Could this be a way to do a huge woofer with very low Fs
Drawing shows a huge membrane coupled to one or multiple woofers
short version? Nope
Long version? REALLY nope.
You'd get a ton of rocking mode distortion from the extended pivot point, and the suspension isn't meant for the type of stress you'd be placing on it.
Better to get woofers more purpose designed for your app. What's wrong with a few Acoustic Elegance IB15s?
I'd make an H-frame to lower the point where the bass rolls off so you need less EQ. Have you modeled it in 'the edge'?
Tinitus, have a look at this thread: http://www.diyaudio.com/forums/showthread.php?t=133711&page=37. They're going full range there, but I'm thinking like you, just try it for the bass. some day, I'm thinking of filling the cones of some old drivers with polystyrene foam and coupling then to a large sheet of something, just to see what happens 🙂
I have similar idea to make huge dipole sub.
get pro woofer with strong motor, remove its cone, leave spider and coil in place. then build and attach your own cone and frame.
then you'll have subwoofer bigger than 31" fostex for much less money.
flat panel cone is a bad idea, it will resonate way too much.
I actually plan to make deep profile, corrugated cone.
Thanks for the valuable input
You nailed down some of the obvious benefits
Update
"Cone" might be a 1/2" thick polystyrene sheet, about a square meter
No thread surround, but instead use the flexibility of the polystyrene
Corners are cut away to increase flexibility
Which woofer?
I dont expect this to be a high power speaker
I want a refined sub to be used solely at "normal" SPL
But stilll need a woofer driver with a strong motor and fairly good Xmax, if this thing goes really deep
Beyma SM212 might work, and cost is avarage around 100EUR
Or maybe even a carfi woofer would work fine
Update
Which woofer?
That 'felt' surround can be noisy I guess, no? I like the one with thread suspension better😀
And the motor should be secured in some way, so I think the skectch by MisterTwister make more sense to me.
As to the membrance, how about honeycomb cardboard? Quite light and rigid related to given area. If more than one motors can be used, then it can be driven more evenly.
I can see quite a few problems with this. Firstly, two motors driving one cone seems like asking for trouble! Also having no baffle at all makes is horrendously efficient, so you are working uphill negating your gains.
I think you'd be better off starting with some large 15" drivers with a powerful magnet and low Qts. Now remove the surround and simply extend the cone so that it's bigger. Cones are better because they combine stiffness and low mass. Any flat panel will be inferior. So you might turn that 15" driver into a 21" and perhaps use a few of them. Now put it in a H frame to get the best efficiency you can from a dipole.
Tinitus,
Why don't use a shaker as motor for some sort of rigid panel? Like this one: http://www.smarthome.com/8249P/Bass-Shaker-Pro-50-Watt-RMS-Pair-Bass-Transducers/p.aspx
If you want to get really clever use a servo motor to drive a large diaphram. Excellent LOW freq output.
Tinitus,
Why don't use a shaker as motor for some sort of rigid panel? [/url]
It did cross my mind
But I have no idea about how shakers work
Dont you think it would be like "one-note" bass ?
Small update
There have been some misunderstanding about mounting the woofer driver
Ofcourse it will be fixed on a chassis connected to the main frame
I was just too lazy to draw it, or thought the drawing would look simpler
I have looked a bit backwards and was close to decide on the the first suggestion with a stiff thick "cone" with some sort of "surround"
But as mentioned earlier theres a huge risk it will be "rocking" badly putting too much strain on the woofer drivers voicecoil, and lead to distortion
Another option( I think it has mentioned earlier as well)
Fill the woofer cone with a carefully shaped block of polystyrene
With a bigger plate of polytyrene in front
Like say 400x400x40 mm
And no additional surround, just the woofer
Some benefits are still there
Like a bigger cone that equals 2x 15", using just relatively cheap 12" with a strong quality motor
Lowered Fs and raised Qts, fit for OB
And pure pistonic motion
And certainly NO high FR peaking
Maybe nothing but low frequency
Makes me wonder how high it rolls off, about how much low pass filtering is needed
The previous suggestion with a big thinner sheet polystyrene
Flexible, and dont need additional surround
Doesnt put much strain on the woofer driver
Lower Fs is based on size, more than weight
Kind of like a very big ringradiator
Concerns with a big flexible "cone" ( 800x800x12 mm)
The ressonance of a big polystyrene "cone" could be a problem, and also lead to one-note bass
And there would probably be lots of other spurious concentric ressonaces
On the other hand, what are chances of winning in a lottery
But its getting closer to the dumpster
I think polystyrene foam is not so good as being the 'transmission' between motor and diaphragm, too soft, isn't it?
How about a section of cardboard cylinder?
Perhaps you could fashion a more typical type of surround from bicycle inner tube rubber? You could then mount to a baffle for better efficiency. I'd have thought if you used the flexibility of the material to act as excursion, you'd push the resonance back up from the springyness?
I'd expect flat polystyrene to perform very poorly. It is light, but it has no strength or stiffness. A cone with the same mass will be a lot stiffer and stronger. Aluminium subwoofer cones have enough strength for you to stand on them! Just think how thick and heavy the polystyrene would have to be to support your weight!
A cone wouldn't be extremely difficult to make. You could try paper combined with fibreglass/carbon fibre/kevlar. You might use paper to create the shape first, then apply the matting and resin. You could even create ribs for extra stiffness so the cone can remain thin. You could use balsa wood ribs - it has little strength of its own but as the matting wraps around it you then get the strength.
The real challenge is the suspension system. Have you ever heard what a driver sounds like once the surround is damaged? It's not pretty! You can buy rubber surrounds for re-cone kits, but the ones I've seen are small and not cheap. You may have some success with an accordion style surround, but to me this sounds like one of the most difficult parts.
If you leave it out you need a very stiff spider.
Might have a good idea there
I didnt know how to
Maybe I do now
Polystyrene
They come in all sorts of density and strenght
Here we use it below concrete floors
Anayway
I have decided to order a Beyma SM212 because of its relatively low cost and good 15mm Xmax(p-p),
Along with a 15" woofer I need for my bassguitar
I reckon a wheel for a racebike is 28"
A fine size for a woofer
Tuck in the tube
Pump it up
And its moving
Makes me wonder how much such a thing moves
There were some speakers called Poly-Planar back about 1970 that used a relatively thin 1/8" polystyrene membrane and no outer suspension. The diaphragm worked in bending mode. They sounded pretty good; the 8" and 14" x 20" versions had decent bass. Their weak points were a cheap motor (voice coils fell apart > 5W or so) and an aluminum foil whizzer which resonated nastily, fortunately easily removed.
Yamaha also did a bending polystyrene diaphragm design shaped like a human ear with the motor mounted off-center. Theirs was impressive (huge cast aluminum frame made of recycled motorcycles?) but strange sounding to my western ears.
I've wondered what a big styrene foam sheet driven by a stout motor would sound like. Might be pretty good, based on the Poly-Planar array I built.
Nice info, thanks 🙂
I have thought about the next step
Tall planar using RUBANOIDE "motor" 🙄
But man, those big neos cost more than quality woofers
The project was supposed to be big AND cheap
One step at a time I guess
Seems I cant let it go now
Stiffness of the foam panel can be controlled and the strength could be huge if a good quality epoxy/fiberglass mat was used on both sides.
But I think the problem here is that surely you will be limited to the original woofers X-Max and efficiency will be going down as the mass increases.
Great idea tho.
Bicycle tubes for surround--- just like "Myth-Busters"
Great idea tho.
- Subwoofers
- BIG diy woofer for OB
