The design is pretty straight forward and if you are in doubt you should consult the datasheet and the AN-1192 and compare.Some Flaws in PCB Design?
Suitable transformer voltage is 2 x 24 VAC.
The mute resistor mute be chosen with the power supply voltage in mind (can be found in the datasheet) and if you have 24 VAC 33 kohms is max according to me but this is rather obvious. You will notice if the resistor is OK or not.
Thank you so much
i am going to print the layout on photo paper.
Thank u so much. now only one important question about the power supply. How much ampere the step down transformer shoult be to use 6 lm3886 at full power for 5.1 channel system
Well, 6 LMs at 50W output means a total output power of 300W. Your transformer should be double, so 500-600VA 2x22V will do the job.
ok. But here in ma country Main voltages are as follows 220 volt 50 Hz
So plz calculate again that i need 600va or 1200va may be you use 110 volt.
buy the correct voltage rating for your supply.
a 5.1 will not send maximum signal to all channels simultaneously.
I have suggested that the first two channels should have a full transformer VA allowance. All the remaining channels should still perform well if they have a half VA allowance.
2*50W + 4*25W = equivalent 200W
Select a transformer from 200VA to 400VA to power a 50W * 6 channels %.1 system. If your speakers are 8ohm I suggest you fit at least +-40mF as smoothing capacitance. Double this if your speakers are 4ohm.
Hello everyone!
I'm totally newbie and I don't want to spam in forum with dummy topics, so I decided to use this topic as my question is also about lm3886 pcb.
I want to make a chipamp. I tried to choose version what I want and seems the best one is Mauro Penasa rev. C. But I'm not familiar with PCB creation and that's the problem.
I tried to find a KIT but seems all are without LM318.
As solution I found something similar on ebay:
Classic-lines-LM3886-dual-channel-AMP-PCB-DIY
Can anybody check out pictures and comment is it good one?
Or better take some other:
LM3886-Amplification-Kit-Filter-eliminator-supply-DIY
or
LM3886-High-End-Power-Amp-Refer-Gaincard-New
As we see amp layouts are different for last two - which one is better.
Thanks, and waiting for some response.
or
First link should be this:
Please check this one for first specified link
Also images from links:
1.
2.
3.
1.
2.
3.
Here is LM3886 PCB Plz Check that all the components are ok and it is ready or not? If not make it final for all.![]()
I hav noticed after purchising my 2 lm3886 ic that the pins of ICs are much closer than that one in pcb layout. Ic cant fit on this pcb. now i am trying to draw this layout with permanent black marker on copper sheet with customise pins.
Hello ieris;
I definitely held at a distance from these products. I have doubts about the quality of these products.
A better but only slightly more expensive option is to built your own PCB (or P2P or get only PCB without parts or use sample board) and to order parts from local well - known supplier.
The LM3886 is a high performance 150W Audio Power Amplifier with Mute. The performance of the audio power LM3886, say NS, utilising its Self Peak Instantaneous Temperature protection circuitry, puts in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area.
Hello ieris;
Hi!
Thank you for your answer! Of course we don't know is there original and qualitative parts used, but seems this case is quite well.
And it's not so cheap (but cheaper than I get parts in local country). And it's understandable because for local supplier I see that price is more than half buying 50+ pieces.
Can you suggest where I can get some version PCB w/o parts?
from cloud cuckoo land!The LM3886 is a high performance 150W Audio Power Amplifier with Mute. The performance of the audio power LM3886, say NS, utilising its Self Peak Instantaneous Temperature protection circuitry, puts in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area.
- Chip Amps
- Lm3886 pcb
