The tray will not open or close. If it is helped a little with a finger I will move, but not without....
It could lack some oil or lubricant? What to do?
hai, iv been thru with diz kindof problem before, what i did was get the tray motor replaced and it works. you can source the motor from any philips cdm4 tray mech. good luck.
You may have a missing tooth on the drive gear, if so read here.
http://www.diyaudio.com/forums/showthread.php?postid=1149198#post1149198
Cheers George
Cheers George
Where is the tray motor and is rework possible?
Dont think it is gear because it can work with a little help....?
Loose part inside...
When I opened the played a part was loose inside. With a little shake it fell out. It was a little metal pin or axle....2mm in diameter and 10-11mm long....with hard surface...like a capstan axle on a cassette player.
Anybody know what it could be? Possible a part of the tray mechanism?
It seems to be the two belts, the motor is running but they do not move the wheels....
Anybody knows the types?
go to
http://www.diyaudio.com/forums/digital-source/89200-help-philips-cd960.html#post2226966
I have the same problem. I opened up my CD960 and this little pin drop out. I cannot figure out where does it come from.
My 960 tray keep open out and not spin when I close it. I dont see the laser light up. Any help? Tks
- Digital Source
- CD960 tray problem...
