It looks like is has one channel ? Can you make a photo from underneath ?
These are my own build tube project from scratch ( except the diagrams 😉 )
On the left an old Dual turntable, in the middle the "Phonodude" by Triodedick.com PreAmp and in the far right the Bruce Bender 6N1P Headphone amp.
My and my friend's project 6C33C & 6E5P
http://picasaweb.google.bg/azazello52/Amplifiers#5379198640803460258
6550s 6.6k ct 60 waty output transformer
similar to pete millet driver but uses 6cg7 and an altronics m0706 transformer at the inpput filtered dc on the heaters of the 6cg7
Accidently saw a downloaded schematic fron Italy of a Triodino II, an ultrasimple SET, 4W/channel using just two tubes (three if used with rectifier tube).
Had the transformers; Danburys DB1090 for OP-trannies and a Welter Electronic (DE) N3/1 for mains X-former. I also had a Hammond chassis that I had drilled for a tube X-over, but now had to "redesign" for the Triodino. It got rolled twice with green Hammerite.
Found the 5998A somewhere (labelled IBM - good for digital sound
Some comments on the design: I installed an iPod dock so I could use it w/o players (except for the tiny iPod), the IP-connectors are mounted close to the front to minimize hum pick-up. That's why the mains switch is mounted on the back. And I finally got use for my LEDed knob.
It's a really good sounding amp, perfect for my horn speakers with fullrangers from Hungary (www.sonido.hu).
Wow, very, very nice. Can you describe the chassis construction? Is the top bead blasted machined aluminum?
Very nice! I like the copper.
- Tubes / Valves
- Photo Gallery
