dfidler:Links
Celebrities
Linkwitz Labs
- http://www.linkwitzlab.com/ - Linkwitz Lab
Zaph Audio
- http://zaphaudio.com/ - Zaph Audio
- http://zaphaudio.com/ZDT3.5.html - Constructing ZDT3.5 - Project
Art Ludwig
- http://www.silcom.com/~aludwig/ - Art Ludwig's Sound Page
- http://www.silcom.com/~aludwig/Loudspeaker_construction.html - Speaker Construction - Good Coles Notes pages
Rod Elliot
- http://sound.westhost.com/index2.html - Rod Elliott's pages
- http://sound.westhost.com/bi-amp.htm - Bi Amp
- http://sound.westhost.com/bi-amp2.htm - Bi Amp 2
- http://sound.westhost.com/biamp-vs-passive.htm - Bi Amp vs Passive
- http://sound.westhost.com/sp-boxes.htm - SP Boxes
- http://sound.westhost.com/sp-boxes2.htm - SP Boxes 2
Construction Links
Bending Wood
Applying Veneer
- http://www.io.com/~patman/finish.html#veneer
- http://www.joewoodworker.com/veneering/welcome.htm - Vaccuum Veneering
- http://www.rockler.com/articles/how-to-veneer.cfm - Techniques
- http://www.exotic-veneer.co.uk/exoti...e_products.php - UK Supplier with big sheets
CNC Milling
- http://www.cncrouting.co.uk/what/int...df-frames.html - The Cutting Room - CNC Milling company in London; cool
- http://www.chromecow.com/downloads/l...shm-stl-tools/ - Lightwave STL plugin
Aluminum
- Brushing Aluminum - must be done before anodizing
- Polishing Brushed Aluminum
- How to decide between Anodizing, Painting and Powder coating
- HowTo remove clear coat from Aluminum
- Best aluminum for anodizing is billet aluminum rather than pure ALU; pure alu has many impurities which can give it an uneven finish
- UK suppliers
Kit
- Custom Heatsinks: http://www.cooliance.com/custom_heatsinks.html, http://www.chtechnology.com/heatsinks.html, http://www.aavidthermalloy.com/products/heatsinks.shtml, http://www.thomasnet.com/products/he...7340403-1.html
- Copper Sheets: http://www.metelec.co.uk/copper-sheet.php, http://www.alfun.cz/en/med.html
- high quality actives:
Quote:If you want HIGH SQ then search for DEQX used on audiogon or similar sites. You can buy it new for over $6K US - Accoustic Foam:
- http://www.acoustic-foam.co.uk/acousticfoam/
- http://www.cutfoam.co.uk/acoustic.html
- http://www.cutfoam.co.uk/galleryacoustic.html
- http://www.customaudiodesigns.co.uk/absorbers.htm
- http://www.xlprosystems.com/catalog/...005dead1ae1568
- http://www.xlprosystems.com/catalog/...roducts_id=522
- http://www.absolutemusic.co.uk/store...&productId=400
- https://www.wilmslow-audio.co.uk/cat...42&language=en
- http://cgi.ebay.co.uk/Acoustic-Foam-...e1fdd1ff58fe57
- http://www.inta-audio.com/studio-equ...n=froogle#3315
- http://www.ledametrix.com/oscope/index.html - Poor mans Oscilliscope
- http://www.picotech.com/oscilloscope...y=oscilloscope - Oscilliscopes
- http://www.picotech.com/computer-oscilloscope.html - USB OScilliscope
Sonics
- http://www.superlux.us/frequency_response.html - Why do Frequency Response Curves Matter
- http://www.physicsclassroom.com/class/sound/u11l3d.cfm - Behavior of Sound Waves
- http://www.slideshare.net/guest90e7e...1-presentation
- http://en.wikipedia.org/wiki/Acoustics - Accoustics
- http://en.wikipedia.org/wiki/Reflection_(physics) - Reflection
- http://www.ndt.net/links/proper.htm - Plastic Material Accoustic Properties
- http://polymerphysics.net/pdf/JAcous...11_1782_02.pdf - Acoustic and dynamic mechanical properties of a polyurethane rubber
Speakers
Projects
- http://www.diyaudio.com/forums/multi-way/93218-lgt-construction-diary.html-'LGT' Construction Diary
- http://www.linearteam.dk/ - Linear Team - Good free box design program (you need the T-S parameters from the speaker you want to use) Follow the help exactly to enter the parameters or it will not allow you to complete the entry.
- http://www.rjbaudio.com/ - RJB Audio - Projects
- http://www.planet10-hifi.com/boxes.html - Planet10 Box Layout Library - nice
- http://sites.google.com/site/undefinition/diy - Paul Carmody's Audio Projects - Projects (good site)
Horns
- Horns - Math intensive!
- More words, less math
- http://www.frugal-horn.com/ - Horn Designs
- http://www.mh-audio.nl/Horn/Dinsdale_Horns_1.pdf - good article
- http://www.enjoythemusic.com/magazin...re/zingali.htm - marketting stuff on how amazing horns are...
Software
- http://www.speakerworkshop.com/SW/Download.htm - Speaker Workshop - Probably the best free speaker design package but it is evil to learn how to use.
- http://www.claudionegro.com - Speaker Workshop tutorial
- http://www.pvconsultants.com/audio/frdgroup.htm - Frrequency Response Data Consortium - Collection of very usefull simulation tools mostly in Excell. Th Baffle Step compenation program is really good for demonstrating how just moving a drive unit a few cm in a cabinet can significantly affect the frequency response.
- http://www.angelfire.com/electronic/...rworkshop.html - Tutorial - one of several tutorial on how to use it (search the web for others)
- http://www.holmacoustics.com/holmimpulse.php - HOLM Accoustics - Probably the best free measurement software and fairly easy to use. You will need a microphone and a half decent sound card but that is all.
Analysis
- Measuring Loudspeakers, Part One - very technical
Books
- http://www.amazon.com/Sound-Reproduc...0935423&sr=1-1 - Floyd Toole's book on Sound Reproduction - recommended read; not cheap
Uncategorized
- http://www.lenardaudio.com/education/01_eduintro.html - Lenard Audio Institute
- http://lenardaudio.com/sarabande_standard.html
- http://www.johncon.com/john/wm61a/ - John Conover: Using the Panasonic WM61A as a Measurement Microphone - How to build a really cheap but flatish response microphone for only a few £ or $. If you only take one peice of advice from me it would be don't try to build speakers without a microphone. It would be like setting sail without even a compass, you can use the sun but its not really that much help unless you have years of experience, your ears are much the same.
- http://www.humblehomemadehifi.com/ - Humble Homemade HiFi - Projects
- http://www.troelsgravesen.dk/ - Troels Gravesen Audio - Projects and Theory
- http://www.gedlee.com/Loudspeakers.htm - Geddes - ?
- http://www.musicanddesign.com/HybridDesign.html - Hybrid Design - design philosophy principle for the mid/treble of a 3 way or subs/sats.
- http://www.audiokarma.org/forums/sho...ight=econowave - Audio Karma waveguide speakers - ick
- http://www.t-linespeakers.org/ - Transmission Line speakers
- http://www.claudionegro.com - Speaker measurements, Double chamber reflex, DAC, Speaker vibrations.
This page has been seen 2,944 times.
Created by onLast updated by on
