Power supply for my "DIY" RIAA
How can you tell and what does that mean? Sorry for the noob questions here but I'm still trying to learn a lot of this.
A dual secondary transformer has 2 separate output windings - it's like 2 transformers in one.
A centre tapped transformer has one output winding but is "tapped" in the middle to split the voltage.
For example:
Dual secondary would be referred to in voltage terms as 22-0, 22-0 whereas a centre tapped would be referred to as 22-0-22. Both transformers can provide either 22 or 44 volts.
See HERE for some pics.
OK, thanks. Looks like they have those dual secondary transformers on that site as well, for $20 for a 15V one, and I don't think that is all that unreasonable. Gives me a starting point for $60 or so and then I can see how it works out.
Now if US customs can get off their butts and send me my record player I'll be happy.
A simple +/- 18V Supply
I recently had the need to build just such a supply for a RIAA front end. I used a 35VCT 100 ma toroidal transformer (available from Newark Electronics) connected to a standard fullwave bridge. 120 Hz hum can be minimized by using a C-L-C Pi network instead of just a capacitor. A 4700 uF/20 mH/4700 uF reduced the 120 Hz component to the millivolt level even before the regulators. An LM317/337 pair is used for voltage regulation. All resistors are 1% metal film, and the resistive divider node is bypassed with ~10 uF Ta. The output of the regulators is bypassed with 4700 uF to eliminate any residual noise. The resulting noise level was at the measurement limits of a 6.5 digit voltmeter, or <1 uVRMS. One final note, In their app note, National Semi recommends including a pair of diodes around each regulator to provide input and output protection. 1N4001 diodes or equivalent will work fine. The regulator was built on 2-layer PCB, allowing for a nearly continuous ground plane, and the transformer/regulator is housed in a separate chassis from the preamp itself.
