HI... in attachment a simple signal generator schematic based on MAX038 (available also as free sample from Maxim).
I found the schematic on the web but I substituted the output buffer IC with something more simple to find (LF357 instead of EL2001 wich is hard to find for me).
Note: Fine - Coarse - Level are 1K Lin Pot
Hope you'll find this usefull.... I had no time to make a board, but if someone want to help me, I will post schematic in eagle (.sch) format.
You may be interested in a fuction generator kit that I'm selling:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=70138
It's based on the Exar XR2206 chip. All parts are included except for a chassis.
Ron
Ron
The Analog Devices SSM-2135 would be a good choice for the output buffer. It has lots of guts. I used it to make a headphone amp for my AKG 240 cans.
If you need more drive than that, run a series resistor of about 100 ohms, from the output of the buffer. Then, put a complementary pair of transistors on the output. Simply connect the bases of the transistors to the output pin of the chip and , connect the emitters on the other side of the resistor. The collectors go to their respective supply rails.
You can use 2N3904/3906 pair or, for more heft, 2n2905/3019.
I need a signal generator circuit of 5GHz.
Five GIGAHertz??? At those sorts of frequencies all kinds of weird things happen, 'normal' circuit boards and components don't work. It's a topic of study all on its own, the area of magicians and RF experts.
