NAD 3020 clone
Here is the schematic from a 3020B that was simulated using modern transistors. I thought I would experience the equivalent of audio nirvana when I saw the gain/phase plots of this circuit but I was underwhelmed. To be honest, the gain/phase plots look awful compared to a typical Leach amp. Of course looking at a simulation doesn't tell the whole story. But if it looks and simulates less than stellar, why build it? Some of the blame could be the modern transistors used to make it. I am surprised by the number of small caps sprinkled around the circuit to shape the frequency response. Sure, it's flat +/- 3db 20 to 20K but the phase response is iffy and it appears that there will be stability issues at high frequencies. Blame the modern transistors, I guess. Has this amp been cloned? Does the NAD 3020 deserve it's cult-like reputation??
I guess the search for the audio holy grail continues......
  • nad_3020_clone.pdf
Try bypassing the input filter. It intentionally limits the BW and is bypassable on the real amp (LAB input).
With modern transistors, it may require more agressive frequency compensation. Only experiment (not simulation) would be able to tell for sure. With only +/-30V supply it probably wouldn't blow up if it did oscillate.
:cool:
Onlky to get the idea to make a clone of one classical Bjorn Erik Edvardsen (BEE) amplifier
shows you are a bright young man
Because this Norway guy makes some very good design
with corrent audio amplifier ideas!
The new classical amplifier from him
can be found here: nadelectronics.com/products/hifi-amplifiers/C325BEE-Stereo-Integrated-Amplifier/details
Why not liike I suggested
make a clown out of a more modern variant of 3020 : C320BEE ;)
http://www.diyaudio.com/forums/showthread.php?postid=1104784#post1104784
Schemnatics can be found here:
ACD denmark member of diyaudio helpfull service
Comment....
Lineup: That comment was in reference to using the LAB input. Yes, it bypasses the input filtering and smooths things out
I did snag a copy of the SM for the 320BEE. That is a very interesting website for manuals. I find the 320BEE balanced design interesting. Quite a few more parts than the 3020 and different but there is a similarity to the original 3020 as well. The DC path for the input transistors is through the speaker output terminal, just like the 3020. Yes it's possible to clone it, I think. Maybe if I have time some day I'll see what it looks like in LTSpice. Shouldn't take but a hour or so to get some first pass results.
Lineup: Here is my results of a cloned 320BBE
WOW! With modern plain vanilla SMT transistors (not the 2SA/2SB/2SC/2SD types) this amp simulates very well. Flat to 100K. Excellent phase response at the ends and through the audio range. I like it. I want to build it. If you want a copy of the LT Spice schematic, email me at stoc005 (at) comcast (dot) net and request a copy. The reason I am not including a .pdf of the LT Spice schematic is because somebody could just copy it and sell boards/amps on EBay.
the design is unstable at higher frequencies. which the people refers to as roll off in the treble. it adds noise above certain frequency, not very high. I think it around 15k onwards
It would help diagnose faults in aging equipment to be able to use the simulation if you would post the .asc file. There are many threads about faults in 3020's and you would be doing a good service to many experiencing these difficulties. I am happy to have a look at the original circuit and your version of it.
In your pdf version the value of C8 is astronomical at 1000pf. This value will be amplified by Q2 and the resultant load will appear between the base and earth. For more detail on this on this search online for "Miller effect".
Stellar and not a word that rhymes is the aim.
