Hi, need some help.
the small gear inside the CMK Drive (control in and out of the drawer) broken into pieces.
Anyone can tell me where i can order? thanks
I have a spare transport unit from VRDS-10, if there is any similar parts?
Photo/details of yours?
Arne K
Arne K
Got the same problem on my vrds 7. Did you find one ?
Also searching a service manual for this CMK4 mech. (VRDS 7 or VRDS T1). Will do a separate post
I have a Krell KAV300CD which has the same problem. . The service dealer (who used to do Krell repairs but no longer does so due to the non-availability of spare parts in South Africa) says that two gears in the CD mechanism have worn teeth and need to be replaced. He says that it is a quick and easy job but is not prepared to try source the gears. He says the unit is a CMK4 but cannot give me part numbers as he does not have the service manual. I have tried to find a manual on the internet but the manuals refer to the TEAC CD players rather than the CD mechanisim. As far as I can gather the TEAC VRDs T1 has CMK mechanism but I am not sure.
Any ideas where I might source as manual which covers the CMK 4 mechanism and or spare gears?
Dale
Dale
I've just replaced the 2-step gear. See the thread TEAC VRDS T1 broken gear. Detailed instructions with part numbers and supply sources listed.I have a Krell KAV300CD which has the same problem. . The service dealer (who used to do Krell repairs but no longer does so due to the non-availability of spare parts in South Africa) says that two gears in the CD mechanism have worn teeth and need to be replaced. He says that it is a quick and easy job but is not prepared to try source the gears. He says the unit is a CMK4 but cannot give me part numbers as he does not have the service manual. I have tried to find a manual on the internet but the manuals refer to the TEAC CD players rather than the CD mechanisim. As far as I can gather the TEAC VRDs T1 has CMK mechanism but I am not sure.
Dale
Gear replacement
Thanks. I managed to get hold of a TEAC VRDS T1 service manual and indentify the required part numbers which are recognised by Krell. I have ordered a 2nd 2 step gear which I plan to tape inside the unit cover it case the new one fails in 10years time because it seems a common problem (by the way their price for the gear is USD 15).
Hi Dale. Did you order via phone or e-mail through Krell US? The UK distributors here direct all enquiries to TEAC. I would also like to order a second set of gears and do as you have done. Many thanks.
Krell relavement gears
I ordered via www.krellonline.com. I ordered last Wednesday and received them on Monday morning. The 3 gears plus a a new belt drive and courier charges came to $100.
Dale
Dale
Many thanks.I ordered via www.krellonline.com. I ordered last Wednesday and received them on Monday morning. The 3 gears plus a a new belt drive and courier charges came to $100.
Dale
I just had a KAV-300cd strip that same gear. Teac USA did not reply yet. Krell did and said the gear can be had for 12 USD. each. This same deck had a failure on the audio board due to leaking Nichicon capacitors, one shorted a trace. Replaced all 28 of them and the audio problem cured. Then the gear immediately failed after that!
Can anyone advise if can assess the 2 step gear on the CMK-4 mechanism without removing the CD tray ?
Hi, need some help.
Is this it??
http://www.chsinteractive.co.uk/electrical-components/misc/vrdst1-gear-b-rack-teac.htm
Cheers George
- Digital Source
- Repair of Teac CMK4 Drive
