Krill - The Next Generation
I would like to start this thread off by looking at three different biasing methods. The first is class B, followed by class A and finally my method which has come to be known as the Krill. I will be looking at the voltage across one of the emitter resistors to determine if that transistor is conducting or not. I will be doing this over a number of posts to keep the size of any one post reasonable.
I don’t expect to change certain minds with this, but those of you that believed me earlier may find it interesting. As many of you know, I can no longer run tests in the physical realm, so this has all been done in simulation. Remember, this is only a simulation. Your reality may vary.
First up is the Douglass Self “Blameless” class B amp. The schematic I used is from here:
http://www.dself.dsl.pipex.com/ampins/dipa/dipa.htm
All simulations were run at 1 kHz.
This is at two watts output. No surprises here, the output transistor cuts off.
Next up is the same amp biased into class A at 1.77A per output or 131W dissipation at idle. I used the 37V supplies shown on his schematic. The output is 50W into 8 ohms. As you can see, the transistor is still conducting with 146UV across the 0R1 emitter resistor. This is 1.46ma of current which is safely above the 5UA (max) emitter or collector current specified for the output transistors I use. I did not check this specification on the transistors he uses.
And now, the Krill. This is at 50 watts into 8 ohms. You will notice that this amp is of the inverting persuasion. There is no reason for this other than this was what I was working on at the time I decided to do this. I used 0R22 emitter resistors and 34V supplies. I should also state that this amp uses 4 pair of output transistors. Again, it is what I was working on. This is at 129ma bias current for a dissipation at idle of 35.1W of dissipation. The bias was set for minimum distortion at 50W output into 8 ohms at 1 KHz. The wave form flattens on bottom, but you can see that there is still almost 96UV across the emitter resistor. To me, this says the transistor is still on.
So what happens when I switch the load to 4 ohms? There is still 2UV across the emitter resistor. Does this mean the transistor has switched off or not? That is still 9UA of current which is above the 5UA cut off value. How on does a transistor need to be to be on?
Hi Steve,
I thought we finally all agreed what was going on at the end of that big brouhaha? Here's my quick version.
1) On a given half-cycle of the load current, one driver transistor turns off completely, and very fast (due to the capacitor between the driver bases).
2) This leads to a reverse-biased Vbe of that driver, which, because there's no resistor connecting the driver emitters together, leads to zero base current in the output device that the driver is connected to (the one that would ordinarily turn off quickly).
3) The reverse-biased driver Vbe also leads to the voltage difference between the bases of the output devices not being constant, but getting larger when the output stage is sourcing or sinking lots of current.
4) The zero base current of one of the output devices means that the stored charge cannot be swept out of the base of the output device by the driver.
5) This stored charge manifests itself as a slowly decreasing collector current in the output device that normally turns off in a conventional class AB circuit. It will eventually turn off, given time. Try it for 20 Hz for example. Of course, since it's an exponential decay, it will never be identically zero, but it will get arbitrarily close.
One interesting thing would be to show the driver Vbe's in this situation, with polarity chosen so that Vbe of the NPN and Veb of the PNP are shown (both positive in the active region). The other interesting thing is to show the base current in each output device going all the way to zero on alternating half cycles.
Here you go, 20Hz. Nothing changed but the frequency. There is now more current flowing in the "off" output.
Here's the schematic for those who don't use LTspice.
Edit: Output current was close to 3.5A peak for each sim. Output stage bias current was 262 mA.
To run the sim at different frequencies, just change the freq .param statement. It will do the same number of cycles regardless of the frequency.
In the idealized case crossover distortion has nothing to do with the output devices turning off. The logarithmic Vbe modulation between several amps and several micro amps is enough. I still don't get the fixation with "does the output device turn off".
wow , andy and steve on the same page. We still come so close to 0 , what we are attempting is to "rip " the carriers from the bases of the "half" that just switched off ?? from what I have seen, the "krill" way hopes to eliminate higher order distortion by not having a Xover point. Short of biasing your AB into A and using MOSFET's , This does not exceed the new triple I now listen to.
that is what gets "sucked" by my CCS's on the"off" cycle , the T3T triple works very good.. almost no H3 - or above .. at all.
Output device base currents at 1 kHz (left) and 20 Hz (right). Also shown are driver Vbe's for 20 Hz, showing that they turn off.
Obvious , it is still going negative. I have not gone for that result. I have instead "shot" for the best transition at Xover , resulting in the lowest H3/5/7 ... with a typical EF..
os
