What is the Best Rectifier to 6C33 SE?
I would like some answers if possible:
How many hours a 5C8S will lasts feeding one 6SL7 and one 6C33?
Power output expected is 12/13W.
Originally Posted by Celsius View Post
I have two amp 6c33 SET one with tube rectifier and other with SS rectifier to me the best rectifier is :
CREE CSD01060 Silicon Carbide Schottky Diode, cheap and great :)
You have a interesting comparinson set.
Do you mean say CREE its best sound over the tube rect?
What is your tube rect??
I would use fixed bias to reduce the heat under the chassis and give more flexibility.
I agree that the Cree diodes sound much better than any tube rectifier I've ever heard, but for what you're doing, I would use the 3A version.
Thanks for your useful tip:)
Fixed Bias is the same AutoBias?
Any opinion about the Fairchild 8A 1200V?
Thanks for help
