bryston clone
Ampfilier is very sound quality but little bass.
Congratulations, it looks like quite a bit of work went into that.
I have a Bryston, the guts of it are a 2B, and the bass is very strong (into my PMC floorstanders). What you built should have at least as much bass as mine.
So the circuit topology should be fine. That leaves components ?
Big power supply capacitors provide energy storage for the amplifier to draw on for big bass peaks so if you've got tiny caps, which it looks like from the photo, you need more capacitance on the power supply rails.
Umut arkadaşım.Öncelikle Burda bir turk gördüğüme öncelikle sevindim.
Opamp Preanfisi var.DOA 33 diye isimlendirmişler.Bu cihazı yaparken aynı zamanda crown xls 202 serisini yaptık.İkisini aynı beslemeyle aynı anda dinleyince bu anfi baslarda zayıf insan seslerinde çok iyi.Ancak crownda da bundaki insan sesleri yok. bu likde xls 202 serisi için
Bloggang.com : K_evens : C-500 Power Amplifier
  • malzeme yerleşim.pdf
  • SST PRE.pdf
:cop: Thanks for your post, but please make all future posts in English. This is an international site, so we've made the use of English mandatory in order to have the widest possible understanding.
Many thanks!
