Appendix- Krell-O-Tracker
Appendix - Krell-O-Tracker
This is to keep track of variations on this project, and give others guidance on what was used. If you have one in-progress, feel free to enter the info on the parts you are using or plan on using. Feel free to enter notes, links, pics, comments and such in the last col.
Date Finished or IP | Name | Transformer | Total uF Per Ch. | DC Rails | Emitter Resistors | Output Devices & # Per Ch. | Notes, Links, Pics, Comments |
1981-87 | Original | 400VA x 2 | 80,000 uF | 37.5 VDC | 0.5 Ohms | MJ15003/4 (2 each) TO-3 | 50 WPC Class A |
1. | Mark G.#1 | 680VA X 2 | 112,000 uf | 39.0 VDC | 0.68 ohms | MJL 21193/4 (3 each)TO- 247 | 54 WPC Class A - Amp has been scrapped out to build permanent version. |
2. | Assesears | 500VA x 2 | 90,000uf | 33.0VDC | 0.68ohms | MJL4281A/4302A(3 each)TO-247 | 36WPC ClassA? (small heatsink) |
3. | Stuart Easson | 2.8kVA x 2 | 2x25000 | 105VDC | 0.68ohms | MJ21193/4(16 each)TO3 | 50W/Class A ; 500W/Class B |
4. | Stuart Easson | 450VA x 2 | CLC 68k/2.7m/68k | 37v DC | 0.68ohms | MJ15003/4(2 each)TO3 | 50W/Class A , 75wClass B |
5. July 31, 2005 | still4given | 500vA X 1 | CRCRC 45,000 | 42 VDC | 0.68 ohms | MJ15003/4 (3 each) TO-3 | (don't know) [Pictures] |
6. August 8, 2005 | LGreen | 700VA x 2 | 128,000 uF | 37 VDC | 0.499 ohms | MJ21193/4 (4 each) TO-3 | Notes- low/high bias option switches from 20 WPC Class A to 50 , WPC Class A at 8 ohms, fan cooled; 70 lbs/ 32Kg. Discussion and Pics- (a) [Post #3609] (b) [Personal Web Page] |
7. in progress | Mark G. #2 | --- | 112000 mfd | --- | 0.68 ohms | MJL 21193/4 (3 each) | Proto test of WIKI boards |
8. | NUTTTR | 800VAx3 | 272,000uf/ch | 38v DC | 0.68ohm | MJ21193/4 (5 pairs/ch) | Not yet... |
9. March 2006 | JoeyDD? | 500VA x 2 | 80000uF/ch | 36VDC | 0.68ohm | MJL21193/4 (3 pairs/ch) | 2 monoblocks, passive cooling, [Pictures] |
10. | jacco vermeulen | 300VAx8 | CLC,78000uFx6,2.5mHx2 aircoils/ch | 35VDC | 0.68Ohms | 2SA1216/2SC2922(12/ch) | 4 discrete voltage regulators for main and driver board with 9VAC/27VA step-up toroidals/ch,80x80mm Papst fansx6/ch,7 amps bias? |
11. November 26, 2005 | LuckyLyndy | 500VA X 2 | 112,000 Per Chan. | +/- 40 F. | 0.68 | 6 Ea MJL21193/4 Chan. | DC Variable Speed 15 vdc Fans Running at 6.5 V. |
12. November 28, 2005 | Luke | 25V@7.5A | CRC 96,000uF | 36 VDC | 0.4 ohms | MJL4281, MJL4302 (3 each) TO-3 | (don't know) |
13. A week or so left | KMJ | 2x540VA | 132k uF / Ch | 38VDC | F. Re | MJ15003/4 (3 each) TO-3 | Fancontrolled cooling and monitoring done |
14. February 27,2006 | Mark A. Gulbrandsen | 2 kva dual secondaries | 56,000 per rail | +/- 38 volts | ? | MJ21193/94 3 each TO-3 | Dual fans at half speed. Final version for me |
15. In-Progress | Googler | 2KVA Bel Canto Dual Pri/Sec | searching | +/- 40VDC | ? | 6 x MJL21193/4 per ch | Heatsinks are 12Lx5Wx5H w/ 14 ribbed fins. Boards Stuffed!! Need PSU CAPS |
16. In progress | niles | 2x500VA | 56,000 per rail | ~41V DC | 0.68R | 3 Ea MJ21195/6 per Ch.. | Building matched pair as bridged monoblocks using authentic Pass A2 sinks with custom machined chassis fittings |
17. Collecting parts | bikehorn | 1x 1250 VA xformer with 2x 39-0-39 sec'ys | ESP capacitance multiplier | 39 VDC | 0.5 ohm | MJL21193/4 TO-3P, 5 pairs/ch | will include VU meters |
18. June 27, 2006 | zlast | 2KVA 28X2 | 120000 uf | Rail +/-40 V | 0.47 ohm | 3 pair MJL21193/94 per ch | 4 channels/ redesigned boards so outputs transistor on board /50WPC Class A. [Pics/ Post #6747] |
19. July 3, 2006 | Farl | 1X500 VA | 66,000 uf per rail | +/-41V | 0.68R | 3 pairs MJL21193/94 | Maybe 50W Class A [Pics/ Post# 6774] |
20. in progress | Andrew T. | 30+30Vac | 750VA | 60mF per rail | +- 42Vdc Re=0r333 | 6pr 2sa1943/c5200 passive cooling 3off 8"*8"*2" sinks/ch | 100W ClassA? into 6r, Iq=3A, twin drivers 2sb649/d669, +- 42Vreg frontend |
21. In progress | Harry3 | Two 500VA 25+25Vac | 56000uF per rail plus 1000uF & 0.1uF caps next to O/P transistors | +- 35Vdc | 0R5 | 6pr 2SA1943/2SC5200 | 2x80VA trans. for front end-will regulate. Two Semikron heatsinks 300x200mm - 80mm fins plus 2 fans |
22. In Progress | Harry3 | Two 500VA? 30+30Vac | 60000uf per rail plus 1000uF & 0.1uF caps next to O/P transistors | +- 42Vdc | 0R68 | 6pr 2SA1943/2SC5200 | Two 12Volt fans running at 7 Volts, very low noise. |
23. May 15, 2021 | XaQ | 1.2KVA 29-0-29x2 | 130000 uf/rail | +/-40 V unloaded | 0.68R | 3 pair mjl21193/4 | 2 stereo amps 4 passive heatsinks 15.5"L 5.5"W 6"H 46 fins ea. [Pics/ Post# 9284] |
24. September 17. 2007 | Steenoe | 2 pcs 500VA 26x2 | 90.000uF per ch | E. 35V | 0,68r 6W | MJW1302A/MJW3281A 3 pairs per channel | Passive cooling, weight 42 Kg |
25. Jan 01 2008 / IP | B. Jack Richards | C. 2 X 500VA | D. 44000uF/chan/rail | E. 38 V | F. Re=0.5 | G. # 4xMJ21194 | H. Bought fake trans from ebay (HonestCard?) ended up buying from OnSemi?. Now sounds fantastic |
26. February, 2008 | john65b | 1240VA | 2 x 56,000uf/rail uF | 37 VDC | Re R68 biased @ .65mv | 3pr 2SA1943/2SC5200 | Sounds EXCELLENT. Bests my UCD400 by quite a bit |
27. December 22. 2008 | neychi | 2 x 400VA | 2 x 47000uF per ch | 38 VDC | Re 0.5R | 3 pairs MJL21193/21194 | Passive cooling, 55W class A |
This page has been seen 3,707 times.
Created by onLast updated by on
