Bzzt. Sorry curly (the ongoing education continues...siiiggghhhhh)
they were YOUR words I quoted..back to yourself. You tried to use them against me, but only succeeded in demolishing your own case.
You claim that you, without doubt, can hear cable signatures...true or false curly?
You also state that you are not influenced by anything other than the sound, true or false curly?
You state this as an absolute, true or false curly?
Ok then for arguments sake let's accept all that.
Good. Now explain it all in the light of your own words curly
but you will never be able to prove any of it, regardless of any tests that are conducted. It is simply not possible to prove anything about human abilities to a perfect degree where there will never be doubt.
I ask you yet again curly, do you have any doubt about YOUR abilities?? If not, then why did you write what you did?
If you do not want to answer that one, what about THIS one. It is just not something that I feel will ever be totally proven until science can read what the brain is seeing when a person listens to music.
Again, are you as certain of your abilities to hear these differences in the light of YOUR comment here as you have been maintaining all this time??
(I told you all of this before, I was trying to be helpful you know, you gotta stop shooting your gun into your foot)
Sorry you will never be able to educate me as you have nothing to offer other than a closed minded stance to what is possible. You are all words and no experience. I refuse to respond to close minded verbiage from someone that has all the answers of what makes the world go around. I have nothing to to prove to you or anyone else. I doubt that you would accept it, even if I could, as there would be some reason, just like the Amazing Randi and Fremer.
Scientists, electrical engineers and pretty well anyone who graduated highschool. But if you have scientific evidence to show we might not fully understand resistance or impedance then do please share it. Or, just shut up and admit you don't know what the **** you are talking about.
BoIIocks.
Curly:
Er, and you pay attention. It's black because it's a different dielectic - it's loaded with carbon. Colour is irrelevant!
The dielectric is still the same. The carbon is responsible for the color!!!!!!!!!
Curly:
If backpeddling were an Olympic sport... 😀
That makes about as much sense as your understanding of audio equipment. You sure like to talk about something that you have so limited experience with. I mean maybe you could at least spend some time with things that you want to know and preach about, or is your stance that as long as I have read it, therefore it must be true, rule your thoughts?
Panikos:
Yes - but in a DBT you're comparing TWO cables, both of which go through the switchbox. The switchbox's audible signature (if any!) is present equally in both tests so it will not affect the test - after all, we're looking for differences. Using switchboxes allows the fastest, quietest means of switching cables. They're essential, but would have no impact on the test.
No the measured distortion of the switch is greater than the cables. It will swamp out any signature you are looking for. Don't believe me, measure it yourself. I have.
What, is this a trick question?
Well, let me see now... oh, I know! You put carbon in it!! Amirite???
Hey, Andre the Intellectual Giant, I've got a question for you too! (it's not a trick question though).
What happens to a material when you put carbon in it, apart from changing its colour?
I think you get a pencil? 🙂
Doomlord, John only tried to show that colouring a dielectric influence it's properties.
Yet more ducking and weaving.I will not respond to anyone that has no valid experience in audio
Contempt for 'book learning' is a well-understood characteristic of the ignorant and fearful.other than what they have read from a book.
Jan, what I mean is that his theory may describe what 'we' are hearing, not like some theories that are directly in contrast with what listening suggest.
Isn't that the idea?
His theory may also describe what we are feeling when we look at a passing train. So?
jd
It was ***** switch then. By the way, any links to switch distortion measurements you can offer? I don't have the means to measure anything myself 🙁No the measured distortion of the switch is greater than the cables. It will swamp out any signature you are looking for. Don't believe me, measure it yourself. I have.
Hardly. I do not believe that tests of this type can ever provide real true data as the brain is under pressure to perform. It is just not something that I feel will ever be totally proven until science can read what the brain is seeing when a person listens to music. Test conditions are pressure packed and will skew results. Maybe we get a Vulcan to perform your tests 🙂[snip].
On the contrary, you can take the test at your leisure and take as much time as you would normally do. The only difference is that you don't see which cable you are currently listening to. It may make you feel uneasy, 'cause now your ears are on their own ;-)
But pressure-packed? That's nonsense.
BTW Are you aware that most people perform their chores better when there is some pressure on them?
jd
I will not respond to anyone that has no valid experience in audio other than what they have read from a book. Period.
but you just did... everything you say seems to be an oxymoron
If, from now on, I encounter posts pointing a finger towards a fellow member, said poster will find himself lurking from the SinBin or will even find himself banned.
Very last warning and don’t count on less than a week in the bin.
Talk about cables, not each other.
This is not to be discussed in public, my mailbox is open 24/7
/Hugo
/Hugo
Hmmm. Maybe it is good to remember that often books are based on more and more intens experiences and tests than most of us can master in a lifetime.
jd
jd
Exactly, it may happen with the ears also. 🙂
jd
I doubt that they are of a subjective nature though Jan. Using two different sides of their brains to do said tasks, as a rule.
Sorry pal, but all the diversionary tactics in the world amount to nothing. We're not impressed. The bottom line is - you can't answer the questions put to you. You can't show why a DBT is invalid, all you do is make excuses to avoid ever taking one and whine about pressure. You can't answer simple arguments based on scientific knowledge, instead you choose to deride scientific knowledge because it comes in books. You claim that your 'experience' in audio validates your beliefs, yet you have not addressed the basic fallacy in your thinking, that subjective experience trumps objective fact or that 'being in high-end audio for 20 years' means you don't have to listen to reason.
You complain about the invalidity of my arguments. If they're invalid, use your vaunted experience to prove it. Oh way, you can't. You're full of cr4p. Arguing from authority, even your own, is a fallacy, btw. Think about that.
jd
Not directly knocking books as far as a reference, but experience is what reinenforces anything that may be learned through a book, is all that i am saying. Without experience, you are following blindly.
About 10 years ago hi-fi magazine of which I was the editor bought wireworld's cable comparator. While I could easily hear differences between cables in sighted test, using the comparator I didn't hear any difference even when I was operating the comparator. I still don't have an explanation for that.
I think the question should be: can you identify two cables in blind test (it doesn't have to be DBT)?
About 10 years ago hi-fi magazine of which I was the editor bought wireworld's cable comparator. While I could easily hear differences between cables in sighted test, using the comparator I didn't hear any difference even when I was operating the comparator. I still don't have an explanation for that. [snip]
The explanation has been known for, ohh, a couple of decades, maybe more? Also buried in this thread at several places.
[snip]I think the question should be: can you identify two cables in blind test (it doesn't have to be DBT)?
It should be DB to get accepted as fully controlled. Do you know, for example, that the results of placebo tests in medicine are influenced by whether the person giving the placebo knows or knows not that he is giving a placebo? So subtle is body language, and so good are we at picking it up. No, to be sure, as DB as possible. Just the sound!
jd
It was mentioned by someone in the past couple of days that a certain switching box (by design?) altered the character of both cables in a comparison.🙄
I assumed that this was to avoid the character/attributes of a cable which was well known to the listener being recognized.
To me this is a total nonsense as if the switching unit in any way masks or alters the cable's signature traits, then the test is null and void of value.
Your reaction is not surprising! There are of course many reasons for your experience.🙂
@doomlord_uk
I DID warn you!
- Design & Build
- Parts
- I don't believe cables make a difference, any input?
