Single Ended Pentode Spud and Feedback
Usually, at least in guitar world, in a single ended pentode amp, the feedback return is to the cathode of the driver. But, in the case of a spud amp, where there is no driver, any suggestions on how to add some feedback? Any ideas?
If you have just the one stage, then there's just one choice: Anode Follower.
I'm having trouble picturing how this will work -- am I just taking one side of the secondary and connecting it to the grid through a resistor? Or just take right from the plate ... presumably through a cap?
What tube?
12HG7 to start with. With a 5K:32 OPT for headphone use.
Disabled Account
Joined 2006
You can ground the cathode resistor through the second coil or part of it. Add a cathode capacitor to increase the gain of the stage as well.
Mind the direction of the coil.
I think that I have seen that done, but I can not remember where.
If you have not purchased the transformer yet then you could specify one specifically for cathode winding feedback. Tim de Paravicini did that in his EAR HP4 headphone amp.
OK, then the $100 question -- any hints on how to calculate these feedback resistors.
This way is allmost impossible practically. The set of R-s are wery hard to select due to numerous contradictory requirements. If you stick on this way, take the signal from the plate (trough a C) for far easier matching (high-Ohm Rfb2).
I attached a possible schematic below to see if this is what you mean. Any C and R suggestions there?
Also on the schematic. Is this what you have in mind?
I made a SE EL84 amp a while back grounding the cathode through the secondary. http://www.diyaudio.com/forums/showthread.php?t=121767&highlight=jerluwoo The problem in doing that way makes it basically a unity gain stage that will require a driver.
1.Not easy task! Ex. Rfb2=1M, Rfb1=22k, C=100n. The feedback will depend on the position of the pot.
That's probably not good ...
Right. It's 100% feedback. You need a coil's tap to lower it.
100% feedback is fine as phones rarely need any more than a buffer. The problem, however, is that the secondary winding DCR is ~6 ohms. With 20mA of current through the tube, that puts 120mV of DC on the headphones, which is way too much. What if only the Rk bypass cap goes to the secondary with the resistor going straight to ground?
Why not triodestrapping w/o NFB instead? You´ll still get 1W instead of pentode 2,5W with Ia=40mA.
