i've recieved an amcron DC300A series II with some issues. but, i think i've made it worse then it was...
problem 1: channel B gets very hot
problem 2: channel A doesn't work properly sometimes. very loud pink-noise like sound, cone sucking in, etc etc. other times it works fine.
first: i don't know wich channel is wich, so i named the right channel (amplifier towards you, normal orientation) B, and left A.
then the schematics and layout (see attachments) (pre)driver board components, layout and complete schematic.
so, i started with problem 1, channel B, first. this since problem 2, channel A, didn't happen the first few test runs.
i noticed one of the driver transistors (Q209,Q214) from channel B was a MJ15003, instead of the original 2SD555. the other wasn't replaced. there's your oscillation. so i replaced both drivers with new MJ15003 (these are suitable, but not perfect. shouldn't be a problem tough). oscilation gone 🙂
then, i fired it up, it ran good for an hour or two. but no celebration yet because it overheated. turns out the bias of channel B isn't stable. after a minute it's over .1 volts higher (measured acros R232) then it should be, and raising. blowing cool air at the bias transistor brought it back to normal, so there's something wrong there.
after discovering this problem, channel A suddenly started acting weird. loud noise, peaks to VSupply, fluctuating DC offset, agressive speaker movement. channel B still 'normal'.
i turned the amplifier off, on, off, on.. sometimes normal, sometimes weird behaviour. i cound't measure for more then a few seconds because channel A heated up very quickly and i was sure my test-speaker would be destroyed.
I suspected the main amplifier board A. maybe a leaky power/driver transistor. so i disconnected the yel/wht coming from Q106 (pre-driver) to Q109 (driver) and vio/wht from Q107 to Q114 (ditto). same problem. reconnected the wires. same problem.
then i suspected the main opamp (uA739). swapped with another DC300A II, same problem. then i suspected the famous zeners+10uF 250V cap. replaced the cap, zeners were OK and besides should also influence channel B, not only A. still the same problem, only more frequent. could be because i've turned it on and off quite some times now.
went to sleep.
the next day, i turn it on and it works like a charm. same bias problem in channel B, but when the bias pot was set to minimum bias would just be stable enough to continue measuring channel A. turned it off, desoldered the red wire going to both output boards. i thought to do so to protect the output boards from the weird behaviour by not giving it any voltage.
turned back on. seems stable but music is still coming through quite clear, but low volume. strange. must get power from somewhere else?
i start tapping around on various component to check for loose connections. nothing triggers the fault. all transistors measure ok. while tapping around on the channel B-half of the board suddenly a spark flies from somewhere. unplugged the amp, and saw that Q220 (2n4125) was in two halves. measured around that transistor, no problems, inserted a BC557 for replacement (and doublechecked the orientation 😉 )
turned it on, acting as before with some music.
BUT THEN. channel A does the same trick as before, voltages, DC, everything. with the red V+ wire disconnected!!
stupid as i am, i turn of the amp, and reconnect the red wire (this was at 0:00, stupid stupid stupid. i should've slept) _only_ to channel B. turned it on, and Q106 (the pre-driver of channel A, D40P3) burns out.
the following questions where dominant:
- what now?
- was the BC557 a bad move?
- what common transistor can i use for replacement for the D40P3?
- how do i measure what is going on in channel A? i can't leave it on for more then a few seconds.. and i'm pretty sure i can't turn it on at all now.
- does anyone have a clue what could be wrong?
things i do know
- when you switch to mono (i've discovered this before things started blowing up) the noise etc is in both channels!!
- all the power transistors, resistors and diodes in both output boards are OK
- the uA739 is OK
- the power supply for the uA739 is OK
then i decided it was time to ask you folks
went to sleep.
- what now?
things i do know
- the uA739 is OK
oh, i see the complete schematic is badly readable.
here you can find the whole service manual
http://www.crownaudio.com/pdf/legacy/DC300AIIServiceManual.pdf
here are AMCRON/CROWN DC300A II transistor replacements i've found.
original -> preferred
original specs
other options
when i've recieved the replacements; the measuring can start again 🙂
D40P3 -> MJE344 / MJE340
Si NPN Power BJT
Various
V(BR)CEO (V)=180
V(BR)CBO (V)=250
I(C) Abs.(A) Collector Current=500m
Absolute Max. Power Diss. (W)=1.67
I(CBO) Max. (A)=10u
@V(CBO) (V) (Test Condition)=250
h(FE) Min. Static Current Gain=40
@I(C) (A) (Test Condition)=80m
@V(CE) (V) (Test Condition)=10
f(T) Min. (Hz) Transition Freq=50M
t(r) Max. (s) Rise time=2.5u
t(s) Max. (s) Storage time.=2.5u
C(obo) (Max) (F)=6.0p
@V(CB) (V) (Test Condition)=10
@Freq. (Hz) (Test Condition)=1.0M
Package=TO-202AC
Military=N
3DA87D BD410 BF381 BF382 BF461 MPSU10 MJE344
2n4929 -> 2n2216
Medium Power, High Voltage, General Purpo, 2N4929, Silicon, PNP, 1W, 150V, 150V, 4V, 500mA, 200°C, 100MHz, 10,
25/200, MOT, TO5
2N2216 2N3413 2N3634 2N3743 2SA1573 2SA698 2SA781 2SA793 2SA922S 2SB736 BC303
BC303-4 BC303-5 BC303-6 BC304-4 BC345 BC396 BC461 BC640 BFR23 BFR79TO5 BFS93
BFS98K BFT19 BFT37 BFT37A BFT44 BSV11 BSV17 BSV17-10 BSV17-16 BSV17-6
BSW40 GES4929 KT3108A KT313A KT505A KT639E RCA1A02 2N3636..37 2SB606 BFT44
BFT45 2N3634 2SA698 BFT44 KT505A
NSD128 -> MJE350 (?)
Si NPN Power HF BJT
National Semiconductor
V(BR)CEO (V)=180
V(BR)CBO (V)=180
I(C) Abs.(A) Collector Current=250m
Absolute Max. Power Diss. (W)=1.7
I(CBO) Max. (A)=50n
h(FE) Min. Static Current Gain=50
h(FE) Max. Current gain.=500
@I(C) (A) (Test Condition)=10m
@V(CE) (V) (Test Condition)=5.0
f(T) Min. (Hz) Transition Freq=100M
Status=Discontinued
Package=TO-202AA
Military=N
2n4125 -> BC558 / 2n2907A
Low Power, General Purpose, 2N4125, Silicon, PNP, 310mW, 30V, 30V, 4V, 200mA, 135>C, 200MHz, 5, 50/150, F, TO92-2
242760 2N2906 2N2906(A) 2N2907 2N2907(A) 2N2907/A 2N3209 2N3903 2N3905 2N3906 2N4126
2N5139 2N5141 2N869 2N869(A) 2N995(A) 2SA1055 2SA709 2SA741(N) 3CK3F A5T4125 BC205
BC213 BC252 BC308 BC350A BC513 BC558 BFV81A,B BFV82(A...C) BSW24 BSY40 BSY41 GET2221
KT3107A KT361B LY2894 MPS4123 MPS4124 MPS4125 MPS4126 MPS6517 XGFP2894
2n4250A -> BC206
Low Power, Low Noise, General Purpose, 2N4250A, Silicon, PNP, 200mW, 60V, 60V, 5V, 100mA, 125°C, 100MHz, 6, 250MIN,
F, TO106-1
2N4248 2SA1049 2SA1136 2SA1137 2SA970 BC206 KT361K
2n3859A -> BC546
FRH
Various
FRH, 2N3859A, Silicon, NPN, 360mW, Vcb 60V, Vce 60V, Veb 6V, 100mA, 125°C, 90MHz, 10, HFE 100MIN, GEN, TO98-1
2N2926-1 2N3793 2N3794 2N4256 2N4409 2N5209 2SC1815 2SC1815-BL 2SC1815-GR 2SC1815L-B
2SC1815L-G 2SC1815L-O 2SC1815L-Y 2SC1815-O 2SC1815-Y 2SC2109 2SC2111
2SC4444 2SC4446 2SC4449 2SC4485 2SC689 2SD474 2SD474K 2SD591 2SD592 2SD592A 2SD592ANC 2SD592NC
2SD599 2SD601A 2SD602 2SD602A 2SD603 2SD636 2SD637 2SD638 2SD639 2SD655 2SD661 2SD671 2SD734
2SD754 2SD767 2SD769 2SD770 2SD771 2SD778 2SD779 2SD786 3DG121B BC168 BC169 BC174 BC182
BC182B BC182L BC184 BC190 BC337 BC546 BC637 BC682L BC817 BC846 BCW98 BCW98A BCW98B
BCW98C BCW98D BCW99 BCW99A BCW99B BCW99C BF299 KT3102A KT3102B KT3117A KT3130V KT315E
MPSA93 -> MPSA92
Si PNP Power BJT
Zetex Semiconductors
V(BR)CEO (V)=200
V(BR)CBO (V)=200
I(CBO) Max. (A)=250n
h(FE) Min. Static Current Gain=30
h(FE) Max. Current gain.=150
@I(C) (A) (Test Condition)=30m
Package=Chip
Military=N
2N5401 2SA860 BF423A BF491 BF492 BF493 BFP23 BFP26 ECG288 MPSA92 SO693 2N5415 2N6432
2SA840 2SA860 3CK02 BF435 BSS74(S)
original specs
other options
Si NPN Power BJT
Various
V(BR)CEO (V)=180
V(BR)CBO (V)=250
I(CBO) Max. (A)=10u
Package=TO-202AC
Military=N
2n4929 -> 2n2216
25/200, MOT, TO5
Si NPN Power HF BJT
V(BR)CEO (V)=180
V(BR)CBO (V)=180
I(CBO) Max. (A)=50n
Status=Discontinued
Package=TO-202AA
Military=N
2n4250A -> BC206
F, TO106-1
2n3859A -> BC546
FRH
Various
MPSA93 -> MPSA92
Si PNP Power BJT
V(BR)CEO (V)=200
V(BR)CBO (V)=200
Package=Chip
Military=N
i think anyone who would want to repair this will need it on the bench in front of them and start from basics, ie remove all the transistors and check them, along with most if not all the rest of the componants
so many questions so little time!
the red wire to o/p board is the pos, the blue was still connected (neg) hence half an output signal!
the 4 pots are dc input and output offset NOT bias. / bias is set be the resistor on the board that pushes into the two metal pcb stand offs.
d40p3 = d40v2
check ALL small signal transistors esp the 2961 and 2n4125. (all of them!)
like said above by other people you need to be checking components not doing wierd things with the amp, otherwise it will go DC BIG! BIG! time!!!!!!!!!!!
d40p3 = d40v2
d40p3 = d40v2
i realized the first point very quickly after the first blown transistor.. i never work late on this amp anymore 😉
i've desoldered all transistors, found 3 blown ones. 2x 4125, 1x bc639 (replacement voor the 3859a).
also found a dead small-signal diode and a keramic missing one leg
replaced most transistors now, i'm trying to get a big variac before firing it up again.
Just put a 60W light bulb in series with the Mains AC. This should give you time to do some "live" measurements without the amp goes intoi'm trying to get a big variac before firing it up again
Just put a 60W light bulb in series with the Mains AC. This should give you time to do some "live" measurements without the amp goes into![]()
yeah, i used that trick, but that didn't help enough to give me time to measure, nor protected the poor pre-drivers
i gotta be patient, get the variac, pop in some new transistors and then
I guess you noticed this but just incase you didnt early / late 2961 / 3859 often have different pin outs depending on manufacturer.
i use the inscription on the transistor (crown printed those on the transistor) and the board layout wich has the pinout clearly drawn. if anyone has better replacements then i've found, let me know.
i now plan to use MJE340 for the D40P3 and MJE350 for the 2n4929. the last one is overkill, but suitable, i thought.
both the NSD128 are fine, so no worries about them.
i plan to use the BC557 for the 2n4125, the BC546 or BC639 for the 2n3859A and the BC556 for the 2n4250A. if those bring the amp back to life, i will search for better replacements, but i have those in abundant quantities 😉
does anyone see a problem here?
anybody? some problem with those transistor replacements?
I have not used any of the ones you mention as replacements, so im unable to comment....sorry...and good luck
that's ok. i've collected a big list, and i don't have restrictions to use the ones i've selected. so if you do know replacements that from experience work, let me know.
replaced most transistors now...
What about the 'keramic' and a diode? IMHO, your amp is oscillating strongly (simply check it with oscilloscope), and destroyed ceramic can be the reason for it... 🙄 These small caps are 90% of whole design effort. They determine mainly, how the amp is sounding, and determine whether the amp will work at all or simply produce clicks and pops with DC 😀
the ceramic certainly was the cause of oscillation, but now the pre-drivers are blown (thanks to me being stupid) i can do nothing at all and i'd like to know if my transistor replacements ar suitable or if there are better ones before continuing and blowing the entire outputstage.
i have bought a variac btw.
- help with repair of DC300A series II
