The latter sounds better, but the former is warmer. 🙂So now, I'll have to choose between the LT1468 and LT1028...
In your place, staying with DIP chips, I'd do LT1028ACN8 + AD845KN.
The reason why there was such a change in sonic character with the Audioquest, is that the VDH was kind of its polar opposite: the latter being (comparatively) light and refreshing (coaxial + stranded + silver plated ...no wonder), the former instead being (with burn in) bolder, warmer, with more composure (solid core + symmetric conductors + all copper ...no wonder).
Sure, with the Audioquest there was also an improvement in overall sound quality (as in, more low-level resolution and, thanks to the absence of silver, better tonality), but the more apparent change was that of sonic character... as I focussed better after longer listening.
But 🙂 I'd kept the VDH only a few days before trying the Audioquest. All sonic comparisons (in the Super Pro DAC) were made using the neutral (meaning a sort of average between freq. response & sonic color), if lower in quality than the two above, Sommercable Classique.
With low (a couple of Kohm) input impedances, the stock TI NE5534 performed much worse than the LT1357 in my other DAC (Musiland SVDAC05). Congested/screamy upper midrange, small soundstage, lack of bass & treble extension.and at those impedances the NE5534 is probably about as good as it gets.
Korrah, I was forgetting... for the summer/buffer, you would want to compare LT1357 and AD845. I think the LT1357 is more clynically precise while staying musical and relatively warm, the AD845KN is more relaxed (in detail and pace) and mellow.
The LT1357 is also well suited as a buffer since it drives any capacitive loads (see datasheet).
My 5th post in a row 😀
Are you the man who designed the AD797?! I learnt it lately reading another thread. Well, you're due more respect than we gave you before, sorry. 😱
Noise isn't an issue here, and at those impedances the NE5534 is probably about as good as it gets
I was referring to the noise aspect 🙂
Well, the LT1028 and OPA1611 are lower noise. Anyhow, I think it matters none.
Interesting... having replaced 5534's myself in a DAC (Micromega Stage 2) I know that OPA604 and AD845 work well for me. I use AD845 for the final buffer. Noise isn't an issue here, and at those impedances the NE5534 is probably about as good as it gets.
There is some evidence to suggest that FET input opamps work better for I/V conversion, possibly because Bipolar input stages "interact" with any HF hash coming from the DAC in a non linear way... hence the OPA604.
I don't think the output stage acts as an I/V though, since the DAC is a AK4393.
I've bitten the bullet and bought a set of LT1028s. >.> Hope its happy in this circuit...
i've bitten the bullet and bought a set of lt1028s. >.> hope its happy in this circuit...
acn8 ?
I see. I did recommend the ACN8 for a reason, but also the CN8 will be fine.No, CN8.
AC sounds noticeably better than C for me...anyway AD797B and LT1028A have become my "de facto" op-amps, luckily either of the two always does wonders wherever I try them 🙂
Actually I haven't ever used the CN8. Only ACN8 and CS8. And actually I don't think I heard significant differences, although they were put in two different DACs 😱
Instead I'd be curious to hear if there's really such a difference between AD797 A and B. That'd be fun 🙂
No problem, you go at this like the Energizer Bunny 🙂 , while others spend weeks living with each change.
Hahah, I'm a bit frenetic I know, but there's method in madness 🙂
Like spinning many opamps rapidly, then going back to the ones that inspired me the most, to understand them better... That's how I make sure what I prefer. 😎
finally got the opa1611 into my cdp, sound is very close with lme49720 metal case.
opa1611 is good.
Andrea is saving me lots of time.🙂🙂🙂
opa1611 is good.
opa1611 is good.
Agreed...there's a definite resemblance. Enjoy. 🙂
Any chance to tested with OPA1641 yet?
Not until I learnt about it 😛 Thanks for the tip! It's a new low cost JFET opamp...let me have a look at the datasheet.
In general I prefer bipolar opamps, anyway.
It looks really good, but not quite as good (keeping the JFET inputs) as the much more expensive ADA4627-1.
I'm not crazy about the just 1.8 mA supply current, and the just 30 mA peak output current.
But... I'm pretty sure it will be a better sounding JFET opamp than the likes of OPA627, OPA2107, OPA2111... 🙂
- Chip Amps
- The best sounding audio integrated opamps
