Pass Pearl 2 troubleshooting help needed, low output in one channel.
Hi Gang,
A friend was kind enough to give me a pair of populated boards, and it was gesture I greatly appreciated as I have been swooning over them for years. He made one "small" mistake which I thought was on purpose.. he left out the LED's completely. That made R29 smoke in both channels.
So, I replaced R29 on both boards and installed LEDs with the correct polarity. I brought the boards up and one of them still smoked R29. I found a short in Q11 and replaced it. This channel works properly.
The other channel didn't obviously cook any transistors. I just dropped in a fresh 100 ohm resistor at R29 and tested it out. This channel shows a dramatically lower output. The only oddity I can find is higher voltage at the Collector of Q11. I can't seem to figure out why.
I am going to be totally upfront and say I am a total rookie at this type of thing and usually can't successfully diagnose a circuit because I don't truly understand how it all works. I also can't count out an assembly error of some sort by my friend.
Any help is appreciated, I am dying to hear this thing!! I borrowed my friends and really liked it a lot.
Thanks in advance.
HiFiBerry AMP2 Power Issue
Recently took delivery of one of these amps, which I connected to my working RPi 3B loaded with MoOde. I initially connected it using a 19.2V PSU, one that I've successfully used to power my Zoudio amp previously.
No +5V. The board says 18V at the input terminals. So I tried a 16V PSU. Get +5V this time, but not for long.
The only way it runs with the 16V PSU is if I co-power it using the ordinary pi 5V input. It plays correctly. If I remove the additional 5V PSU, it drops out within a few seconds.
Do I have a defective AMP2 module?
HiFiBerry says it's supposed to power the pi and then some from the amplifier power input. I know the TAS amps are good for 24V and HiFiBerry only warns against using >18V with 4 ohm speakers... Implying it should work with , oh, 19.3V input and 8 Ohm speakers which I have.
I'm using the screw terminals, versus the quick connect for the PSU connection.
Any help would be appreciated. Thanks!
555 Timer DC Protect / Turn-On Delay
I have been working on a simple design for a turn on delay and DC protection utilizing the venerable NE555 timer and have encountered and interesting issue.
I decided to prototype the design quickly on some perfboard following simulation success. I only had a ratty old salvaged 555 chip that I wasn't even sure was OK, so I stopped at the local junk monger to pick up a few new ones. So, I cobble up the test circuit (see attached) with the recommended local decoupling and such and of course it didn't work as was expected (otherwise I wouldn't be asking 😉).
Well initially I can say my issue was self induced as I inadvertently applied a supply voltage that was too high and may have ruined one. After realizing my error I re-configured my PSU for a proper supply voltage and installed a new 555. Still wasn't working. Removed the second new 555 and double checked everything again, no errors found. I decided to pop in the ancient old 555 and here is where it gets interesting - the circuit worked exactly as expected.
OK, no apparent error. One possibly toasted 555 was my fault, another seemed to be DOA. Curiosity got me as I had bought four and had only tried two new ones thus far. I decided to try the others and found they did not work as expected either, but whenever the old one was inserted, voila, it would work.
Now to my question. Does anyone KNOW what, if anything, would cause three new 555s to not function (I actually found another unused one that did not appear to work either, so four in total) while the really old one worked perfectly? They are all bipolar devices, no CMOS ones were used. Is there some fundamental difference between the construction of the old vs new that is the difference? I thought the 555 was basically unchanged since 1970 so expected them to all behave the same. Am I wrong?
Overseas shipping delay time
The coronavirus situation obviously had an impact on delivery time of the goods (in our case diy parts). I'm still waiting for items to arrive after two months (item was send from USA).
I have a hesitation every time I find something and the shop is overseas
What your experience with orders you've made lately ? Also did you have an experience where you've finally received an order after months of waiting ?
Does Mouser/Digikey/big shops have the same week or so delivery period ?
Crossover LCR meter measurement
I bought an LCR meter to measure the values of unmarked crossover components. I now realise that the meter measures impedances and calculates values for LCR. The issue is that the values displayed depend on the frequency setting. However when I buy an inductor/resistor/capacitor, they aren't specified as having a particular value at a particular frequency. So how do I know which measurement to use to obtain the actual value of the component in crossover? Thanks.
FS Dayton Audio Esoteric ES140Ti-8 midbass drive units
Up for sale I have a pair of Dayton Audio ES140Ti-8 5 1/2in midbass drivers from their Esoteric series. Drivers are brand-new-in-box.
The 140 has a superb spec.; key features include a woven fibreglass cone of large central cap design. Finite element designed motor with neodymium ring-magnet, dual copper shorting rings, 3in edge-wound CCAW voice-coil with titanium former, long-throw suspension, tethered tinsel leads. Klippel optimised suspension. Heavily vented motor and extremely open cast basket design. I've attached some Dayton images as it's an impressive looking unit.
As noted above, brand-new-in box. Asking for £80 for the pair + shipping, which is about £60 less than some European sellers are asking for a single unit.
On the subject of packaging, they are in their original Dayton Audio boxes. I use sustainable FSC rated outer cardboard boxes fastened with heavy-duty packing tape. These are reinforced inside with recycled heavy-duty cardboard and packed with recycled brown / grey packing paper and high quality bubble-insulation.
As always, thanks for looking. 🙂
Large lot of transistors,diodes, LEDs, etc
Thousands of pieces, hundreds of different part #s, too many part #s to document and list here. Most are (>90%) NOS, I imagine from 10-30 yrs old but some may be newer. More parts then are shown in the photos, I think they can be stuffed into a 22x17x16 box weighing 35lbs. My zip is 17036 and prefer to ship via FedEx, so you should be able to get a shipping estimate at FedEx based on the above information. I will not ship international, it will cost more then the parts!
Price is $99 for the entire lot, prefer local pickup.
Krell KSA100S jumps into its security
Dear DIY enthusiasts and professionals, My Krell KSA100S jumps into its security immediately after switching on. I have no money to buy such an amplifier again, so a repair is my last rescue. Could any of you help me with a schedule or repair manual? I would be very grateful to you. Thank you in advance for your effort! kind regards Arnold Bergen.
Please critique - Studio Monitor - SEOS 12 + 2x6" Mid-Woofer + 18" Sub
3 way high SPL sealed studio monitor
Edit - Changed the title of the thread to better reflect the current ideas.
Hello,
Apologies, I have started similar threads before, but got confused and waylaid by other projects.
I build music studios. I have built several pairs of custom speakers for my studio builds... mostly derived from proven designs. I have a superficial understanding of some things, but I can be flummoxed easily.
I want to build a sealed, 'limited range' (100 Hz - 20 KHz) monitor which will function well @ 2m-4m listening distances. The accepted studio protocol (per ITU 775) is an equidistant triangle between the speakers and the listener, with L&R angled @ 30 degrees.
In my current demo room, I have Tannoy DC12i (with a coaxial 12" driver) and custom subwoofers with AE TD15H drivers. One of my main problems is that the stereo imaging is much more stable further back into the room from where I'm sitting (the speakers are about 9' apart and I'm sitting @ about 8' - this is 1' ahead of the theoretical "sweet spot"). I'm hoping that a smaller mid-woofer will beam less and widen the sweet spot.
I already have a pair of B&C DE250s in SEOS 12 waveguides. I'd like to use the DE250s for sure (they sound absolutely great to my ear, in a pair of 4 Pi speakers I built), but I'm willing to consider a smaller waveguide if it will help me increase my XO frequency (between mid-woofer and CD), for a wider sweet spot at a closer listening distance...
System will be tri-amped with Class D amplifiers, and managed by MiniDSP 4x10HD, with analysis and tuning help from REW.
At this time, I'm thinking that bass duties will most likely be handled by a JBL 4645c, simply because it is very inexpensive here. Luckily, it will serve as a great stand for the mid-woofer/HF speaker and bring the listening axis point up to the recommended 4' above floor level. I'm also thinking about a Peerless by Tymphany STW-350F in a custom sealed enclosure, but that is for another thread.
Right now I am focussed on the mid-high component.
Goals:
* 82 dB average / 102 dB peaks @ 4m, from ~100 Hz to ~18 KHz (some active Eq may have to be applied to achieve this, of course). (85/105 dB is the film standard - but for smaller rooms, the kind that these speakers are intended for... 82/102 should be sufficient.)
* Suitable for listening distances of 2m-4m.
* Sealed enclosures that can be easily customised to different rooms by varying the dimensions, but keeping the internal volume constant.
At this time, my questions are -
* Will a pair of Eighteen Sound 6ND430s per side do the job? What alternatives should I consider?
* If so, how high can I cross them over to the DE250s in SEOS12 waveguides? Or should I consider keeping the XO point as low as possible, in order to minimise interference problems between the mid-woofers?
* Will a smaller waveguide such as the Eighteen Sound XT120 be preferable for a higher XO point (~2 KHz)
* Are there any fundamental flaws to this approach?
Thanks in advance,
PS: I'm stuck in a total lockdown/quarantine situation. I can't access my PC which is in my studio, in which I have WinISD - the only speaker design software I'm familiar with... Pity there seems to be no similar software for Mac...
Diy Subwoofer Amplifier?
I'm interested in building a DIY two channel, stereo, external subwoofer amplifier that can easily power up to two 12" subs at moderate listening levels. 200-300W RMS per channel? Balanced inputs would be nice.
I'll be using mDSP to integrate into my stereo system.
I'm looking for the ability to play around with different passive subwoofers in different enclosures mix and match with different speakers.
I've been looking at HypeX module's, icepower at PE, plus a ton of others and I have absolutely thoroughly confused myself.
I've never built an amplifier before so I would like something on the easier side, my electronic skills are limited to a few computer builds, a couple of sets of crossovers and general around the house/farm electrical work.
If anyone has any suggestions where to start, links to good proven designs, or any advice in general I am all ears.
Budget is around $500 or so, less would be great, more if necessary.
Thanks.
Best CCS for 15mA & output transformer
I have a SE triode headphone amp based 5687 actually with OPT air gaped so no output cap.
I want to use cascode CCS in place of OPT load, I have DN2540, IXTP 01N100D & LND150 so I'm looking for the best suited CCS for my needs: what upper or lower position device, etc.?
Also I need to use the OPT to reduce the output impedance but I have doubts if I need an output capacitor between the CCS & the output gaped transformer, if yes how can calculate the value?
TIA guys.
Restoring the TDA8920TH from Philips Stereo.
So I want to restore the amp and PSU that I took out from an old Philips FWD750, I just want the aux functionality but I realized the aux inputs to MUX which send the signal and receives it back from another circuit board to communicate with IR sensors from the remote, I am planning to get the output without sending the signal to the other board just using the PSU and the main board. My initial Idea is to simulate the orginal layout in KiCad and try and get the output signals, however I can't find the Pspice model for TDA8920TH is the simulation neccesary or I can get the output just via inspection and changing or adding some circuit elements?
Damping 1960s console speakers
I have a pair of 12" Sears Silvertone cabinets that match a 6BQ5 Silvertone stereo receiver. They're nicely made as in they're furniture like and built to last, but they're pretty resonant, especially in the mid-bass. Rap on the cabs and the woofer baskets even give a pretty good ring. I'm planning on replacing the speakers with full range Fanes, but I want to at least get resonance down to kabuki speaker levels.
They're only one cubic foot, so I want very thin and efficient damping. I was thinking Peel and Seal and/or Dynamat stuff. I like the idea of self-adhesive products. And some fiberglass batting on the floor of the cab. Am I barking up the right tree? Are these even tameable? Any way to brace them without woodworking skills?
2 x 3 way boombox.
Hello all
So I know there are a zillion of topics about it but all being very specific and different from the one i aim to do, I am posting this thread. This time I dont want to go for a cheap option but more mid prices (budget 300 to 500). I have few issues I would need help with, which are as follow:
1 drivers:
I picked them according to qts, frequency range, fs and overall sizes and if i had the choice, design.
- 2 x DS-115-8 Dayton or DA-115 both 4"
- 2 x HiVi b3s midrange 3"
- 2 x Goldwood GT510 1"
2 cabinet
Horizontally stacked design with separate enclosures for bass of 25mm baltic birch plywood or maple
Size: h: 35cms L: 50 W:35
3 radiators
2 x 3" woox radiators
4 amplifier
1 x tda7492 upgrade to 2.1 later with a 4 output amp from Sure. Will bridge 2 channels with a xo to create a subwoofer channel
5 crossovers
Chinese stuff for peanuts according to answers here.
6 power and electronic
1 x dual VU meter
1 x UPS system with 12v witb 7000 mAh
1 x phone dock (optional)
1 x bluetooth receiver with usb and sd card
1 x battery charge meter
1 x odroid board (optional)
The problems/questions i have are:
If i dont align the speakers putting high and low together on each sides and mids in the center, will it have a big impact on the sound quality ?
Do i need to enclose the mids?
Can i enclose the bass into a sealed box with radiatore pushing out into a flat tunnel towards the side leaving the mids and high in the rest of the box in br?or ported?
Will it need bracing?
Is the volume enough?
Fastening using the factory screw holes or a pointy thingy pressing the driver against the bafflee
Thank you all for your help
I got more but it will come as i buid. I am not a full on noob I actually build speakers for over 10 years but passive and i just dumbly followed schematics and never bother with doing the engineering and all i self engineered i got super lucky it sounded decent (when it did... which wasnt too often)
Also, anyone knows a free program to mske a 3d model? Preferably pn Linux
Comparison Of 2 Pole Compensations
Why to use 2 poles instead of one? On the contrary what people think , it has nothing to do with the stability, but the purpose is to widen the open loop bandwidth. Very grand majority of designers don't give any attention to this aspect, after all there are one thousand and one opamps with open loop bandwidth of few hertz and they have the reputation of excellence. So why to bother about open loop bandwidth?
The first aspect is to have a uniform NFB applied to the whole spectrum, same treatment to all 20-20khz without segregation.
The second aspect comes from tube amplifiers. In Williamson for example the OL bandwidth is 10khz limited by the OPT, 20db NFB is applied . With large OL bandwidth , on the transient of the input burst , the phase starts nearly what it will be on steady state . Whereas in very low OL bandwidth , it starts with -90° phase shift to reach gradually to that of steady state. This phenomena , provokes transient distortion if multiple voices burst at same time interval. To hear what I mean ,listen with a low OL the requiem of Verdi YouTube . With my aging ears I can clearly hear enhancement to 30khz OL bandwidth my be a sensation to 40Khz but above I don't think is necessary , but if can why not.
The VAS circuit that will be submitted to all kinds of 2 pole compensation techniques has OL bandwidth of about 4khz, to widen it to at least 20khz.
attachment.php
There are four different types of 2 pole compensation I found . TPC,TMC,Cherry NDFL and dadod's OIPTC. I will try all of them , and evaluate comparatively.
If you have suggestions to try out this or that , please be welcomed .
Hayk
Bias on Aragon Palladium
I have just bought a pair of Aragon Palladium’s- the original version from the early ‘90s
Would just like to give them a small service with an adjustment of the bias current an a change or cleaning of the speaker relays.
I can’t seem to find any info anywhere about the alignment procedure - so I would be very happy if any of you could tip me on where to find the service manual ? 🙂
If I decide to change to caps in the power supply or maybe a full recap - what would be a good brand to buy and would it be safe to go 20-30% up in capacity?
USB sound card's EEPROM reading/(re)flashing
I have a simple SA9023 USB-to-Optical/Coax converter.
The story below is not too important though, I would need general understanding first
While trying to use the converter with Raspberry Pi I faced several USB related unstable "miracles", the converter perfectly/stably works with PC though. I suspect the converter EEPROM content is not consistent enough (there are some null string descriptors in there at least).
Maybe there is a chance to fix that, but looks like I just don't understand some basics to move forward. Would be happy if somebody could navigate me a bit.
So some general subjects I would like to understand, rather general than the device related.
Unfortunately I'm newbie with that.
1 A USB device has a chip (SA9023 in my case) and (SPI/I2C) EEPROM. Is there a way to access (read/write) the eeprom via USB. Or it could be only possible via a standalone programmer with a clip connected directly to the eeprom?
I know that some USB devices allow the underlying eeprom programming via USB registers. Sometimes it's briefly documented, but usually not.
Actually almost any USB device has a chip + eeprom, so the eeprom content (initial at least) population should be performed anyhow and it should be technological enough (for manufactures). It's hard to imagine a "man with a clip" in a factory.
Maybe there is just a common approach I'm not aware of. Or it's a vendor/device dependent "zoo"? The datasheets are typically silent at this point.
2 A modern USB device typically has a chip + eeprom. So there is a reason to believe the eeprom stores not data only but code for internal processor as well. It's hard to believe the chips are not universal enough as there is a lot of various devices based on the same chip.
However the datasheets include nothing about the processor, its type, commands set, internal registers, peripheral addressing, ports etc. Could it be it's just too common and well-known? So no information is available unconditionally and I'm just not aware of.
Anyway such firmwares were developed anyhow and (most probably) developed independently from the processor core, So the information should exists somewhere,
Could it be there is just a kind of "8051" processor inside and everybody know that excepting me? It's hard to believe every USB device manufacture creates its own processor to produce the device. Is there something to start reading from?
Wood combination for 3 way speaker
I have designed 3way home Hifi speakers
- inner net volume 150l
- 12'' woofer
- BR tuned to 22 Hz
- MTM
- 3 braces vertically (tolal height 1200mm)
- SPL 1W 1m 94db, RPM input power 120W
I would like to make the design similar to CANTON 1.2 DC but with only one woofer.
My idea is:
1. milling solid wood for front baffle 45/25mm hard wood
2a. 22mm MDF otherwise
2b or 20mm MDF + 2.5mm HDF (with some veneer)
It combination of solid wood with MDF (or MDF+HDF) good Idea or
make it completelly from solid hard wood?
Thanks for any suggestions.
Peter.
Alpair internal cabinet reflections
What frequency range tends to be most affected by internal cabinet reflections in a shallow enclosure for the Alpair metal line?
I am hoping cross over at 4th order HP @ 300Hz on an Alpair 5.2 and I am wondering if I am avoiding some of the trouble area or if the frequencies into the lower mid-range and above are most affected?
I am aiming for 5" internal depth in a wall-mount cabinet. There will be an LDW7 in the same cabinet but it will be in an isolated compartment.
DIY Cheap Car Amp: SMPS from broken amp + TDA7294 Chip amp boards
Several years ago I picked up a used broken Sony Xplod amp Model XM-2185 GTX rated 165W x 2 into 4 ohms. Poking the volt meter around I discovered that the SMPS was still pumping out around +- 38 volts DC. But could not figure out what else was wrong with it. So I tossed it to the side for another day.
Flash forward to another day and I have a co worker who wants a cheap car audio upgrade for his newer Nissan Versa keeping the stock head unit. Well let's see what I have laying around the house: How about what I picked up a while back at one of Part's Express buyout/closeouts: 4 ohm Peerless SDS woofer Peerless 835004 SDS 6-1/2" Woofer 4 Ohm | 299-250 for like $10 each. Plus some tweets and a leftover crossover (I have active in my car) and I have half the problem solved.
As for amplification. Well, what can I do with the old Sony amp with working power supply? First, I got lucky and found the service manual: Sony XM2165GTX Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics It's using a TL594 as SMPS controller feeding 6 power MOSFETS (FKV550N) 3 each leg. Specs on the MOSFETs say 50v/50A. Also from the look at the PC board and the circuit diagram, I could cut the board in half and have just the SMPS with a single row of the MOSFETs plus the two double diode rectifiers all sharing the one side of the heat sink/case. So I decided to cut the board and the metal case to provide heat sinking as well as protection. I also wired the +- DC output to what were the normal speaker outputs for one of the no longer used two channels. I'll post pictures of this abomination later. Yes, its pretty fugly. Edit: As promised, don't laugh:
(Above: Pic of split Xplode amp with SMPS power coming out front previously speaker terminals.)
(Above: Bottom view of SMPS with homemade plexiglass cover.)
(Above view of SMPS portion of XPlode amp) Soon to painted flat black and hidden.
Now I have power, what can I do with it and on the cheap? How about a chip amp? A little ebaying brought up a pair of TDA7294 boards assembled from China for like <$17 including shipping. Can't beat that!
So I've been wondering about heat sinking the chip amps and mounting the resulting mess in this guy's car. The solution I've come up with is building a shelf under the rear deck (in the trunk) to hang down at most 3 to 4 inches to hide the ugly SMPS amp and the chip amps. As for cooling, I have a big old CPU heat sink from a Dell that was being tossed at the office. Looks like:
I probably could put both chip amps on it, but I'm going to pick up another heat sink just like it (from ebay). So my plan is to have the old SMPS power supply on one side of the shelf and on the other have two of these heat sinks on their side with a 80mm (or so) case fan blowing thru the two of them. I also have a couple extra surplus big 'ole electrolytic caps like 30,000uF @ 50v to shore up the wimpy 3 x 2200uF per leg caps on the original SMPS board. Of course, mounted externally to the SMPS since they are kind of big.
My thinking is on most car amps the SMPS and all channels being amplified are all on the same heat sink/chassis. Splitting the SMPS from the amplification would reduce size (two smaller thingies are easier to hide/install than one big one). And the split would run cooler since the heat is spread and separated. Putting the chip amps apart from each other would also help.
I'll probably share this project with the guys over at DIY Mobile audio as well. I have a spreadsheet with the totals I have spent on this project which includes new 8 gauge power wire, fuse, ring terminals, 3 sheets of RAAMmat deadener. Total so far is under $150.
Hello from U.K.
Hi .. :wave:I’m a Mechanical Engineer by trade ,:yikes: but interested in the DARK ART of electronics ..😕
I Currently have a valve audio system consisting of Audio Innovations - second Audio monoblocks , with Boarder patrol PSU’s fed from Series 1000 pre amp and Series 1000 SUT from my custom built turntable that is based on Lenco mechanics, and fed from a variable PSU that I built , albeit from a BOM and instructions..:wrench: My system sound great to me and I couldn’t be happier with it even after 8 years ..
however I like to build things .. and I would love to build my own amp ..
as always though I want to just straight in the deep end .. and I want to build something that I will want to use , instead of my AI set up , so it must look and sound as good or better ..
Coupling cap voltage rating
Hi Guys,
I have a query regarding the voltage rating for the output coupling caps for an aikido preamp.
I am not yet knowledgeable enough to figure out what voltage would be present at the output.
It looks to me like there would not be a large DC voltage present between the top grid and the bottom plate of v2 since the bottom plate is not exposed to the B+.
Based on this assumption it looks to me like a 250v k42y-10 cap would be safe for use here.
Am I dumb and/or wrong here?
Diode matrix Music keyboard
I know this isn't exactly Audio but It is in control of the source. This is the MCU for a diode matrix for keyscan in a Yamaha P-85 digital Piano. Multiple B and C key keys were dead. I have beyond doubt determined the missing signal to be on conductor n15 pin 23 of CN301. My problem now is that I do not know how to check for key return. I believe. I need to use my scope but I need advice.
fasteners used in old Pioneer valve amplifier
Hi all,
I'n new to the group, recently joined to seek some information on my current project.
I'm in the process of rebuilding an old Pioneer SA-400 amplifier and am having trouble identifying the fasteners used through-out the unit. They're not standard metric threads, though the verniers measure the diameter of the 2 sizes used as 3mm/4mm. most of them are self cutting screws, but even the ones that aren't have the same thread.
They don't seem to be BSW or UN threads either. I've been down to the local screw shop and they are also unable to identify them.
is anyone able to help identify the screws?
thanks.
Solid Wood Baffles with MDF/Ply boxes?
Hello,
What have been peoples experiences/thoughts on combining solid wood baffles with sheet good (MDF or Ply) boxes?
My 30+ years of woodworking experience tells me that such a large cross grain joint is a bad idea that can only end with the baffle splitting. Yet, I have seen countless examples of such construction posted on the Interwebs.
I know one thing that would help for sure, and that is "ripping and flipping" the wood, so you end up with a quartersawn baffle (of all the lumber cuts quartersawn has the least amount of movement).
Are people getting lucky?
Is it that we live in climate controlled houses where the humidity is fairly constant?
Has anyone, for example built a pair of speakers in Nevada (low humidity) and then moved to Florida (high humidity)?
Is it that the modern PVA glues that we use have some "give" to them?
Are there any guidelines people have used for how wide a solid wood baffle they would on an MDF/ply box?
Does the thickness of the baffle matter?
Any failure examples where the baffle did crack?
What about where the baffles were a glue up of layers of plywood? With this type of baffle, you would think there would still be movement as the layers are not constrained in their "thickness", just in their width and length.
What are your thoughts?
Thank you,
David.
Midranges for synergy horn
On my (long) list of projects to tryout there is the synergy horn.
So today I was searching for what kind of mid drivers would work in a synergy horn.
EBP should be as high as possible I think and the driver shouldn't be to big to get a good cross over frequentie.
So what would you guys recommend.
the Lavoce FSN030.7 doesn't look to bad I think. 3" and EBP=351
4 of these drivers will do something I guess.
Faital Pro 3FE22 doesn't look to bad either EBP=220
Then I also found the beyma 3FR30ND with EBP=324
That's what I found for 3" drivers.
maybe 4" could also be possible.In that case I found the following drivers:
B&C has the 4NDF34 with an EBP of 393, a decent power handling and Xmax also.
Then There is also the B&C 5MDN38 but this is already 5" and probably to big.
For the compression driver I am thinking of the PRV audio D290 as I had very good experiences with them.
For the low section I haven't decided the size yet. Will be probably 10".
Any advice is welcome
Tube rectified PSU
Hi .... I’m looking for some advice ( “don’t do it “ is not an option ) :cloud9:
Some background ..
My current Audio system consists of Audio Innovations second Audio Monoblocks , with Bp PSU’s , fed by an Audio Innovations series 1000 pre amp , and SUT .. .. my system sounds great to me ... and I have been over the moon with it for the last 8 years .. but I want to build something myself.. it must sound as good , preferably better than My current system and have a visual impact .. so ...
I am thinking of another SE set up , with a separate PSU based around valve rectification ..
I have a pair of NOS 866a MVT Which I want to pair with 2 x 6ax4’s , this will give the visual impact ( well aware of the pitfalls of MVT’S )
Then on to the amp based on 300b’s .. . .
There are lots of amp schematics out there to use , it I cannot find a PSU schematic based on 866a’s ..
Has only one got anything they can share please ?
Cheers Brian
Thoughts on making J-FET Preamp of a 2N5546
Hi
Ive taken apart an old oscilloscope and found some interesting old gold pin BJT and JFETS (and some opamps i havent looked into yet.
I have built a JLH 1969-ish clone before and a normalt simple BJT preamp, and been tinkering with electronics a alot, but not in audio very much.
But I would like to try this as an input stage to JLH or maybe a separate preamp.
It beaing a dual jfet should mean they are pretty well matched up?
It is a 2N5546 that a find most appropriate of what I have.
Link to datasheet: 2n5545-7.pdf PDF datasheet. ALL TRANSISTORS DATASHEET. POWER MOSFET, IGBT, IC, TRIACS DATABASE. Electronic Supply. INNOVATION CATALOG. Service
I have done alot of searching and havent found anybody using this, I read up on what resistors etc would be appropriate i believe. But what I just seem to not find any good info on is what makes a particular JFET good for audio purposes?
Is it even probable that a osciloscope jfet would be of any use? It was a crt oscilloscope but i dont believe it was part of that circuit but somewhere near the inputs.
Sorry if any grammar is messed up, english is not my first language.
Would very much appreciate some tips in the right direction.
Best regards,
Lars
The Audio Interface Phono Pre
This is something that I have been working on over the last week or so. The inspiration comes from an USB audio interface - a Tascam 2X2. The preamp section has always produced very subjectively satisfying results. It is also works well both balanced and single ended.
A while ago it one of the analogue inputs died and in order to fix it without a service manual I had to trace the circuit of the preamp section. For all of the Tascam marketing that made a big deal of the discrete, low noise, high gain, high dynamic range preamps it turned out that really it was a fairly standard mic preamp circuit. This inspired me to look into the idea of using a similar kind of circuit as the front end of a phono stage.
I have to openly draw attention to the fact that what I wanted was a relatively simple circuit. so I could have as much design input as possible. Also something quite flexible being both for balanced and un-balanced MC and MM cartridges without separate circuits for both. This would mean that I would have to have some compromise on outright lowest noise and distortion but I still wanted decent performance.
This is the circuit so far:
There a a few things that I still haven't wrapped my head around fully yet. One of these is he input transistors in parallel. I have gone to some effort to learn how to model the noise accurately in Tina and believe I have done this correctly. Paralleling 3 common garden 2N4403s in the LTP does seem to provide some small benefit and as it stands the circuit does seem to have decent S/N. I plan to look into other transistors in parallel, hopefully modelling these in Tina.
MC frequency response is pretty flat. The roll off at the extremes is intentional. Although these is content at these extremes I would argue that there is no musical content. I find that some roll off of lowest frequencies has a subjectively positive effect. Also I find that some roll off of the highest frequencies seems to help suppress pops and clicks a little.
MM response has a slight rise as you increase frequency but this is only around 192mdB and I doubt that it would be audible.
Distortion at VF2 and VF3 is 0.035 for MM and 0.045 for MC. What I have yet to work out is why it's around 9% at VF1. I have always had similar figures for other simulated phono amps that have worked fine. I guess I am not simulating the test properly.
The shown gains are not correct. This is caused by the inverse RIAA macro, which is based on a passive RC circuit.
Although I have designed the circuit overall I should mention that the input stage is based on an ESP Audio circuit which was uncannily similar to the Tascam circuit. However, I feel that I have done enough overall to call it my own.
I've yet to work out how to simulate the distortion properly for phono stages. It seems like the RIAA network throws everything off.
Also can't work out what caused the very slight deviation in the RIAA curve for MM cartridges.
Single FR on huge OB?
I have my Alpair 7p sealed in a pine box with MDF for the front baffle, I have to buy a big sheet of MDF to replace the pine in the cabinet.
This sheet would be enough to try out some 1200x1200mm open baffles.
Before, a 500x700mm MDF open baffle sounded way too lean with the 7p.
The larger baffles would push the roll off point down an octave to 200Hz, which is gonna help a lot with that.
Will it be enough? not sure... I was totally satifisfied with bass quantity from the sealed 7p and the quality was excellent.
What are the implications of using a huge baffle like this, most importantly on the mids and highs? is it a waste of time? (assume more would do it otherwise)
ART Pro Channel Mic Pre noise troubleshooting help. Schematics, MP3 & Pics.
Hello everyone.
I have an ART Pro Channel mic preamp that has developed an issue that I'd really like to fix.
I've tried to be as thorough as possible, sorry for the long post.
Here's the problem:
When the Preamp Output knob is all the way counterclockwise or off and the Gain and Master Output are set to to 0dB (12:00, these exact settings don't really matter, this is just for example), the unit is quiet. As soon as the Preamp Output knob is turned clockwise, serious hiss (or "sshhhhh") is heard through the output. As the Preamp Output knob is turned further clockwise, the hiss gets louder and louder until the knob gets to 0dB or 12:00. Then, as the knob is turned further clockwise the hiss decreases until it is fully clockwise (+10dB) at which point the hiss goes away completely.
Also, if a sound source is plugged into the input, you can't hear it over the hiss until the Preamp Output knob gets to about 9:00 or -8dB. As the Preamp Output knob is turned further clockwise, both the input and hiss get louder until about 12:00, then the hiss decreases as the input continues to increase. When the preamp knob is fully clockwise you can clearly hear the input with no hiss.
One other interesting observation is that when the VU meter is set to "Preamp" & "Internal" via the 2 front panel switches, the dial immediately pegs hard right and no knobs have any effect on this.
I have attached both of the schematics.
Here is what I have done for troubleshooting thus far:
1. Visual/smell test. Nothing looks or smells burnt. None of the caps appear to be bulging or leaking.
2. I have swapped out all of the tubes and this doesn't change anything.
3. Measured the +/- voltage of A7 on pins 8 and 4. These are stable +/- 15V
4. I have measured the values of the Q20 transistor (TIP112). A youtube video suggested this is a common source of problems.
Base: 48.43V
Emitter: 47.44V
Collector: 61.03V
3. I have measured the input and output of the U1 Voltage regulator (L7815CV).
Input: 20.7V, Output: +15V
I would have done more measuring, but to get to the bottom of the main board, I have to completely disassemble the thing and make some sort of test fixture. I will do this if necessary, but I haven't yet.
I have also attached a recording of what the noise sounds like. At the beginning of the recording the Preamp Output knob is fully CCW. I then turn the knob fully CW 🙂03 - :10). You can hear the hiss increase then fade away (the hum is single coil pickup hum). Then I turn it fully CCW 🙂12-:16). Next I turn the knob clockwise after playing the top 4 strings on the guitar. You can hear the noise increase and then disappear as the guitar gradually comes through.
Finally, I have attached a picture of the front and inside of the unit.
It seems to me that the source of the problem is right after the Preamp Output pot and before the Compressor, EQ and VU Meter. This leads me to think that the most likely culprits are either or all of the following: C43, C48 (22uF 25V) and/or A7 (NE5532). Because the problem disappears when the Preamp Output pot is cranked, I'm leaning towards C43 and/or C48, but this is purely a guess. The fact that the input is clean when the Preamp Output is cranked leads me to think it is not the 5532, but again, this is pure speculation.
Does this noise sound characteristic of a certain type of component failure? Does it sound like one or more of the opamps is faulty? Does it sound like a faulty electrolytic cap(s)?
Would anyone be willing to take a look and offer some insight and tell me if I'm on the right track or completely out to lunch? Does anyone agree that C43,C48 A7 are the likely offenders?
If not, could someone point me in the right direction?
Any and all input would be greatly appreciated.
Thanks for looking.
Origin of Unknown amplifier.
Hi Guys, I write you because I wanted to know the true origin of this amplifier which is known Pioneer Amp here but I don't think so. It is very used for home audio in these places and its sound is not so bad but some improvements can be made to this amplifier for best performance. I leave the scheme which is in your hands and suggest about it. Thanks for your attention.
W5-2143 vs Peerless NE149
Anyone done a comparison of these two drivers run full range? While the NE149 is marketed as a midwoofer, the published response shows it is quite capable of fullrange operation.
The NE149 gets a lot of praise from multi way users as some of the finest midrange quality, high end SEAS and ScanSpeak reference from a drive unit less than half of the big boys which is what started my query.
There is a rise in the response of the 149 centered in the 8khz region on axis but I wonder if that can’t be smoothed out with baffle location? Is there any way to simulate that?
I do see the off axis response drops like a stone above 10khz but that’s perfect for me as I intend these as nearfield monitors
I do believe by the specs the 149 to be the better for LF extension unless someone knows otherwise?
Thanks again!
DX Blame MkIII - 2013 builders thread.
Still4given and I decided to start a new thread for those building the DX Blame MkIII, an amplifier designed by Carlos (destroyerX). Although there is an existing builders thread started in 2011, it has grown to almost 2000 posts long and is difficult to navigate.
New builders are encouraged to assist each other by reading through the original builders thread and posting relevant key information here.
I will update this thread index with links to the latest schematic, board layout from recent group buy, and latest BOM.
Original thread documenting the development of the DX MkIII:
http://www.diyaudio.com/forums/soli...me-mkiii-supercharged-will-soon-released.html
Previous builders thread:
http://www.diyaudio.com/forums/solid-state/193759-dx-blame-mkiii-hx-builders-thread.html
Recent group buy:
http://www.diyaudio.com/forums/group-buys/239084-blame-mkiii-hx.html
Byron and Terry's BOM (UPDATED 21-09-13):
diyAudio
Time to build
After a very extended break due to ill health I'm finally ready to build my speakers.
Drivers are:
Faital Pro 15FH510 for bass: FaitalPRO | LF Loudspeakers | 15FH510
B&C 10MD26 for mids: B&C Speakers
Faital Pro HF144 for highs: FaitalPRO | HF Drivers | HF144
The room is as per the attached image (measurements in cm). Bay is 72cm deep? Speakers will be located either side of the bay window.
I'm hoping to split the frequencies at 200 and 1500 to start. Ill use a minidsp 2x4 to play around with to start and may progress to 2 2x4HD if i like the sound. Either that or start the laborious task of passive xover.
I have a 4 by 2 multicellular horn for the HF144 to start with. I'd like to play with other horns, JMLC for example but this will do to start
The 10MD26 will be sealed into a Nautaloss spiral as per xrk971 design - The Nautaloss Ref Monitor
The mid and high units will be firing down the length of the room away from the bay window wall. I would like to try them in the corners to start.
The bass is the only real question I have. There are two options.
Option 1: build cabinets to fit the corner (max WAF outside of option 2) and reduce the output to deal with the loading
Option 2: we are building a small booth (2 benches and a table facing each other across the bay) into the bay window. The seats could quite easily work as cabinets for the 15FH510 firing down the room.
I've included some enclosure sims for sealed and ported designs. I like the sealed as it gives extension at the loss of max achievable bass in the vented cab.
My system technics sl1200mkii with Denon DL110, various phono preamps, mac mini with various format music (minimum being AIFF 16/44), hifimediy asynchronous usb dac, B1 Korg, ACA of various types, Peter Daniels F5, MOFO and F4 to come.
I listen to anything, as long as i like it, opera to rock, techno to baroque, lone female vocals to concerts. I like to hear details (only if their in the recording obviously) the breath of the singer, the bow on the strings, skin on the strings.....basically the little things that make the whole. I love speakers that kick, sharp and hard and I'm not averse to loosing out on the lowest bass to get the tightest bass.
Hope this is comprehensive enough. Let me know what you think
JVC-95 3 way ported
First post.
I have a pair of JVC SP-95 speakers that came as a combo Kit for some unknown JVC equipment. Cheap speakers I know but there large 3 ways and ported with a 12 in. full range woofers & 1” tweeters, 3”mids. The tweeters & mids failed, they have been replaced with a Peerless tweeters 4 ohm & Goldwood mids 8 ohm. The woofers are 8 ohm also. I also re capped the crossovers with the same uf value caps that were originally on the crossover. The woofers & tweeters share a 1.5 uf cap & the mids use a 6.8 cap & both caps run through 2- 3.3 Ohm sandcast resistors. Pretty simple crossover. Problem is the tweeters are not bright enough & the mids are almost nonexistent, l can’t hear the mids. The woofers work great, lots of bass response. I made a mistake using 4 ohm tweeters, would they improve if I replaced them with 8 ohm tweeters? What kind of cap would bring the mids back to life, the 6.8 cap isn’t right for them. Some kind of ball park uf value for the mids would be great to know. Thanks for any info.
Contracted synergy fever
After a few years of researching different designs, including the monkey box classic 3-way, "cornscala" builds, and the beyond the Ariel design, I decided to try building a synergy horn. With the help of the excellent synergy calc spreadsheet by Bwalso, I got the confidence I could actually build these. There are many others to thank for their contributions to the other various synergy threads such as Weltersys, xkr971, Patrick Bateman, Mark100 and others. And I can't forget Tom Danley for sharing his insight on his brilliant design.
The start of much sawdust making...
SE 5W MOSFET CFP
here is my take on simple low power 5W class A amplifier. Inspired by ACA I wanted to have lower distortion and higher damping factor then ACA.
Amplifier sounds better than ACA. More resolution, more dynamics, better bass.
Happy listening!
  • KiCAD_SE Class 5W.zip
5 cubic foot Sealed, best driver?
I see a post from 2013 which is basically the same question. But a lot can happen in 7 years.
I have some of the wood cut for a pair of 5 cubic foot (gross) sealed cabinets. The interior dimensions are 20.5" cubed. I will be mass loading the top, sides & bottom of the cabinets. 1-1/2" baffle. Perhaps some bracing for the rear, which will depend on whether I use a plate amp or an eternal amp. Interior will have a liberal amount of Rock Wool.
The project is "designed" around the Ultimax 18. However before I bought the drivers I thought I would see if there were other drivers I should consider.
The main purpose is to deliver wooferage to my 15'x25'x9' HT room. My fronts are full range which I high pass at ~30hz. To be more precise my fronts are Magnepan MMGs sitting on top of a pair of GR Research OB "W" 12s. They will reach down to below 20hz, but when doing HT, at a reasonable volume they will occasionally make a nasty cracking sound which I interpret to be them bottoming out.
I alleviated that by raising the High pass. I never have a problem with any music.
So I am building these subs to mainly do infrasonic to ~40hz. Is there anything in the price range of the UM 18 that I should look at?
100W Quad EL34 Scratch Build Project
Having, as most of us, found myself with a lot of free time on my hands, it seemed a perfect opportunity to finish a project that I started about three years ago.
General advice for building a valve amplifier is to start small, ideally using a ‘make-your-own’ kit. I have not done that. Not even close. I’m kicking off my sojourn into homebrew audio electronics with a 100W bass amp using Partridge transformers salvaged from a Carlsbro TC100, with a circuit and chassis of my own design. This is my second attempt at this undertaking. The first edition has sat untouched on my desk for the past year serving as a fluctuating source of agitation that would peak when upon watching my ex-girlfriend’s eyebrows reach escape velocity when I told people that I was working on it. Yes I’m ******* building it Jenny.
Here's the design:
Everything before the phase inverter is likely to change as I build and test, so pay it little mind. This post will mainly be my reasoning for the power amp and power supply. It's a bit of a wall but I find it useful to write out my thought process. I've mainly followed Merlin's methodology for designing a PP amp. I welcome you to point out any daft mistakes. I'm a first-time builder diving into a project way beyond my ability level. It's an inevitability. I have already highlighted three queries that I would greatly appreciate assuaging.
I have actually started buidling the amplifier; it's just taken me this long to get around to writing up this post though I'm not too far along to not be able to adjust the design so again, I ask for your honest critique.
Naturally I don't have any information on the transformers. But I do have a variac and a multimeter... The average voltage ratio was 17.6, the square of which, 311.2, is the impedance ratio. Given that these measurements were taken from the 16 Ohm output tap that gives us a primary AC impedance of 311.2 * 16 = 4980R which we can safely round up to 5k.
My mains voltage today was a toasty 236.5 Vrms, which presented on the secondary of the power transformer as 357.2 Vrms. Once converted to DC by four UF5408 we should have a HT voltage of 357.2 * 1.414 - (2*1.7) = 501.8 V however the measured voltage is actually 494 V. Any ideas? The amp that the transformer comes from has a HT of 470 V so the measured value is closer but still much higher. Is this because I've taken the measurement with no load applied? When taking the measurements only the bridge rectifier and reservoir capacitor were hooked up. For the time being I'm going to assume a HT voltage of 480V as it's a happy medium between the HT used in the amp that the PT was pulled from and the measured voltage.
The impedance 'seen' by the tubes in each class of operation is therefore:
Class A = 480 V / 2500 R = 0.192 A
Class B = 480 V / 1250 R = 0.384 A
I spent far longer than I care admit wondering why drawing load lines using these values put the operation well outside of the EL34s maximum thermal dissipation until remembering each side of the power amp has two EL34s in parallel. They each supply half of the current!
The maximum thermal dissipation at the HT is 25 W / 480 A = 52 mA. I'm aiming for an initial biasing point of 75% of this which is approximately 40 mA. This necessitates a bias voltage of 20V. Which brings me to question two - the schematic for the TC100 shows a bias voltage of -37! which seems way too low. Am I misreading the schematic? Could I take from this that my measurement of the OT impedance is incorrect?
The current flowing in the screen-grid dropper resistor will be the grid current of the four EL34s plus the preamp valves. The datasheet suggests a 20:3 anode to screen current ratio, so = 40 ma * (20 / 3) = 6 mA screen current per EL34. The preamp valve complement is an ECC832, ECC83, and ECC81 with respective typical current draws of 20 mA, 2.4mA, and 11.7 mA. The total current through the screen-dropper is therefore (6 * 4) + 20 + 2.4 + 11.7 = 58.1 mA. This is a fair whack of current so I've chosen a small dropper value of 100R to limit the voltage drop to 58.1 mA * 100R = 5.81V.
The screen stopper resistors are 1k so they will also drop 1k * 6 mA = 6 V. The final screen voltage will therefore be 480 - 5.81 - 6 = 468.2 V, a good 18 volts above the EL34 maximum screen voltage of 450V. Is my HT too high? Do I need to increase the size of the dropper resistor to drop more voltage? Or can I leave it at this value expecting the voltage to sag when under load?
That is it for today. Tomorrow I'll start posting build progress pictures. I'll be including any mistakes and how I managed (or failed) to rectify them for both educational and entertainment purposes.
putting an amp and speaker inside an acoustic bass
I'm trying to get enough power to bring an acoustic bass guitar to be heard with acoustic guitars. I'm thinking of the Smokey amp plugged into a 10" speaker mounted to the inside back of the guitar and maybe opening up a port hole or even an f hole on the front. Just enough to raise the db level from unamped at around 60db to 100db. Any thoughts?
Champ 5C1 with equivalent tube options
I am thinking about building a Champ 5C1 clone based on a schematic mod I found which added NFB to the circuit almost like a gain pot. There was an audio file where he played the amp and demonstrated it and I got the schematic from him a while ago. I want to build it so I have multiple tube options as listed in the attached schematic.
Before I dig into this I wanted to see what you all think about the viability of this, I assume they are not all simply just drop in replacements, even though I see them called equivalents, and some switching may be necessary to set bias and other levels appropriately.
Sonic Frontiers SFP-1 Phono Stage
I have this idea of using a JFET as a Phono Head Amp for my MC Lyra Lydian cartridge (500uV).
Currently I use a Musical Fidelity The PreAmp A3 (shunt power regulation, LM394 BJT matched pair head amp, and VQ1000J MOSFETs), and I want to beat it.
I know that one AD797 IC as it is based on BJT's can give better S/N ratio, but I don't like to see so many transistors in the signal path... I want a minimalist design.
And why not mix JFET with Tubes?
First time I saw this design was in the 90's from Sonic Frontiers, when I used to buy quality components from The Parts Connection.
So, I share here the Sonic Frontiers SFP-1 Phono Stage schematic (partial, due to upload space constrains) so you can comment on it.
The JFET in use are marked as J310. Anyone have information on this one?
+B1 AND +B2 = 210VDC (for the 12AT7 output tube and 6DJ8 RIAA driver)
+B3 = 187VDC (for the JFETs)
Cheers.
Microphone effects loop with blend knob
Hey there good people,
I'm wanting to build a circuit for live use for vocals, and looking for some suggestions.
The gist of it is basically, I need something with a microphone input (it'll be used with dynamic mic), then feeding an effects return/send which will be hooked up to guitar pedals.
Would like to integrate a wet/dry blend knob in.
Lastly, feeding a mixing board, so line level output.
As of right now, I'm looking at the THAT Corp chips for both a preamp, and line driver output.
I'd assume the mic signal coming in needs to be boosted via preamp to an instrument level, fed to the effects loop, then converted to line level.
Do I need something to make up the gain after the wet/dry blend?
Open to all suggestions. All this running on a 9v supply would be ideal, but beggars can't be choosers, so open to anything.
Center Channel Stereo Tube Amp
I have seen that some stereo amplifiers from the 60s have a central channel, such as the Fisher X101D, or the Scott LK79, among others.
I know it is a connection between the 2 secondaries of the output transformers to run a third speaker called the center channel, I have seen the circuits and understand it, but I would need someone to technically explain how it works.
Thank you so much
Gusmore
LLC design review
Hi
After a long break from the project I want to push it a bit further toward a finalized design (who am I kidding? - like I would ever really finalize/finish anything..).
Design-goals:
  • Input-voltage: 230Vac+/-10%
  • Output-voltage: +/-60V, +/-30V and 12Vdc for a fan
  • +/-30V can be configured as regulated or un-regulated.
  • Power: enough for a single-channel classD-amp @ +/-70V with 4Ohm Load
  • Dimensions: max: 100x100mm pcb
  • Standard doublesided 35u PCB
  • X-former: ETD34-size core from typical ATX-smps.
  • Option for external inductor and split-capacitor for the LLC-tank
  • Prim-sec isolation: min 250mils = 6,35mm
  • Isolation-distance at HV-side: min 100mils
  • Controller: L6599
  • Regulation: TL431
  • Cooling: minimal airflow. Preferebly no forced cooling for normal operation with 8Ohm load at amplifier
  • Disable-input that shuts down the PSU with an isolated 12V input
  • Option for external 12V for L6599 in R&D
  • Temperature-shutdown if mosfets or transformer gets too hot.
  • Designed for amateur hand-soldering.
  • All passive SMD are 1206.
  • Dissapation in 1206 resistors below 100mW
  • Option for over-current-protection: splitcap and/or cap-voltage-sens
Inspiration:
http://connexelectronic.com/wp-content/uploads/2017/09/SMPS500R.pdf
https://www.st.com/resource/en/datasheet/l6599.pdf
Power inductor tester
Transformer:
Its a massive headache to design and construct the transformer so that it works AND is safe to use.
I know that commercial options are avalible, but: a)Whats the fun in that, b)I could not find one that fits my design-goal.
Please dont even consider building something like this without building a test-rig to verify inductance AND saturation-current (see link above)
Earlier post regarding this project can be found here:
Mosfet failure analysis
Heating in LLC HB mosfets ?
Power limitations for LLC-smps for amplifier
LLC simulation
Heating in LLC transformer
Tests performed to verify design:
  • Measure hotspots under load and no forced cooling (Xform and mosfets)
  • Measure voltage-drop and stability at output with pulse-load of 8ohm from Vcc to GND (roughly 8A at 60V)
  • Multiple on/off cycles at mains power with and without load
  • Limited noise from speaker with amp and speaker connected to PSU
Design questions for you all:
  • Is it OK to have the Ycaps before the CM-coil at the input?
  • Do you see any fatal design-flaws?
Pictures attached: First prototype on a double-sided PCB and suggested updated design-files.
Disclaimers:
This design is NOT a commercial design for sale. I'm thinking about offering the design-files for free here. My only worry is that a project like this is potentially dangerous and it will require some skill to assemble a safe unit.
You can buy a perfectly good commercial powersupply! This project should never be build if the only motivation is saving money. While the parts are cheap its very labor-intensive to build and test.
Which audio analyzer software goes above 20 kHz?
I want to do distortion measurements and spectrum/frequency analyses of amplifiers. Mostly you have a 1.0 kHz test signal and you see the overtones at 2.0, 3.0, 4.0 etc. kHz. But I want also to test amplifiers with a 20 kHz sinus and then you get overtones at 40, 60, 80 etc. kHz.
As I see in the pictures, audio analyzer software represents frequency spectra just untill 20 kHz.
Which audio analyzer software can represent frequency spectra above 20 kKz ?? Let's say untill 80 kHz?
Of course under the assumption that you use an audio soundcard/DAC with a sample rate of 192 kHz. The better ones do so.
And which audio analyzers are the best for doing measurements on amplifiers?
Introduction and Pentode CF question
Hi, This is my first post since '04, when I posted a few questions under the name John no nfb, I quickly realized I didn't have a clue what I was talking about, so went back to lurking, anyway fast forward, I still don't know what I'm talking about but now I just don't care if people think I'm stupid! My question is- I would like to see if I can use a TFK RS288 indirectly heated pentode as a transformer / choke loaded cathode follower ( a linestage) really I need to know what cathode resistance to get about 25mA through the device, I plan a floating screen supply, so no screen current through the trans/choke, I will attempt to post some specs and a rough idea of a circuit. Thanks John
ATC SCM11 Speakers for sale
I have a set of pretty much mint ATC SCM11 speakers that I am just not using. Figured I should sell them on.
These are the latest versions, in original packaging with all grills, dust bags etc...
Marks from spike mounting on stands on the bass (not too bad) and a couple of very (very) minor marks elsewhere that you really have to look for. On a set of stands, they look brand new.
I can provide pics on demand but if you want to see them now, you really could just download a stock image. Aside from remarks above, they look that new 🙂
I'm based near Edinburgh. Happy to arrange posting but only in the UK.
Looking for £900.
iep
Sealed Box Subwoofer Dimensions Limited?
Hi All, I hope everyone is staying safe.
I'm restarting my effort to build a subwoofer after pausing my research to move.
For experimenting with Hornresp, I picked the Dayton Audio Rss265hf because I've seen it show up a few times here. I then set about finding the ideal box volume to achieve a Qtc of 0.707 based on this website. I figured I'd use the equation linked there:
Vbox = Vas/((Qtc/Qts)^2 -1) and graph it to figure out the range of box volumes I can work with (Graph attached at bottom).
[Edited this section for clarity, so I don't sound like a madman]
In the end, it seems like I must to construct a box with a volume Vb = 1.28 ft^3 (which is below Vas) in order to achieve a Qtc = 0.707. Does this make sense? Can I make the enclosure smaller than Vas?
A couple other questions, that I haven't been able to find answers to:
1. Why is the range of possible volumes so small?
2. Are there any glaring flaws in my approach to this?
3. Can hornresp help me sweep all scenarios?
4. Is it all moot?
Thank you
What to aim for in an amplifier designed for controlled bass
What is it in an amplifier that makes it better to control the base?
I'm building an active three way, and currently I use LM3886, but I what my speaker to do better. I have a clear idea on how I want to do the amplifier for both midrage and tweeter, but what about the subwoofer.
I havn't measured the impedanse of the subwoofer, but it's a 4 ohm driver (SB23MFCL45-4) with two passive radiators, so I dont expect it to be easy.
I have four pairs of MJ15003/4 and I intent to use them in the amplifier. I have a choise between 2*18V/6A or 2*25V/6A trafo, but I rarely play loud.
Questions: Do I go for the bigger trafo to get more headroom?
Do I aim for lots of open loop gain and thereby lots of feedback, to get very low output impendance?
Or do I aim for the ability to (in theory) drive 1 ohm, to be shure to have current enough?
Og do I aim for low bandwith in order to make the fase margine in the "safe" aren to make it more stabile?
Do I aim for higher idle current, in order to output stage more linear?
Has anyone seen Rush pairs used this way?
Anyone seen Rush pairs used like this?
806335d1578009536-seen-rush-pairs-india_1_rush-circlotron-cct-png
It is balanced in and balance out. Could be unbalanced in (by grounding one input) or a phase splitter (one input grounded and two output each wrt common).
Unlike the normal Circlotron this one has voltage gain, effectively common source.
Like a normal Circlotron it is symmetrical so even harmonics cancel. The p-channel and n-channel differences cancel -- you don't need to use well matched complements to get low 2nd harmonic distortion.
It can be biased for Class-A or Class-AB. In Class-A it approximates square-laws so the bias current can be about half that of standard push-pull Class-A with smaller heatsinks and transformers and caps. It can be used as a no feedback amplifier with current drive output.
In Class-AB there is an optimum bias for minimum crossover distortion, it is quite high bias (since there are no source resistors) giving low distortion over the first watt. It can be used as a no feedback amplifier with current drive output. The attached plot is with 300mA bias and 25V supplies giving about 0.01% THD at 1W/8R.
The bias current for Class-A or Class-AB needs to be stabilized with Vbe 2 multipliers (or thermistors) to prevent thermal runaway.
Best wishes to all here for 2020 and beyond.
15" subwoofer box firing up, front, or back?
I have a volvo s80 2004. I am going to install a Soundqubed hdx315d1 in the trunk. I would like to have as much sound as possible, but still have it playing down to the 20s and up to the 80s-100s.
I am going to make a new trunk floor from plywood, and build a ported box from plywood with a slot port tuned to maybe 29hz?
I do have an 8" aeroport, but it is too short.
The trunk is quite small and i could barely fit a rear firing box.
Should i make it rear firing, both sub and port. Side firing port. Sealed off firing forward. Or firing up?
UART serial programmer set-up.
I bought a new 1228 110amp Curtis controller for a Mobility gopher then found I will have to program it to make it go faster, etc...? A Curtis serial programmer costs an arm and a leg to buy so I went with a UART although I have no idea on how to set it up except where to plug it in on the Curtis 4 pin Molex, Ground, Transmit and Receive plug. The fourth pin is NC. The Curtis controller module is self-powered 24v and 5v for programming, the UART has a computer style jumper for 5v/3.3v? I need to know if I take the jumper off and if I just connect the Ground, Transmit, and Receive that would be it? Or does the UART need the 3.3v to power its self? I downloaded the Datasheet to look at and uploaded some photos of the UART serial programmer.I want to avoid any mistakes if I can help it? FT232RL%20USB%20UART%20I.C.%20datasheet.pdf
Advice for TV Speakers
I've recently gotten back into woodworking and seeing so many great DIY speaker projects online/youtube and well... my small basic Sony 2.1 soundbar has worked fine for years, but I think time to upgrade.
Because of the room, I'm looking to build a 2.0 or 2.1 system. My seating is against the wall so, no space for rear speakers... also an opening on either sides, so rears if I forced them in, would be a foot from my head, and not wanting that.
Just looking for ideas/suggestions on what I would need for this build in terms of power.
I like my setup now, because TV plugs into the soundbar, and my TV remote adjusts the volume. I don't have a big receiver, lots of wires, a separate remote, etc....
Looking for something that works the same and with just as simple of a setup. Not looking to spend thousands on speakers and electronics... something a bit more entry level that's at least better than the Sony I have now. I see a lot of DIY speaker plans online... but all are just speakers, maybe crossovers as well, but nothing about power.
Any suggestions? Can it be done where the TV volume on the remote adjusts the volume? My soundbar now does it, but it's also connected via HDMI... not just a straight amp with audio jacks.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,801
Members
7,888,936
Messages
Filter
Forum Statistics
Threads
406,265
Messages
7,888,936
Members
507,801
Latest member
TMCK001
