diyAudio logo
Parts selction
This WIKI is for those who have suggestions on recommended parts for Pedja Rogic's TDA1541A DAC.
The main thread is here: https://www.diyaudio.com/forums/showthread.php?s=&threadid=29604&perpage=40&pagenumber=1
If you have any favourite brands that you wish to share, please edit the original parts list below. Hopefully this will take some of the guesswork out of part selection for the less experienced builders out there.
Cheers
jonclancy
PS - Sorry about the spolling mistak! ¦;0)
Assuming this page is for US suppliers I've put some information together for UK/EU suppliers here PedjaDACeu
Semiconductors
#designationvalueRecommended PartSupplierCode
1IC1, IC2, IC4LM317xxx
2IC37805xxx
3IC5LM337xxx
4IC67824xDigikeyMC7824BTOS-ND
5IC7TL431TL431CLPRDigikey296-1290-1-ND
6IC87818xDigikeyMC7818CTOS-ND
7IC97918xDigikey497-1479-5-ND
8IC10, IC127812xDigikey296-13998-5-ND
9IC11, IC137912xDigikeyMC7912ACTOS-ND
10IC101CS8412-CPxxx
10aIC101CS8414-CSxNewark35C5741
10bIC101SOIC Dip AdapterxDigikeyA320-ND
11IC102TDA1541Axxx
12IC103, IC104AD844ANxDigikeyAD844AN-ND
13T1BC557xxx
13altT1BC5572n5087Digikey2N5087RLRAOSCT-ND
14J1, J22SK170BLToshibaMCM2SK170
15D1 - D24BAT49xxx
15altD1 - D24BAT49IR 11DQ10Digikey11DQ10-ND
16LED1red LEDxxx
17LED2green LEDxxx
Resistors
#designationvaluepartRecommended PartSupplierCode
1R1, R3, R8, R10360Rmetal film 0.25Wxxx
2R2, R4, R9, R11120Rmetal film 0.25Wxxx
3R5, R135k1metal film 0.25Wxxx
4R6, R7, R14, R103, R1071kmetal film 0.25Wxxx
5R12220R/0.5Wmetal film 0.5Wxxx
6R10175Rmetal film 0.25Wxxx
7R1021k (see text)see textxxx
8R104, R1081k5see textCaddockMichael PercyTF020
9R105, R10975Rnot needed if opt. discrete output buffer is usedxxx
10R106, R110220kmetal film 0.25Wxxx
11VR1, VR2500R (see text)multiturn pot like BI 67xDigikey3266W-501-ND
Capacitors
1C1, C4, C8, C121000uF/16VelectrolyticxDigikeyP10253-ND
2C2, C5, C9, C13470nFceramic multilayerxDigikey399-2100-ND
3 C3, C6, C10, C1447uF6.3VBlack Gate NX Hi-Q or OS-Con SP,SGxMichael Percyx
4C747uF/16VelectrolyticxDigikeyP11196-ND
5C11, C15100nFceramic multilayerxDigikey399-2054-ND
6C162200uF/50VelectrolyticxDigikeyP10335-ND
7C17100uF/35Velectrolyticxxx
8C18, C1947uF/16VBlack Gate Std (OS-Con SP, SG)xMichael Percyx
9C20100nFMKPxxx
10C21, C223300uF/35VelectrolyticxDigikeyP10311-ND
11C23, C24100u/25VelectrolyticxDigikeyP10269-ND
12C25 - C30100uF/16VBlack Gate StdxMichael Percyx
13C101, C10210nF/400VWIMA MKP10 400Vxxx
14C10347nF(see text)MKPxxx
15C1043.3nFWIMA FKP2 (or FKM2)xxx
16C105 - C110, C113 - C118100nFWIMA MKP10 250Vxxx
17C111, C1122.2uFWIMA MKS4 63Vxxx
18C119470pFKP (or MKP or mica or styrene)xxx
19C120, C1231n8Fstyrenexxx
20C121, C1241nFmica (or styrene or MKP or MKC)xxx
21C122, C1254u7F/50VBlack Gate NxMichael Percyx
Optional discrete buffer
1IC14, IC1678L12xxxx
2IC15, IC1779L12xxxx
3R111, R1151ksee textxxx
4R112, R11622metal film 0.25Wxxx
5R113, R1171kmetal film 0.25Wxxx
6R114, R11875see textxxx
7C31 - C34100uF/16VBlack Gate Stdxxx
8J101 - J1042SK170BLxxxx
Other optional components
#designation/valuecommentRecommended PartSupplierCode
1CO1, CO2 (100pF- a few nF)low pass output capsxxx
2TR101 (Scientific Conversion SC944-05), R101' (300R)SC916-01 can be used with R101'=75RxScientific ConversionSC944-05
3D25, D26 (BAT42/43/48/49)safety diodes for CS8412xxx
4RO1, RO2, RO3 (22R-1k)I2S line low passing resistorsxxx
52 row, 8 or 10 pin, 2.5mm header and jumpersconnector on the I2S linexxx
Reclocker Components
#designationvaluecommentRecommended PartSupplierCode
1IC1,IC2LM317 x x x x
2XOC3291Crystek Crystals CMOS Clock 50Mhz SMD crystal oscillator x x x
3IC101-IC10374xx74LS or F dual D flip-flops * x x x
4optional buffer inverter x may be used to route the clock back to the transport making it the master clock x x x
5D1-D4BAT42 x x x x
6C11000uF/16Vx x x x
7C2,C40.47uFmultilayer ceramic The best are NPO.Then comes XR7 and Z5U x x x
8C3,C5,C6,C747uF68uF/6.3V OS-CON SP (or 47uF/6.3V OS-CON SG) x x x
9R10175R x x x x
10R1,R3360R x x x x
11R2,R4120Rthis value may be tuned or swapped by inductors x x x
12R5,R6,R710R x x x x
