OLD THREAD DAC End by Andrea Ciuffoli
Joined 2006
Patrick, I dont mind assisting with a group buy for such a thing, however, I would not support devaluing the cost on a customs form, so value would be ~31 usd.
Expensive little chip.
This will be a pricey unit when done, output tranny and all, unless that can be avioided.
There are no cheap AD1865s around, and you can search the forum for comments about sonic differences between different grades. I personally would only go for the NK grade. And I think the PCB is designed for DIP package anyway.
Whatever, there does not seem to be much interest anyhow .....
Patrick
Hi quanghao!
It looks like you have added an analog filter to the original design (on DAC board, choke and capacitor) ... Is that so? Why? And can it be by-passed?
Best! :)
YES! That is one option, you can choice or no! I make it for many pople can use!
When You use I/v which tranformer you dont need filter.
You use I/v normal Tube or OP , you can use this option! If you like!
Hi all! At the moment the first units are in production and the DAC-END can start.
Information:
A. The PCB has the following data:
Material: FR4 - 1.6mm
Layers: 2 and 1
Board size: 95x110 mm
Surface finish: Immersion Gold
Copper weight: 70µm
Soldermask: Both sides - Red
Silkscreen: Legend on top
B. The price will be as followed:
On set (4PCB)
1. PCB- DAC END =$15
2. PCB- Salas Shunt For DAC=$15
3. PCB- I/V stage =$15
4. PCB- 10M45 for I/V= $10
5. Worldwide shipping: $ 5
6. paypal fee: 3,5%
A donation of $2usd to diyAudio will be done for every DAC-END pcb sold
A gift $1 for Salas contribute to diyAudio,I thank Salas very much.
Pre-Orders only at papal: quanghao168@yahoo.com.vn
Best regards to the community
Quanghao
Information:
Layers: 2 and 1
Copper weight: 70µm
On set (4PCB)
6. paypal fee: 3,9%
Quanghao
I'm starting saving money for it.....
What bout all component cost? in US $ please....
