can't download the manual!
Hi Bob / Jens,
I can't download the manual. The page is locked?! Can some one please send me a working link or the (zipped) file?
Thank you
Peter
Hi Bob / Jens,
Thank you
Peter
Peter - YGM
Jason - are you looking for information on how to design the eq sections of this board or make an adjustable equalizer?
Re: Off topic
Try searching for "Rane and EQ" maybe something will come up....
The design of a real perametric EQ should make it possible to adjust Q, Fcenter, and Gain without one affecting the other..... so you will need 3 pots pr. adjustment if you want to make it universal.
If you want to build a say 10 band EQ I'm sure there is something on the net.... here the Q and Fcenter will be fixed, and only the gain can be adsjusted.
What do you prefer?
\\\Jens
jason132pop said:Does any-one know where I could find some DIYer on parametric eqs??????
What do you prefer?
\\\Jens
gil-garcia said:thanks a lot
it would be great to receive by mail PSU and xover manual
philippe
Is the manual available ??? If so could someone email it to me??Had shelved this project after purchasing PCB's and would like to start the project. Have all EXELL sheets downloaded but would like to have the manual also.
THANK YOU,THANK YOU .....and
Seasons Greetins🙂
F1 FAN said:
Many Thanks😎
class-a
Is there any significant improvement to be expected by running the opamps in class-a.
Does the PSU 2.2 has enough power for that?
depends.
How many opamps do you plan to use?
How many are being converted to single ended ClassA?
What bias current do you plan to use for the ClassA?
You forcing me to finnish the design. I have to get back to you.
Soundwize, is it a matter of doing all or doing none? or is biassing the input and output opamps f.i. already benneficial (how do you spell that?)
PSU 2.2 can provide up to 500 mA, the limiting factor being the rectifier diodes.
If you were to do a bit of modification to allow larger diodes the limiting factor would be heat sinking on the pass transistors. The PSU design spreadsheet calculates max current based on heat sink size and the assumptions that it sits in 35C ambient and 100C maximum junction temperature.
BobEllis said:I've had a few requests for boards, but not enough to justify another buy. With nearly 2,000 AF4 boards out there, I suspect that there are a lot gathering dust.
If you are not going to use your boards, post their availability here and likely someone will snatch them up.
Hi everybody -
I need 2-4 filter boards for new projects. (Have used up all the 8 I originally bought). Anyone have some they are not going to use?
Thanks, Espen
Re: spare boards
Excellent. I'll take them. PM sent.
Thanks, Espen
SWDick said:I've got 2 spare boards for 5 euro each plus shipping.
Thanks, Espen
active crossover pcb needed
needed a stereo active crossover complete pcb (with psu pcb).
Anto
Anto
xover boards
I'm looking for other two active xover boards in order to complete my active xover with a stereo band pass module. Can someone helps me?
Anto
Anto
Re: xover boards
Try this link: http://www.diyaudio.com/forums/showthread.php?postid=1647475#post1647475
He may still have the 8 sets.
Good luck!
Ciao
10y said:Hi,
Anto
Good luck!
Ciao
- Group Buys
- Active filter board GB
