When I'm travelling, I have a pair of Stax SRM-001 electrostatic in-ear headphones which I drive from the line output of my Sony D777 portable CD player. It sounds fairly reasonable, although the Stax sound much better from a proper source. However, the main bugbear is having to carry lots of CDs. It would be more convenient to play .wav files from my notebook - a 16GB USB stick could hold 20-30 CDs. But the onboard audio quality of a notebook is rubbish, so can anyone recommend a decent USB DAC that is ideally powered from the USB interface or its own battery? I don't need a headphone output or volume control, just line output.
Like so: Pacific Valve & Electric Company Pacific Valve Musiland Monitor 01 US ?
jd
If you have a PCMCIA slot, have a look at Echo Digital Audio Corporation
It was recommended to me in this thread and the guy who bought is seems very pleased.
OK, so two possibilities I hadn't found in my trawls. The PCMCIA slot gadget looks ideal in terms of portability (but what does it sound like?), but even the Pacific Valve would be tolerable. I'll keep searching...
Hard to tell how it sounds, I’ve never compared it to anything else but :
The creators implemented 24/96 which indicates that they seemed to care about quality.
It must be pretty bug free, the guy that makes extensive use of it has no idea how PC’s work and he never ever called me to fix a non-working soundcard.
Putting 24/96 on an product is hardly a sign of quality. Any 30 euro/dollar DVD player has it on it, and even 5 euro/dollar PCI soundcards... I guess, this thing comming from Echo audio counts for a lot more 😉
Even if it were a good product: PCMCIA is dying. You can't plug this in a normal PC (without extra hardware), and jamming lots of stuff in a very small package means that it will not be possible to use larger, often higher quality products. This does not mean that this is not a great product, but you should think about that.
They have smaller, too. 🙂
Note that I'm not affiliated in any way with echoaudio.
Hi!
I had a Echo Indigo I/O and I still own a Echo Indigo DJ pcmcia soundcard (the older ones, for pcmcia type II slot). For a really portable solution I think this is a very convincing card! The sound quality is really great for such a small piece of audio gear. Compared to an external high end dac it lacks a bit of naturalness and sweetness. But never the less the sound is fast, punchy, dynamic and precise over the whole frequency range, with great detail resolution.
If you buy the DJ version you get two analouge outputs, one variable and one fixed, suitable for headphones or for directly feeding an amp.
If you buy the I/O you get one variable output and one input for recording purposes.
The reliability is excellent, and the drivers are carefully programmed and updated frequently. It also supports asio natively!
Regards!
Martin
Regards!
Martin
It looks as though the arguments about PCMCIA size and likely audio quality may be academic because the manual for my Advent 4211-B says the slot is a card reader, and doesn't mention PCMCIA. Looks like an external brick may be the answer.
Well, in this case you might consider the Super Pro 707 USB DAC.
Super Pro DAC707
You can read something about it's potential here:
http://www.diyaudio.com/forums/digital-line-level/156846-so-many-dacs-choose.html
Super Pro DAC707
I'm happy to use an external brick DAC, but it must have either its own battery or run off USB. External power is not allowed as this has to be portable (otherwise, I'd use my DACmagic). I had a look at the Musiland, but Pacific Valve have not quite worked out that there are other countries in the world other than the US of A and their ordering system can't cope.
The usual suspects (so far as DIY goes) are:
AlienDAC (datasheet PCM2702 implementation - note that PCM2702 is becoming unobtanium fast)
BantamDAC (same as a above, but on a tiny board)
AMB Gamma-1 (PCM2707 for conversion to I2S, then a decent wolfson DAC)
GrubDAC (new design similar to bantamDAC, but using a wolfson DAC with a built-in voltage inverter which allows for a much simpler board and eliminates output coupling capacitors)
I use a Gamma-1 as my everyday DAC driving a Pimeta headphone amp, the combination is excellent. I also use a BantamDAC for connecting the laptop to the stereo - because the board is so tiny, it can be built as a "cable-dac" - a small box with a USB lead running in one side and RCA straight out the other. I've got a GrubDAC PCB on order, too, because one can never have too many USB DAC's, and I already had a few PCM2707 around.
If you'd like something which can drive headphones, look into the "Carrie" design over on Head-Fi, it's a version of the Mini3 adapted for USB power, with board dimensions designed to fit with a BantamDAC or GrubDAC in a Hammond 1455C80x case.
- Digital Line Level
- Recommend a portable USB DAC?
