Advise on heat sink
Hi everybody. I have a question. The heat sink I can find here is 150 (h) x 100 (w) x 25mm (d). I intend to mount the mosfet onto the heat sink. Please see attached images. Will this be enough? These heat sink are from China and o specs on them. Please help.
pmchoong said:
So, these heat sink should be able to handle the heat.
NO! What people have told you, is based on guessing. To you it should translate into something like:
"Those heatsinks are worth checking out a bit closer, and do some calculations."
As Jaccolina stated above, there are online dissipation calculators around, and if sucha a calculation tells you that the heatsink is big enough, well, then it's a bit closer to a green light.
Magura 🙂
