The Advantages of Floor Coupled Up-Firing Speakers
:cop: Note: Thread title changed.
Reading what many people in audio wrote on the subject of loudspeaker design (Carlsson, Beveridge, Moulton and Linkwitz were my main inspirations) I came to the conclusion that the real issue is that loudspeakers and room form one system.
Recently I had an impression that this I also a view of gedlee (Dr Earl Geddes) when he wrote that the most important parts of his book are those concerning waveguides and room acoustics ("Don't read the stuff on non-linearity, but fully grasp the chapter on waveguides. Thats what I would say today.That and room acoustic")
Later I came to believe that what Dr Geddes writes on the topic of room reflections is in the end of the day the same thing that Carlsson, Beveridge or Moulton and also Linkwitz have written on the subject. And that in their designs they wanted to achieve the same end - to eliminate the detrimental effect of room reflections.
And yet their designs are so much different!
Apparently there are many ways to achieve the same. Linkwitz’s experience with subjective evaluation of his own an yet very different dipole and omni designs confirmed this for me.
I have very unusual loudspeakers which I have built some time ago with those room-speaker interface things in mind. These are very short omnidirectional loudspeakers. They are just 20 cm high and have 8 inches wide range driver on top and firing upwards.
The loudspeakers are to work on the floor – the driver is only 20 cm above the floor – and against the wall.
In this positioning they happen to be quite similar to the late Stig Carlsson designs (carlssonplanet.com, but the Carlssons are two-way and much more complicated because of that) but were not inspired by them.
I didn’t know the Carlssons when I was building these and my first and main aim was to eliminate the detrimental effect of early floor and ceiling reflections without resorting to unavailable true linesource (like Beveridge)
The second aim was to build loudspeaker least visually obtrusive, loudspeaker that would be practically invisible in the listening room (which in may case at the time was also a living room). Perhaps it was even equally important goal.
But frankly speaking I wasn’t thinking a lot and I think now that I really didn’t know what I was doing 😉 and still I don’t – I have no technical background – and it was and it is all mostly intuitive. 🙂
But the outcome appeared to be quite satisfying. This is still work in progress. Achilles heel of the loudspeakers are 8 inches Fostex wide range drivers which have major resonant problems in the break-up area. Out of the box they were literally howling at me. After some driver-mutilating (i.e. tweaking) I can say that these problems are only partially solved for the time being and I am looking for a different driver
Soon I will have a new listening room that is 350 cm wide and 550 cm long. Not too big and not the best proportions but I can arrange it specifically for audio purposes.
I am considering positioning the speakers against the opposite longer walls (scheme attached). Stereo basis would be 330 cm. The listener is to be located 200 cm from stereo basis, 250 cm from both speakers
All this with the questions of minimizing early reflections in mind and particularly with what Dr. Geddes has written on this forum.
A big thanks goes to Dr Geddes! 🙂
To my not very big surprise the resulting set up happens to be very much like Beveridge positioning of his line source electrostatics.
The positioning would give very early reflections (VER) <1 ms from adjacent wall. I hope that they would not be strong enough to become audible problem because the Fostex is quite beaming (I don’t know for sure but 8-inchers are typically 7-8 dB down at 1 kHz at 75-90 degrees and 12-15 dB down at 2 kHz). I am also considering using small Carlsson style absorbers effective for midrange and high frequencies as an option.
Apart from those very early (and hopefully low in level) VER I expect that:
- significant reflections off the adjacent wall would not reach the listener
- floor reflection would not reach the listener
- first reflections off the front wall and off the back wall would reach the listener 9.3 ms after the first wavefront
- first reflections off opposite walls would reach the listener 8.3 ms after the first wavefront
- first reflections off the ceiling would reach the listener 8.8 ms after the first wavefront (ear at height of 90 cm, ceiling at height of 300 cm)
It seems that apart from those earliest reflections <1 ms all other reflections are delayed more than 8 ms and caught by proximity (Hass) effect.
And all this in a relatively small listening room. The bigger the better.
Also I am considering using some wide band absorbers to reduce the reverb after first 50 ms as Moulton recommends.
What do You think? Any suggestions? Ideas? Your own unusual setups?
best,
graaf
graff - I like where you are going with your ideas...😉 I'm working along similar lines of thinking but was not aware of the carlsson site until you listed it and found it very interesting. I made a couple of prototype omni speakers along the lines of Walsh 5 (Walsh 5 remake thread) and enjoy them very much - but improvements can be made I'm sure. I decided that before I spent piles of time, money and effort that I would read up about things, and like you have discovered that about half (debatable) of the challenge of good sound reproduction is the room itself. Reading Dr. Geddes book on audio transducers now. So I'm interested in this topic and I'm sure that others will join in. BTW do you have any photo's of your speakers? :cheers:
I'm glad to hear that 🙂
this "white paper" is particularly intersting: http://www.carlssonplanet.com/downloads/uploads/carlsson_ortho.pdf
c2cthomas said:
So I'm interested in this topic and I'm sure that others will join in. :cheers:
I hope so 🙂
I have photos of the "almost finished" cabinets (WxDxH - 33x33x16 cm), the driver is highly modified Fostex FE206e
best,
graaf
Oskar Heil Speakers uses speakers that fire up towards the ceiling and an Air Motion Transformer for the HF. http://www.unitedhomeproducts.com/id101.htm
In my Walsh 5 remake I am using the AMT above 5 KHz and an upside down 10 inch Pioneer for mids and LF up to 6 KHz. Below is a sketch of what the final version should look like - if I ever get around to making that version of the speaker. At present I'm considering other adventures which include OB. :cheers:
Heil speakers are interesting in combining dipole and omni radiation pattern
But In my loudspeakers I don't want separate tweeters. I "believe" in crossoverless designs.
Fortunately the Fostexes I use in my configuration (they are currently positioned against the same reflective 5.5 m long wall) give me almost all treble I subjectively need. And that with the whizzers cut off. With the whizzers they were excessively bright for me. Now they are even more beaming but I get the trebles from the wall and ceiling reflections. When positioned appr. 20 cm above the floor the Fostexes though beaming nevertheless "illuminate" the ceiling and larger parts of room walls with the trebles quite uniformly. This is a kind of additional advantage of such a low positioning just above the floor.
So I am rahter thinking of adding separate stereo subwoofers behind the main loudspeakers than of adding any kind of tweeters or midtweeters
best,
graaf
graaf
Very interesting topic !
I work with some of the ideas you come up with and I`m well aware of Stig Carlsson`s loudspeakers.
My current speaker setup is a pair of Jordan jx92 in 12L in closed "boxes" close to the floor and 1,4 m away from the nearest wall.
I even tried to put the two together to form a sphere and place it in the corner as a "stereo-speaker" with a sound barrier in between and listened in nearfield, sort of ambisonic approach.
wow! stainless bowl!
great idea! 🙂
I would say that it is getting even more and MORE interesting 🙂
The Jordans were my second choice. I admire what Ted Jordan does. I am a real "Jordan propagandist" in audiophile web community here in Poland 😉
I chose the Fostexes because as 8-inchers they are more directional (I needed high directivity in this design), they require less excursion for a given SPL which is a good thing and having very low Qts they need smaller box which is a very good thing.
WOW!
I didn't know that anybody has tried this approach apart from myself! 🙂
You mean AMBIOPHONICS? (www.ambiophonics.org)
I was inspired by ambiophonics when I tried something like this. I built rectangular box 23x23x23 cm with wide rangers of the size of JX92s on opposite sides.
What I was trying to achieve was an "ambiopole" i.e. "crosstalk-cancelled stereo array" without physical barrier or electronic cross-talk cancellation, which are normally required (alternatively).
I was relying just on the directivity of the drivers and of the cabinet.
And it worked! I positioned them diagonally close to the corner and into the room and also against the wall and in the middle of the room. And they worked in every position. It was amazing. This was the moment I finally departed from "standard stereo triangle" set up for good. In terms of recreation of natural space "standard stereo triangle" was pathetic in comparison. Unfortunately the thing didn't work well with some recordings and I finally postponed the project.
Later I came across another less known website: http://www.stereolith.ch/
Walter Schupbach has been making similar speakers for twenty years now or even more!
His latest designs employ monophonic tweeters. Stereo signal goes only to the sides.
Joseph Manger has discussed that type of stereo loudspeaker in his "Manger Discus" patent. He called it "dummy head stereo" and raised some doubts as to the compatibility of this design with currently made recordings. From my experience I can confirm that those problems exist. Alas! Because with suitable recording one can get real 3D from such speakers! I mean REAL 3D. The listening room literally disappears. "Walls, ceiling and floor disappear and the air itself is playing music!" as one of may audiophile friends has decribed this experience. "Standard stereo" is laughable in comparison.
Here is a review of somewhat modified Schupbach loudspeakers:
http://www.magazine-audio.com/essai...hi-fi/22/stereolith-up-grade-vu-par-richard-d
best,
graaf
or shall I better say "lamentable"? 🙁
graaf said:
let me draw Your attention to two points in the conclusions of this review. The reviewer writes:
"Profondeur et hauteur d’image musicale hors du commun" i.e. "extraordinary depth and height of soundstage" and at the same time:
"Image stéréo étroite" i.e. "width of the soundstage is shortened"
this conclusions are highly symptomatic of the main problem of this design
the problem with this "dummy head stereo" or „pseudo-ambiopole”, as I like to call it, is that it reproduces EXACTLy what is in the recording
It means that "it produces no artificial soundstage"
on the other hand many or even most of contemporary recordings are made with an assumption that they will be reproduced in a standard stereo triangle and thus they rely on the loudspeaker spread in such a triangle to produce the width of the soundstage
such a soundstage created by loudspeaker spread in a stereo triangle is of course completely artificial because it has nothing to do with natural spatial cues for distance perception
pseudo-ambiopole is reproducing as faithfully and as accurately as possible all the spatial cues encoded in the recording ("natural" or "artificial")
but many recordings give little or no spatial cues for soundstage width because the width "is to be created by" "spreading of the loudspeakers in a typical stereo triangle"
when there is little spatial cues for soundstage width in the recording pseudo-ambiopole produces "shortened soundstage width" as described by that French speaking reviewer: "Image stéréo étroite"
and when there is NO spatial cues for soundstage width in the recording pseudo-ambiopole produces literally NO SOUNDSTAGE WIDTH, the soundstage collapses completely
and this is quite catastrophic and a fatal flaw of this design from practical point of view
BUT precisely speaking the device is right, only recordings are crappy
but what can we do?
fortunately - yes we can do something 🙂
we can try a different method of "acoustically hiding speakers in the room"
yes, this is EXACTLY what pseudo-ambiopole does – because of its "bipolar" directivity our hearing is unable to locate the speakers as a distinct sources of sound – they are hidden, they disappear, "the air is playing music"
this is the secret - the ESSENCE of this design
I realized that Harold Beveridge proposed such a different solution – an alternative method of achieving the same result
in his recommended speaker positioning (low directivity speakers against the opposite side walls facing each other I front of the listener) the speakers are acoustically integrated with the side walls – they are perceived as a reflection off the wall
in fact for our hearing the speakers ARE reflection off the side wall and for our brain the room itself is playing the music and not the speakers
this is the solution I decided to try in my new listening room
My latest loudspeakers (image of the "almost finished" cabinet attached above) I built with intention to emulate as possible the room-speaker interface possible with true line source used by Beveridge with regard to effective elimination of distracting early floor and ceiling reflections.
best,
graaf
graaf
You are absolutely right, ambiophonics, that was what I meant.
My own experience reflects yours to some extent, and I wish more people would try to experiment with alternative setups in order to take advantage of the room, rather than fight against it.
One thing strike me whenever I go to a live concert.
It is very hard to pinpoint musicians with eyes closed. Many audiophiles try to setup their speakers in order to get razor-sharp imaging which doesn´t exist in real life.
Problem is that rewievers in all the glossy hifi-magazines want us to believe pinpoint imaging is crucial in order to get a good experience
Virtually all recordings is produced to provide satisfactory results on a boombox or in the car, and most sound artificial and downright boring.
Record companys care for the mass-market, teenagers with great buying-power, audiophiles are a small minority by comparison.
Graaf, I want you to do yourself a favor. Do your own recordings to become familiar with, it is essensial when you evaluate your speakers
http://www.linkwitzlab.com/sound_picture_cd.htm
JB
But In my loudspeakers I don't want separate tweeters. I "believe" in crossoverless designs. best, graaf
Hello graaf - the only crossover element in my speakers is a small capacitor to keep the low frequencies( < 6 KHz) away from the AMT's - so this is not much to worry about. But we are here to discuss using the room as a speaker and not so much about crossovers as I don't recall crossovers as being part of the room treatment. Also you prefer to use a single FR (Full Range) speaker for personal reasons and I understand this as I also have a pair of Fostex 167's FR's (and no x'overs - just silver wire to the connectors). But there is nothing that says that FR's are the only design suitable for this goal of using the room as part of the speaker system. I seem to recall the Carlssons that you referenced in you 1st post as being a multi element speaker - yes? The Heil AMT tweeter is a superior unit and has stood the test of time and many - many - reviews and I have not been able to find anything that can do better for use as a dipole transducer - certainly not a Fostex (and I can say this because I own and use a combination of both speakers in my HT system).
I have visited the Ambiophonics web site http://www.ambiophonics.org/index.htm and am reviewing the material presented there - it is very interesting in concept and will take some time to absorb.
Considering your comments for using a directional speaker to "beam" off of surfaces (walls - ceilings -etc.) have you considered the use of a wide band horn such as the Eminence APT-200 http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=290-536 combined with a suitable LF unit used in an OB configuration (for the LF unit)?
:cheers:
I agree absolutely
sad but true 🙁
actually an audiophile friend of mine is making his own recordings inspired by Linkwitz
for me making them myself would be difficult, I'm not very technical person but maybe sometime I try
best, graaf
Reactions: Freedom666
absolutely, that is correct
Heil is legendary, no doubt about it
I am aware that 8-ich Fostex is no competition
but Heil is also expensive 🙁
in my case the reason for going fullrange is also financial
I aim at most cost effective solution
not to mention WAF-and-home decor concerns 😉
I am an audiophile on a budget but not very unhappy - I like it fullrange 🙂
but of course this is not the topic of this thread
:cheers:
interesting idea - thank You for the suggestion 🙂
I thought also of coincident drivers like in KEF UniQ
Seas offers such a driver if I remember correctly
best, graaf
Not so. In some situations it may be hard to pin point but not always. To many people seem to think that a big lively concert hall is the reference for a stereo set up. What about those who like to listen to jazz and folk? And studio productions?
That said, a number of years back I did try to pinpoint a small vocal group in a cathedral like church in Stockholm. The acoustics was very rich and reverberation several seconds due to the size of the church. I had no problem with localization of the five performers even at a distance of aprox. 15 meters. They stood in a semicircle/arch less than a meter between the performers.
Even though most of the energy is reflected in such a performance we still have this extraordinary ability to hear direction on transientlike sounds. Consonants give away more than continuous sounds of course but even throat sounds (vocal cords giving "buzz and noise" at higher levels.. especially male voices) can give clues.
I for one also want to be able to recreate my pals when I record them in a livingroom or outdoors.. is such situations the pin point is extremly sharp.
So of course it exists in real life.
It also happens to be like this.. when your stereo have the ability to give good focus most other parameters fall in place as well.
/Peter
well, maybe it all boils down to a question how "pin point" is "pin point"? 🙂
to make myself clear - I don't know the experience of other contributors to this thread but loudspeaker and set ups I write about here give me precise imaging, not uncomfortably "diffuse" nor "vague" at all
not at all "un-pinpoint" in any negative sense
and absolutely more realistic the standard stereo - occupying a real space, 3D, very palpable images
best,
graaf
/Peter
I don't like the adjective "pin point" I think it is very misleading
because we can ask - how much is it "pin point"? of the size of the pin?
are the singers or any instruments "pin size"? etc.
of course not
I assume that by "pin point" You mean "precise". Please correct me if I'm wrong 🙂
best, graaf
Let me guess - you saw them there standing, closed your eyes and said "yup, they are in a semicircle/arch less than a meter between" ?
Or did you guess their positions without seeing them first ?
That makes all the difference in the world. Just like with sighted amplifier tests.
Eyes closed of course.
But yes, I did see them before I closed my eyes. Thing is I listened to a piece with eyes closed and did not know who sang which parts but I was myself relatively surprised to notice how obvious it was when someone started to sing. That is it was easy to hear that the sound suddenly came from a new position. Listening to the start of the words/phrases every voice had its own place in space.
I have done a lot of these tests in various acoustics and with various sources of sound. I write and record music, sometimes with a friend that also is a musician and use to produce music/radio jingles. We have recorded in rooms the size of a bedroom up to hangar sized halls. Building/arranging studios and listening rooms from 10 to 100 meter squared we have had great opportunity to test the room sound and localization of sound sources in close to anechoic to lively acoustics in the same room.
Without this ability our ancestors would have been tigerfood and we would not exist. 🙂
/Peter
