Speakon Vs. XLR?
I'm hoping to build some active 2-way speakers, and want to create an idiotproof method to connect the two to prevent sending low-frequency signals to the tweeter. I was thinking of using some 3-pin XLR cable (which seems to be quite popular as a speaker connection on older European gear) and use a shared ground for the woofer and tweeter. Is there any reason I shouldn't do this? I'm only using 60W, I'll be making the cables myself (so wire gauge should not be a problem) and using high-quality XLR connectors is only 40% the cost of Speakon stuff.
The main reason I can see is the risk of mixing inputs and outputs, since 3-pin XLR is mostly for lo-level signals. OTOH, if you have no other XLR stuff in a home setup, no risk. The common ground of a 3-wire cable certainly goes against the cult of bi-wiring. Also, tying the output commons of two amps together could be a bad idea.
XLR come in 4 to 6 pin versions. Not so common, and maybe more costly. Unless they aren't because the dealer is tired of dusting them.
There's also the Alcatel EP connectors; they're uncommon, but you might find a box of them used at some pro sound dealer. They're impressively supersized XLR connectors with plenty of pins. The receptacles fit the same cutouts as the round Speakon receptacles.
Finally, the venerable "Jones" plugs, which can be had with plenty of pins and handle reasonable currents.
Speakon's advantage lies mostly in its durability - the genuine Neutrik plugs are close to indestructable. This is a good feature on stuff that gets bashed around a bit. Also, the locking actually works, which is handy when the stage gets swarmed by 12 year old metal fans.
So far as making your own cables go, the advantage of Speakon is that the strain relief is built for the high gauge cable, whereas XLR is built for mic cables.
For home audio, though, it's probably overkill, unless you have a particularly brutal living room.
Unfortunately the 4 to 6 pin versions have much smaller pins and less current carrying capacity. I sometimes use these connectors for remote DC power supplies but only low current ones.
