then.. crow tastes best when broiled.
Don't you mean stewed ( in their own juice ) quite good if you use plenty of salt and chillie
- Subwoofers
- EVX150A for sub use?
