F5 power amplifier
Hello
I'm planing to build a balanced input X-ed F5 with multiple output MOSFETs .
But right now I'm in half way to have all the (exotic) parts , PC boars etc .
In case if I will have offset or any serious problem I can't solved I will go with balanced input bridged F5 .
Right now I can not write more , probably when I'm finished or will have some experience to report .
But it is possible to build such a amplifier !!!
Greets
EUVL built balanced/bridged version of F5 more than a year ago - this is a big thread, but I'm sure it won't be hard to find his version.
Yes , only 600+ pages to go thru ... 🙂
That's if you think that the dual diff pairs sound ok!
Who thinks what on this?
And, the poster I responded to already had balanced output from his source, so no need for the diff pairs! 😀
_-_-
You believe a balanced input would be negative ? What about bridging ?
You can easily build a balanced F5 with dual diff pairs.
Who wants the glory of posting the schematic?
Maybe EUVL will post his ....
I just wanna learn what happens if i use 100R for gate and 15 R resistors instead of 10R. I am interested
The gain of the JFET section is:
(2k2 || P1)/(R1 + 1/gmQ1), NP used a nominal 20mS for Q1, so the gain boils down to 600/60=10. So if you don't have 10R and have to use 15R the gain is going to be a tad less. You'll also find that JFET's vary quite a bit in their parameters.
Erno Borbely has written several articles on JFETs -- these 2 are required reading:
http://www.borbelyaudio.com/adobe/ae599bor.pdf
http://www.borbelyaudio.com/adobe/ae699bor.pdf
There's been a bit of controversy over the wattage of R1,R2. Remember that there's a voltage divider between drain of the output MOSFET's, (R5 || R7) and R1, so if you are going to crank this amplifier to 25W, R1 can heat up quite a bit. 1 Watt minimum here.
=a.wayne;2048846]<snip>
<snip>
A balanced output (that is, coming from the source) will have a + phase and a - phase. So if you have that, you can drive two identical amps one from each phase and connect the load to the "+" terminal of each amplifier - instant "bridged amplifier".
IF you only have an RCA output, you will need a way to generate a "+phase" and a " -phase " so that you can bridge the amps.
Diff pairs are only one way to do it. There are some real issues with diff pairs.
_-_-bear
