It is John's circuit and at least it is polite to ask him for permission.
Ah, sorry. I thought you are going to discuss JFET-based cascoded complementary input stage that I wanted to draw on a napkin. However, John's version should be thoroughly calculated and adjusted for the best possibility of all parameters.
new thread
That will certainly help, though much depends on who's name is associated with the title and the content.
A good example is this thread: http://www.diyaudio.com/forums/showthread.php?p=1109233
I think that a new thread probably would have less chance of controversy if there is no name associated with the title.
Isn't it John's responsibility to drop that schematic? And if he refuses (or can't) to do so, he shouldn't touch this subject at all and waste our time.
Look at this post, and in two posts later from courage (i.e. without cascoding the JFets to protect them from too high voltages and/or power dissipation)
http://www.diyaudio.com/forums/showthread.php?p=873606
Ciao, Tino
Ciao, Tino
I can put here the "BT-Like" circuit, but need your permissison, as well as estimation if it should be blind or with component values.
Well if we are to discuss that circuit, it would be easier if we actually had a schematic I think. With values.
jd
Come on PMA, this circuit is as common as rice in a paddy. Jeez.
jd
No, I'm not joking, I really support Syn08's idea, and am ready to contribute to the thread as soon as he starts it.
I think a new sticky thread like "Solid State Design Principles" should be started by a moderator.I will certainly contribute, time permitting.
This thread has to die, its a waste of time, database space and electrons/holes required to post. JC would be of course welcomed in the new thread, but shouldn't expect any special treatment.
attachment in post1447 will not expand.
is this a Forum problem or my problem or Janneman's problem?
I did copy it from the original post, and for me it doesn't expand either. It is better to use the link provided by Zinsula:
jd
Syn08, nobody wants for you to contribute in this thread, if you do not like it. You can fully display your views in the new thread as you are recommending.
Yes indeed. Nobody needs JC's authorization to start a new thread on any subject. If it is interesting enough, posters will flock to it. Those who find this thread interesting (or exciting ) will continue to contribute here.
jd
PMA, why don't you put your version of BT like schematic, up? What I was hoping for is a comparison of the folded cascode vs the non-folded cascode (2 stage) 4 quadrant topology in a relatively simple form to discuss how to make each one better. I think that it might be refreshing to have some engineering discussed relative to these topologies.
It is the heart of the CTC Blowtorch, vs the non-cascode being the heart of the JC-80 preamp that somebody is making some circuit boards for, somewhere. Or the double cascode 2 stage 4 quadrant, topology that is the heart of the Parasound JC-2, can be compared to the CTC 4 quadrant folded cascode.
Then the only criticisms will be of the circuits related to the same designer, not others who might not want a comparison made on this thread.
Of course, I invite your improvements, as well as Charles Hansen's (of Ayre) as you both have extensive design experience with this set of topologies.
It would be refreshing to get back to the Blowtorch and its relatives.
Thanks for pointing this out.
This thread is technically useless to anybody but snake oil merchands, looking for ways to promote their crap, and people looking for cheap entertainment (including myself).
One alternative to a new thread is to drop by occasionally and trash, within the moderation limits, all the technical ** for the benefit of the sane people, looking to get something useful out of this mess. Based on the reactions that I usually get, I guess I'm pretty good at that.
Thread 678 looks very good. It is simple enough to analyze and talk about. I presume that is in part 1 of the Blowtorch thread.
Zinzula, if you send me (jan at linearaudio dot nl) the original I'll put it up on my website for download. (Actually it is the attachement of post 677 in the BT part 1 thread)
Actually the best simplified schematic that I have seen so far, was put up by Courage, years ago, as #678. While some of the resistor values need optimization, it is a very clean simplified schematic.
John, this again will lead nowhere. I know, in a few postst you will again complain that people don't follow your advice and go off topic, but its predictable.
IF you are interested in discussing a circuit, pick one and stick to it. We'll help to put it up.
But if you keep wandering around, how can WE keep OT??
jd
- Member Areas
- The Lounge
