How connect CS8412 to OS filter ?
as I like to play first time with various DAC chips outside CDP as there are TDA1541, PCM56, PCM58 and PCM1702... and in the data sheets signals always have different names, I am lost.
For TDA1541, how can CS8412 be connected to SAA7220 ?
And which OS filter I best use for other DAC chips ?
I have SM 5813 and SM 5841.
In SM5841 data sheet I saw sample/hold used with two PCM58. Why ?
Main problem is that in SM5813 datasheet I see 4 signals input but CS8412 has only 3 signals output.
How do I have to connect CS8412 to SM5813 to use above PCM chips ?
Bernhard
CS8412 to SAA7220.
CS8412 OUTPUT FORMAT 2
SDATA => DAAB
FSYNC => WSAB
SCK => CLAB
MCK => XIN
CS8412 to SM5813.
CS8412 OUTPUT FORMAT 5
SM5813 CKDV = HIGH
SM5813 CKSL = LOW
SM5813 COB = HIGH
SDATA => DIN
FSYNC => LRCI
SCK => BCKI
MCK => XTI
CS8412 to SAA7220.
SDATA => DAAB
FSYNC => WSAB
SCK => CLAB
MCK => XIN
CS8412 to SM5813.
SM5813 CKDV = HIGH
SM5813 CKSL = LOW
SM5813 COB = HIGH
SDATA => DIN
FSYNC => LRCI
SCK => BCKI
MCK => XTI
Hello
And how can the CS8414 be connected to the SAA7030 ?
And the SAA7030 would be connected to a TDA1541A.
I think of that because the CS8414 do have SPDIF input.
Here is the SAA7030 data sheet;
http://www.elenota.pl/upload/saa7030.pdf
Thank
Bye
Gaetan
Hello
I will look for that circuit to convert from OB to TC.
And for SAA7030 to TDA1541A, any suggestions ?
Thank you
Bye
Gaetan
See Table 1 on page 5 of the TDA1541A datasheet.
LAT => LE
/CLFD => BCK
DLFD => DATA L
DRFD => DATA R
As the output of the SAA7030 is only 14 bits and, as far as I can surmise from the datasheet (best check with a 'scope), the sign bit/MSB is not extended, you will need 16 clock cycles to correctly align the 14bit SAA7030 data with the TDA1541A's 16bit input latch.Again more glue logic.
LAT => LE
/CLFD => BCK
DLFD => DATA L
DRFD => DATA R
Hello
Yes, true, it take 16 bit input and give out 14 bit with noise shaping to imitate 16 bit.
Humm... 14 bit and more glue logic.
Maby I should go to the analog shift registered dac schematic (an analog 4x OS) that I have received from a friend by email.
But an analog shift registered dac like this one may have more jitter ?
Included the analog shift registered dac schematic.
Thank
Bye
Gaetan
