Howdy folks. I built a set of TG's Faital 3wc 15" at the start of the year. This gave me a taste for DIY. I'm half way through building a set of micro active 2 way speakers for my son to use with his electric drum kit, and for general use (and maybe to take when we travel).
Figured i'd post it up here in case anyone has helpful comments, or wants to build something similar and my build helps.
Am using:
Wondom Jab5 (4 x 100w with DSP) - will use 1 channel per driver
SBA SB19ST 4 ohm tweeters
Dayton ND105 4 ohm 4" woofers
16mm MDF cabinets at 4.5L internal
Planning to muck around a bit with the DSP to see how low i can get them to go with a flat response.
My thinking is the amp's good for 100wpc, the drivers are 30w, so call it 60w peak. The amp's meant to be ok to 6 ohms, i'm asking it to deal with 4 ohms, but hopefully the fact that it's quite overpowered for the drivers means nothing melts.
Have cut everything, and done a basic test of the amp last night to ensure it works:
Wondom Jab5 test - YouTube
Next up bench test using the PC control module and all 4 drivers.
After that i need to mount the hardware in the cabinet. The 1 job i need to work out is how to have the plugs mounted, the 16mm MDF is too thick. I could rout it, but then it might be too thin. Do i use some hard plastic, or can i use metal - but i'm concerned about having a power plug mounted directly to metal... I'm not electrically skilled.
Few pics of the build so far:
