I manage to mix things up due to copy and paste
X2, GND +OUT
X3, -OUT GND
You just follow the schematic because this is correct. My text in the pcb is handwritten, not in the footprint.
X2, GND +OUT
X3, -OUT GND
I have 12 PA150 boards left, hurry to book those. I'll guess the market for more PA150 may be saturated but if there is some interest in 2010 I might consider a forth round.
Not quite saturated. I'd be interested in buying four of the PA150 boards. From looking at the group buy thread, this looks to be 335 SEK (SEK being swedish kronors?) including shipping. Are four boards still available?
Also, just for clarification:
PA150's can be run separately, i.e. 2xPA150 + 0xDRV134 is good for 150 Watts stereo?
Lastly, are dimensions (board size and mounting hole locations) available?
I have 8 boards left so hurry up if you want these boards.
Two boards plus a DRV134 forms a bridge connected amplifier, one channel. You can also use a single PA150 and then you will have three LM3886 in parallel.
PA150: 121 x 80 mm, The LM3886 is 1.2" between them, centered on the board
UBC01: 76 x 64 mm
If you are interested you can see at the my wiki page how much different configurations cost including shipping.
UBC01: 76 x 64 mm
UBC01: 76 x 64 mm
I have signed up on the wiki. I have Paypal ready once I receive the invoice. Thanks a lot for handling the group buy. About the dimensions, I was wondering where the holes were located, i.e. how far apart must my standoffs be in order to mount the board.
The user exurbia gave me an adress which he doens't live at and the letter came in return so 6 boards may be available if exurbia doesn't come back to me.
6 boards = 3 channels.........arg....need at least 9 channels = 18 boards...but i'am in for those 6.
Hmm have already sign up at your page, but not able to make changes to the list. Username peterolsen.
Pete
Pete
Peter, you have signed up for 18 PA150 and only 9 SMD-kits. Is that correct? One kit is for one pcb.
Arg hornmusik.....selvfølgelig skal jeg også have 18 stk. SMD kit's......will you, or shall I change it 🙂
thx
Pete
thx
Pete
- Group Buys
- Group Buy: DRV134 pcb, unbalanced to balanced
