KENWOOD L-07 CII preamp
It's my first thread here.
I have a Kenwood L-07 CII with a problem on the right input phono MC stage ( noisy with cracking... ).
But without diagram impossible to repair.
And also impossible to find service manual, schematic, information about, ...
Please I need your help !
Hallo, Raymond
You still remember to me (Mark Levinson No. 23)?
I have had the complete Service Manual from Kenwood's L-07 CII (original printing, not copy), but until this day I don't find it.
But I recall, that I have order it there:
Schaltungsdienst Lange oHG
Impressum: Schaltungsdienst Lange oHG
Zehrensdorfer Str. 11
12277 Berlin-Marienfelde
Tel.: ++49 (0) 30 / 723 81-3
Fax: ++49 (0) 30 / 723 81-500
info@schaltungsdienst.de
Andreas
P. S.: very fine website:
http://www.wtconcept.com/levinsonml2/
Hallo, Raymond
You still remember to me ( Mark Levinson No. 23 )?
Andreas
levinsonml2
Hello Andreas
IMPOSSIBLE !!! I will never forget my best friends 🙂
And discuss with you about Levinson gear as ML-1 faulty line modules, ...
What a pity you don't find your SM L-07CII.
Aparatusonitus very kindly ( again many thanks ! ) send me the L-07C schematics.
But a bit very different with MKII model.
And still, I never found these faulty components in the right MC phonostage of my preamp !
In fact, would L-07CII be more difficult to repair than a Levinson ML-2 ???
Raymond
Raymond
No.
.....on the right input phono MC stage ( noisy with cracking... ) ???
At first you must perform a failure isolation.
If there are switches to select the input impedance and gain factor, remove it and solder wires to get the neseccary values (no longer non linear transition resistance there are)
Now check out and compare the behavior with
- open input
- short input and
- normal input connection to your moving coil cartridge.
What happens? Is sound to hear? Or only noisy with cracking (flicker noise, shot noise)? Then there is a complete break in the signal line.
Are there a reaction by a slightly mechanical strain to the j-FET's and BjT arround the MC head amp?
If yes, and there are no bad soldering in this aera, the internal bond wire of the transistor itself has temporary interruption or unwanted transition resistance.
What about the color of the MC head amp transistor pins (black or silver)?
If you try to find schematics by google, uses different spelling
"L 07CII" "L07C II" "L07CII" "L 07C II" "L 07 C II" "L07 C II" both "Trio" and "Kenwood" for second keyword.
Here are some Links:
TRIO ƒRƒ“ƒgƒ��[ƒ‹ƒAƒ“ƒvL-07CII‚ÌŽd—l ƒgƒŠƒI
TRIO/KENWOOD ƒZƒpƒŒ�[ƒgƒAƒ“ƒv/‚»‚Ì‘¼ƒAƒ“ƒvˆê—— ƒgƒŠƒI/ƒPƒ“ƒEƒbƒh
review33.com - 影音天地
Kenwood L-07C-II, Hifi-Klassiker - HIFI-FORUM
and attachements:
Raymond
NO !!! L-07CII a bit less complex than Levinson ML-2
Yesterday failure was solved.
In fact only ( I don't know which one ) a bad solder on the mother board ( a double-side one ) and the solution was to re-solder on the two faces all components on the MC stage.
But without your help, Aparatusonitus and Tefbassuebertr, I think I lost my footing !
Raymond.
About my work on ML-2 amps :
Hope you don't mind me reviving an old thread. I've just acquired an L-07C II, and while the exterior is nearly pristine, the inside is a bit of a mess; its needs at the very least a complete recap. I would very much appreciate any help getting a copy of the service manual!
Thank you.
