my 6922 / E88CC preamp
Finished with my simple E88CC preamp, tested with JAN Philips, Siemens and Telefunken tubes. They do measure differently, with the Siemens having the lowest distortion.
I really love the E88CC 😀 Just want to share my work :
http://shine7.com/audio/6922_pre.htm
6922 E88CC 6DJ8
I like this one.
If I will make me one 250 Volt DC supply I try this!
As I recall these tubes also need heater Voltage/current
at like 6.0 - 6.3 Volt ...... DC or AC.
Is this correct?
Making one 250 VDC supply is not as difficult as we think.
It is most about find a suitable transformer
that outputs like 180 VAC .. or 2 x 90 VAC.
These can be found at almost any electronics internet shop.
At least I can get 230 VAC in ... 2 x 115 VAC out Trafo.
Need not be too big as the Current involved is not very high .....
I attach your schematic, if you do not mind.
I got it from your website:
regards 🙂 lineup
SY and his memory 😉
quoting from the thread
http://www.diyaudio.com/forums/showthread.php?s=&threadid=115941
SY, if you ever make it to HongKong you have to visit the store where I saw those solder stands. Bush Electronic Supply, in an alley behind a pretty big street in Hong Kong central or the Centre. You enter the alley, then walk up some steps and you enter the shop. Amazing, the contrast. http://hktubeaudio.homestead.com/files/Central_tube.htm Daan
similar PCB is available on E-Scam http://cgi.ebay.com/MULTI-PURPOSE-T...7QQcmdZViewItem not associated with the seller.
a more up to date link
http://cgi.ebay.com/MULTI-PURPOSE-T...VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Since there are interest in these, here is a close up photo : I bought them from : Sound Explorer Company 凱韻音响電子公司 Flat A, 7/F., Hamilton Comm. Bldg., 558-560 Nathan Road, Kowloon Phone : +852 2332 1821 If you have a chance to pass by HK, buy some
Excellent little project. The 6922 is one of my fave tubes. It has a lot of versitility being of quite low distortion, able to work at low voltages and having quite high Mu and current handling. People usally slate this tube and dismiss it for audio use but i think its O.K
Leigh
Karsten Sømand said:
Have a look at this link. The PCB looks pretty much the same style as the one Alex uses (maybe not 100 % identical).
I don´t know how interesting this PCB is when you look at the price of 27 $ US.
http://www.kitsparts.com/shop/index.php?main_page=product_info&products_id=122
Have a look also at the other Tube pcb stuff from www.kitsparts.com
like for example
Modified ARC Audio Pre-Amplifier Tube Full Parts Board
... of course it costs money: $117
