Hi.
I have found my old Philips CD104 in my basement which is in perfect condition. After reading several threads about quality of the CDM1 drive I was thinking about moding it for use as a CD Transport only.
I have tried to search for solutions but never found anyone actually being succesfull in implementing an S/PDIF interface.
Looking forward to hear from you.
Best Regards
Cavok
Best Regards
Cavok
I've also been watching that collective dream for several years. Everybody wants SPDIF from the SAA7011, and so far no-one seems to have got it.
How about modifying this player with another clock and with a NOS DAC within the case (I2S connection)?
There is no I2S inside, that's the whole "problem" with connecting another dac or an spdif chip. As it seems, nobody with the right skills has been bothered yet to make it. But this is a diy forum, if you want it, build it yourself. Or at least start trying.
As for connecting another dac, it's possible to connect a 1541 before the df. Not with I2S though.
So the solution for you seems to get a cdm304 mk2. Which is cdm1 with the newer chipset iirc.
I'm wondering if/why you can't patch an SAA7210 onto the RF signal and thence an SAA 7220 filter which has an SPDIF output.
Maybe, but then don't use the 7220 to create SPDIF. There are better ways.
Hi guido,
What would be a better way?...don't use the 7220 to create SPDIF. There are better ways.
In this case there is this thread:Hi.
Best Regards
Cavok
http://www.diyaudio.com/forums/digital-source/67469-spdif-output-saa7020-saa7000.html
Hi guido,
CS8402,8404,8406, or philips or TI makes transmitters.
Forget those three. They just make things more difficult.
Hi rfbrw,
Probably because of clock matching?
CD104 works with 4.2336 MHz crystal oscillator (96xFs). CS84xx wait for 128xFs, 256xFs, 384xFs or 512xFs (5.6MHz, 11.2896MHz, 16.9344MHz...) clock frequency.
Or is there any other reasons?
Forget those three. (CS8402,8404,8406) They just make things more difficult.
Hi rfbrw,
So? 16.9344 divided by four is 4.2336, not so difficult. As for those CS chips, i don't know them too well. But would a philips (even 7220) or TI chip be any better?
I'm planning something with a CS8416 (receiver), let's see how that goes...
- Digital Source
- Working S/PDIF interface on Philips CD104 ?
