A30, AP1.7, F4, F5, F2, B1, Jfet BOZ
F3 and AJ (3rd attempt) in the works but new baby (#2) has temporarily displaced my DIY insanity. No interest in building F1
I stocked up on parts and was going to take 'The Pligrimage of Zen' - build all the zen variations from the beginning (or almost all)
I'll say it again because it cannot be said enough
Thank you Nelson Pass for sharing with the DIY community
A75 Pass/Thagard in '93.
Zen-Uno, while i was assembling the A100 Thagard/Pass in '95.
The light gets pretty dimm after that, could be the booz.
Ha.....and the ladies?
Joined 2002
ive built a few, a f5 f4 mini a's smd and normal part style, a few pass labs pre-amps and a zen.
Pics
Pics
Joined 2002
Joined 2002
And I spy a Helimax axe.
Yeah i gave it away, then bought 15,000$ in other helis LOL!!
hello
Bosoz or UGS + aleph X + monitor
le bosoz
aleph X -1
alambic1
Zen V9 + de250
Aleph 5 + altec 420a
ZEN v9
l'aleph 51
Altec 420A en baffle plan
in french, sorry !
Phill
le bosoz
aleph X -1
alambic1
Zen V9 + de250
ZEN v9
l'aleph 51
in french, sorry !
Phill
OK,
Aleph 5
Aleph 30 monos
AX-100 monos, modified later to J-Fet input
BOSOZ, X-BOZOS, CCS-Cascoded X-BOSOZ
CD output stage based on BOSOZ
Aleph ONO
B1 parts are in a box waiting
Lovoltechs in another box are waiting to become an F3
Used with Thiel CS6, Dynaudio Audience 42,
Jordan the Wall and a pair of ZU Druids MK IV
William
Aleph 5
Aleph 30 monos
Aleph ONO
William
I built the F2. It's great! Not many others have mentioned it for some reason. 5 watts is plenty.
Yes... Plenty if you have horns, or else like your music moderately loud. I like louder than that, and have horns that let me enjoy low wattage class A in concert fashion. Just braggin'...
Yeah, the OP did ask about speakers.. and bet you couldn't guess. .. Fostex full rangers.
-with 2 subs in opposite corners of the room
Which Fostex driver are you using? What's your impression? Are they good sounding?
the ff165k. And actually, it's the bk-16 speaker kit. So, also has the fostex t90a tweeter to fill in the very top end.
So, while most of us for some reason still call these full rangers... Im technically 3way. Just the cross over is super high for the tweeter, and super low for the subs.\
It sounds great! It's my first set of speakers that didn't come from a big electronics store, and they easily beat all of the commercial speakers I've had.
and, I don't really cross anything over. The ff165 gets the full signal, the lows are lowpassed, highs highpassed.
Joined 2002
Well, i got the ich a few day's ago and well i fired up one of my stereo aleph mini's the ( smd version ) and what was a i missing SO MUCH detail.
Running one stereo aleph at the moment whyle i fix the other so i can bi-amp again.
Running a opa627 with all black gate caps as my pre-amp.
Was having problems with a passive volume pot, when i got the to middle there was no difference between 10-2 but after about 3 more bass arrived so i removed it for now then went back to my opa627 pre-amp.
Have a few mods to do but soon.
Joined 2002
Thanks for the posts everybody. Now i can needle those of you that have built the amps I'm in interested in.
Good idea
TO help the needling, you might want to think about a few things ?
A budget how much you want to spend, because you can buy some pretty NICe parts, or you can buy parts to just get your amplifier going then change out things.
B research your parts, ie heat sinks transistors boards etc etc.
C how many watts you want need, what your design goals are.
D How many amps you want.
E, what type or kind of pre-amp you have.
F what type of music you listen to.
So many variable's
Was the D1 based Dac ever shared by NP?
The schematic was posted to the Pass website at one point. The schematic was for the rev. 1 boards and carried a bright red disclaimer - "this is not intended as a project and will not be supported as such. do not call us."
I've built Spencers D1V3 which is very loosely based on the D1.
Also ONO, P1.7 (veteran boards and dantimax volume control) and Aleph 30 monoblocs built on BrianGT's boards.
cheers
Paul
- What Pass designs have you built?
