Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 15th August 2010, 11:38 PM   #101
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally Posted by needsp View Post
Hi Russ
One other thing I don't understand. Your reply implies that Legato sounds better at 15V. If R20 etc is adequately rated as you say, why not recommend 15V operation in the manual, rather than 12V?
Paul
The manual is clear why. There is no other reason than heat. If your case is adequately ventilated use 15V. I don't assume all people have adequately ventilated cases.
The manual does assume people will maybe use the buffer, which adds even more heat. So I decided to guide people toward moderation.
I am running and have always run 15V with no issues for more than a year. My legato is performing as well as ever.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 16th August 2010, 03:21 AM   #102
ylingf is offline ylingf  United States
Hi Russ,
I need a SE output, but really don't like to have an opamp in the path for balanced to SE conversion. Since I know my preamp's input impedance is 10K. Is it possible to load the negative output of the balanced output with a 10K resistor, and connect the positive output to the preamp?
Thanks,
Fred
Old 16th August 2010, 10:47 AM   #103
Russ White's Avatar
Hi Fred, It is possible to do, but you likely to get some nasty turn on and turn off thump unless you employ some sort relay or something.
You would be better off just forgetting the opamp is there and enjoy the good music.
You could also use a transformer or some other external BAL/SE conversion.
Old 16th August 2010, 03:07 PM   #104
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
I knew the opamp would cause some comments (as did you no doubt ) its not an issue for me, as i'm running BAL, but I did wonder a bit about the choice TBH. people buying legato are most often doing so in order to use a no global FB discrete circuit; seems a bit counterproductive (regardless of sound) to ruin that in the last stage with an opamp for SE conversion
Old 16th August 2010, 03:23 PM   #105
Russ White's Avatar
I don't see it that way at all. Here is why. There are two distinct processes involved here.
First we have a symmetrical I/V converter. It is fully discrete with no global NFB. It stands on its own.
Then we have an orthogonal but practical and extremely useful bal/se stage which you the builder can decide to use or not. It is completely optional. The DAC is a balanced DAC, not SE. This I/V stage is a balanced I/V stage.
All of that to say to do BAL/SE with discrete components right would take more space than I had on this PCB, and would not have yielded as good results as what is there right now.
Instead, I took the pragmatic approach and offered the builder options. Use the excellent on-board BAL/SE stage, or do something else with the balanced signal.
One great option would be the Ventus which is a discrete BAl/SE converter. But it is far too large and makes too much heat to put on something like the Legato PCB.
So I think the choice was the most logical I could make given the goals regarding form factor etc.
Cheers!
Russ
Old 16th August 2010, 08:25 PM   #106
NicMac is offline NicMac  Italy
NicMac's Avatar
Originally Posted by Russ White View Post
One excellent option would be the Ventus which is a discrete BAl/SE converter. But it is far too large and makes too much heat to put on something like the Legato PCB.
Hi Russ,
Would the Ventus used as a BAL/SE converter work better with or without the buffer stage on the Legato? Would the connection need decoupling caps? Can the output DC offset of the Ventus be set (very) close to zero?
I'm considering to use of the Ventus with a dual-mono BII/Legato connected to (balanced) Hypex modules with by-passed buffer stage (input impedance 1k8R, not very tolerant to DC offset).
Last but not least - will the Ventus be re-stocked?
Thanks,
Nic
Old 16th August 2010, 08:41 PM   #107
BrianDonegan's Avatar
Either would be fine, without would be cooler and easier to power.
No.
Yes.
It is getting a little tweaking attention, but will be available again very soon.
Twisted Pear Audio
Old 16th August 2010, 08:44 PM   #108
NicMac's Avatar
It sounds absolutely superb! Stunningly good! Unbelievably good! I don't say this lightly- it sounds better than the I/V stage I was using (which used a CFT, with a CCS above and below), and I've recently invested a lot of time and effort in that. Believe me it was no slouch sound-wise either- Legato had to be damn good to get my attention!
Hi Paul,
What are you using for BAL/SE conversion? I seem to recall that you are using a single ended power amp.
Nic
Old 16th August 2010, 08:59 PM   #109
NicMac's Avatar
Thanks Brian,
I will try this combination when the Ventus becomes available again.
I'm doing my best to understand why so many people hate op-amps
I seem to understand that the Ventus as added value can give me back a bit of the gain that I lost by bypassing the gain stage on the Hypex modules.
Nic
Old 16th August 2010, 09:45 PM   #110
needsp is offline needsp  United Kingdom
Hi Paul,
Nic
Hi Nic
Just the op amp stage provided
Paul
Buffalo DAC+IVY+OPUS+Dual PS for sale huskydawg9 Swap Meet 13 6th February 2010 02:33 AM
Buffalo DAC, IVY, LCBPS pdrie Swap Meet 2 24th July 2009 03:44 PM
Twisted Pear Buffalo/IVY/LCBPS/LCDPS Hacker Swap Meet 6 26th February 2009 04:57 PM
FS: TwistedPair Buffalo DAC+IVY+LCBPS VT67 Swap Meet 3 23rd February 2009 10:38 PM
Twisted Pear Buffalo Dac and Ivy modules - built - for sale phrarod Swap Meet 3 17th January 2009 02:25 AM
Copyright ©1999-2013 diyAudio
