Optional Parts
Optional Speaker
Here is the wonderful comment from Audioasylum
Features:
This is a single stereo power amplifier using the 6BM8 vacuum tube that has a five triode for power amplification and a triode for amplified voltage. Assembly is easy. Anyone can follow the printed circuit board and obtain the same result. For this reason, you do not need to know the details of wiring and other technical details to assemble a vacuum tube.
This amplifier installed with advanced "R-core transformer" as a power transformer that enables clear tone quality. To improve transient characteristics.
Specification:
Vacuum tube : 6BM8 x 2
Rated output : 2W + 2(8Ω)
Rated input : 600mV
Input resistance : 45kΩ
Residual noise : 80μV(IEC WEIGHTING)
S/N ratio : 94dB(IEC WEIGHTING)
Frequency response : 26~37,000Hz
Power voltage : AC120V 50 / 60Hz
Power consumption : 35W
Dimension : W130 X H130 X D263mm (including projections)
Weight : 2.9kg
Input terminal : Line x 2 (RCA pin jack)
Fuse : 1A
VKMusic.ca Home page
Price $275 for DIY audio member
Elekit Kits Forum: Building the TU-870R (photos) by 4season
Amp/Preamp Asylum: RE: (strong)REVIEW: Elekit TU-873LE II Amplifier (Tube)(/strong) by geraldm121
Optional Parts
Optional Speaker
Features:
Specification:
Rated input : 600mV
Weight : 2.9kg
Fuse : 1A
Price $275 for DIY audio member[/QUOTE
PRICE after January 17, 2010 is $ 290.00
