Marantz CD5000 - display very dull - help?
I'll look in again tommorow. Check that cap. Pin 66 seems to be clamped by an internal "zener" at -18 volts. Sometimes quoted voltages like that are not always correct in service manuals, they should be but aren't. 10 volts dropped across R3847 (100 ohm) sounds a bit high, is it a 1 watt resistor or more ?
If you are careful you could try varying pin 66 voltage but see what you find first with the caps.
I've changed the 220u cap and that seems to have done the trick.
Many thanks for your help!
Tony.
Tony.
Hi Tony,
I have the same dull display on a CD5000 that I just acquired. I'll have a look at this cap and see if it fixes mine.
I noticed you showed some relevant schematics on an earlier post, you don't have other schematics for this machine available do you? I'm planning to make some modifications in the DAC area and it would be useful to have the full schematics or service manual.
Pete
I also have a Marantz CD5000 that i bought with some modifications in mind.
What modifications are you planning? I'm going to keep mine fairly simple to start with.
Upgrade 4 diodes on the +5v supply to schottkys.
Larger cap (8200uF) on the +5v pre reg.
Seperate 317 regs for the 3 DAC +5v feeds
Upgrade the caps around the dac feeds
Take the dac output direct to RCAs (bypass the seperate opamp)
Then I'll have a listen and see if it's worthwhile doing anything else
Pete
Maybe not entirely appropriate in this thread but I find tube displays often to be very dirty between the actual display and glass/screen. Separating the PCB from the frontcover and careful cleaning is often a remedy providing that the electronics are OK.
I recently bought a mint Kenwood DP-5050 that did not have a scratch but the display was unreadable from dust/debri buildup on the display itself and on the backside of the front cover screen. Sometimes it is necessary to use isopropyl alcohol to remove the stuff.
Use a soft cloth !
Made the changes outlined above, the players strting to sing a bit now. Quite a nice, detailed sound for fairly small cost.
On the downside, replacing the cap didn't help with the display brightness. I rempoved the display to clean the glass on both sides. Something went wrong so now I have no display at all. As I couldn't see it before from more than a foot away it's not a big loss and it's still playing ok.
The odd thing with this player is that that the on-off switch on the front of the player only seems to work on the display pcb. The tx, loader and audio pcb seem to be permanently powered.
Pete
...On the downside, replacing the cap didn't help with the display brightness.....
In my case it didn't solve the problem either. My initial thoughts were that it had - but after reassembling it, I realised that although it was ever so slightly better, it still wasn't at maximum brightness. So I'm guessing the VFD is well and truly knackered.
I had this great plan of trying to interface some other display to the electronics, but I just don't have the time (and I don't think it's worth the effort!).
So I have a nice gold CD5000 with a dull display.. (and now it's resident on a shelf..)
Tony.
Pete
It is not so technical that "something went wrong" without knowing what. Just find out what went wrong. It can't be a very serious problem if you acted carefully. My guess is that one of the pins of the display has a dry or broken joint. So resoldering the display could be a solution.
Regarding the player being powered continuously: this happens a lot since companies found out that real mains switches cost more than push buttons. Bad for the VFD, bad for the power bill ( if you add up all gear that can't be switched off ), bad for the environment ...
Yes, when I have some quiet time I have to get the meter out and do some further analysis. At the moment it's not a priority as it's still playing and honestly, if I only restore the display to it's previous brightness it's pretty much useless anyway. I'm hopeful that some component that was suffering (and causing the lack of brighness) finally gave up the ghost 🙂
Pete
This is the page that influenced me on buying this player. I wanna try the changes he suggests. Not only tube output stage but also with transformers. I'm just curious, I have zero experience with DIY electronics, so i thought it will be better to start with something cheap 🙂
That was the page that convinced me to but one as well but I doubt I'll go down the tube route, just the snip-it.
Incidentally, how is the display on yours, can you see it from more than a meter away? Interested to know if this poor display is really a fault or standard with this model.
Pete
Yes, I can see it from more than 1 meter away, but compared to the display of a creek evo or a supermarket dvd player is dull. In fact I remember the first time i powered it on, this was the first thing that striked me.
Here is a picture, maybe it helps.
Got the display working again, fault was with a transistor (7250) providing power to the contoller chip in the display pcb.
Still very dim though. The supply to the dot matrix seems to be 5v ac which is stepped down though a couple or resistors to about 3.7v ac. I bridged one of the resistors to bump the voltage up a bit but it didn't have any effect on the brightness. I'm coming to the conclusion that this isn't an error, just lousy displays on these players.
Pete
If it's the same as the circuit at the start of this thread then the negative 28 volts determines the "brightness" to a large extent, but make sure the zener and the two resistors that ties the heaters to this supply is OK.
If all the voltages are OK... and you have to be very sure and use a scope to see no excessive ripple is present etc then the display is faulty. The DC relationship between all the supplies is critical, particularly the heater.
