Nope
Its like they say, "they just aint doing it right 🙄
Its like I said, you need to learn how to make the flaws of a xover work in your favour, and dont try to make it do something it cannot
Dont blame the xover or drivers if it doesnt work
When I originally engineered my 3 way Helios I placed the midrange above the tweeter and woofer below it, then I played with crossover slopes until my on axis frequency response was fairly flat, while the null between midrange and woofer at the projected "suckout" point was tilted toward the floor. It worked out. Normally I would have a floor bounce related cancellation at 400-500Hz at listening position, but having a 500Hz null pointed at the floor, mitigated it to a degree- at least in simulations.
So, unusual placement of drivers can be part of design.
Althou in far too many cases the cure is worse than the illness....
Ok, "in far too many cases", I will give you that credit 😉
Funny that one of your best is a 2way with a standard active filter...Im just joking Dave 😛
Well, Im actually grown up with fullrange and horns, and know what to expect
You may not remember, but I was the first here to point at the cute little FF85, and asked why noone was interested in that driver
But fact is, you have realised that these little fellows sound better in many ways
Only, they are mostly cone tweeters with low Fs
So, you still need a woofer, and make 2way, or learn to live without bass
And maybe even use flawed electronics to make it work
Dave, Im still joking 😉
Right, I have heard some pretty awful speakers, be it systems with a fullrange driver as well as multiways
In either case, its equally important to know a lot about how to do it
No my friends, a "fullrange" 300-20khz planar, that rocks
Same thing, only way better
And its a 2way, and have all the advantages that comes with a 2way
Indeed... XO evils were minimized by making it low level with no active components, a quite low XO point, simple, careful driver placement and toe in.
dave
bringing Dynaudio up should be made against forum rules.
they need to rename their company to douchebag technology.
the most infuriating thing about their gimmicks is that they balance them out with just enough real science to effectively obscure what they are.
Now when did Dynaudio take leak on you?
dave
Hmm, sure if it makes you feel better that way, no problem 😉
Simply means to me that you have found your way of making it work, which is all its about really
Others have found theirs, if they are lucky
Doesnt generally mean one way is better that the other
I suppose we could have the very same discussion about amp feedback, tubes, SS amps, classA AB B D etc
We all know that if it doesnt work theres only one to blame
Yep, audio gear still has a Looonnnggg ways to go/improve, lots of valid ways of making something that connects you emotionly to the music.
dave
dave
Maybe offsetting the tweeter to one side so it is not directly above the woofer woud help more than inverting the tweeter / woofer configuration.
re:'crossover has nothing to do with tweeter being on top of the woofer" - au contraire, it has everything to do with the crossover, and how it is used to acheive phase alignment
Back in the days of grill cloths, we could flip them around to which ever way sounded the best. I ran my Dittons on the floor up-side down. When we ran bookshelf speakers on bookshelves, often the tweeter was to the side.
Yes, this not QSC but something that hade been known for a couple thousand years. The Romans understood it when they built their arenas'. Nothing to do with tweeter location of course.QSC say you can increase bass output by putting a bass speaker on the floor or in a corner.
My 10F/RS225 FAST are upside down (tweeter below woofer) and it gives perfect time alignment for transient perfect XO. The chest punch of audio is more substantial with the woofer at ear level. It sounds natural and the percussion is very clear and sharp.
https://www.diyaudio.com/community/threads/10f-8424-rs225-8-fast-waw-ref-monitor.273524/
here is the measured step response:
I was going to say that speaker looks more marketing then sound science.bringing Dynaudio up should be made against forum rules.
Do you have an equalizer? What you are describing could likely be fixed with an EQ.Thanks. I am very close to these speakers almost texas headphone orientation when I started to hear the null. In theory my setup should be somewhat phase linear through the crossover region - at least before it hits the drivers. I am using a phase offset to correct the LR2 and it's phase distortions on these monitors. I may have just not had them up high enough but I really didn't want to redo my entire setup so I sat low - the woofer was in the exact same place.
So could it be that the vertical lobe was reflecting on the floor or something causing a null? Or is it just the characteristics of these drivers?
- Why is the tweeter above the midrange/ woofer?
