Old 26th January 2013, 03:16 AM   #4641
mhouston's Avatar
Oatley Electronics of Australia is about to release the K272B HP kit based on the JAN6418 tube. I got an early prototype and assembled it. Harmonically rich sounding and better than a CMoy (I think).
Old 26th January 2013, 10:33 AM   #4642
diyAudio Moderator Emeritus
Bas Horneman's Avatar
This is the Mono Amplifier that I built for my friend Brian Kim. This is the very first SE amp of Hi Fi tube amp of his collection. It employs Lundahl's LL1623AM amorphous core output transformer, and LL1638 double choke filtering for the B+. Driver is with 7N7 tube and each stage with separate RC B+ filtering.
Awesome looks like a lot of premium parts in that one . How to you use the 7n7? 2 gain stages? or gain stage and cathode follower?
Old 26th January 2013, 12:42 PM   #4643
my new preamplifier, still on construction but nearly finished:
Old 26th January 2013, 03:07 PM   #4644
wlowes is offline wlowes  Canada
wlowes's Avatar
Smile 6C33C OTL
I am thrilled to finally post my first tube amp project. Thanks to all who have gone before me to offer insight and inspiration. Based on Bruce Rozenblit's patent (published in Audio Reality). 120w per channel. Sound is transparent, light and effortless with tons of deep bass. I am very happy with the result.
File Type: jpg tube amp finished - close up tube glow.jpg (290.8 KB, 314 views)
File Type: jpg tube amp finished - input and drivers.jpg (252.4 KB, 313 views)
Old 26th January 2013, 06:00 PM   #4645
Stixx is offline Stixx  Germany
Stixx's Avatar
My C3G spud headphone amplifier is finally finished and playing music.
- C3G triode wired running at 145V / 15mA
- Cathode bias with tightly matched Morganite resistors and BG N bypass caps
- (yes, there is still people preferring a conventional setup over LED bias , but only when Black Gates are used)
- Salas SSHV2 with LC prefilter
- DC heaters
- Lundahl LL1689 wired 18:1
- custom wound toroid mounted on top
- all the guts underneath
Absolutely dead silent (Pitch Black background... ).
Old 26th January 2013, 06:03 PM   #4646
buzzforb's Avatar
Now that is gorgeous. Who cares how it sounds
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 26th January 2013, 06:09 PM   #4647
Stixx's Avatar
I do . Didn't have it on the breadboard for almost 2 years for nothing...
Old 26th January 2013, 06:16 PM   #4648
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Beautiful aesthetics. Are you an artistic or industrial designer of some sort?
Old 26th January 2013, 06:21 PM   #4649
6L6 is offline 6L6  United States
6L6's Avatar
Stixx -
Your amp is fantastically beautiful! A sincere congratulations on constructing such a beautiful Headphone Amplifier.
If we had a 'hall of fame' for gorgeous builds, you would be instantly included!
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 26th January 2013, 06:32 PM   #4650
Stixx's Avatar
Err, yes
As a daily job I am... hmm... look for yourself -->
Mercedes-Benz Arocs 2013 Gadgetfreak
(coincidentally found this in greek )
A sincere congratulations on constructing...
Thanks 6L6!!
Copyright ©1999-2013 diyAudio
