Old 28th July 2012, 10:09 PM   #1
merlin el mago's Avatar
Default 6SN7 6N8S preamp suggestions
6SN7 6N8S schematic preamp suggestions
I'm looking for high gain, high input impedance, low output impedance, low noise design with only 2 tubes so one per channel.
Ideas and suggestions will welcome.
Old 28th July 2012, 10:14 PM   #2
denny9167's Avatar
I've had good experiences with the SRPP,I haven't tried the other configurations. Just be sure to elevate your heaters. Thanks
Denny
Old 28th July 2012, 10:18 PM   #3
Thanks Denny, could you post your schematic used and let me know: gain, input/output impedance, etc?
Old 28th July 2012, 10:28 PM   #4
denny9167's Avatar
Sure, I have the pic attached. Since the 12AU7 and 6SN7 are so close I made the substitution. The sound is really quite nice. Since the 6SN7 is an 8-pin octal you will have to change pin-out arrangment. I don't remember the gain, but it should be sufficent for what your looking for.
BTW, this schematic is designed to give you elevation on those heaters! Thanks
Old 28th July 2012, 10:34 PM   #5
Looks nice and very easy to do, surely I will try, thank you.
Old 28th July 2012, 11:55 PM   #6
tinitus is offline tinitus  Europe
been thinking if srpp would be good or maybe even ideal to drive a low impedance trafo output
which could be balanced 600/600 ohm
Old 29th July 2012, 09:57 AM   #7
I don't want to use output transformer.
Old 29th July 2012, 10:15 PM   #8
ruffrecords's Avatar
Use a mu follower. More gain, much less distortion than and SRPP and still the low output Z. Run the 6SN7 at around 5mA.
Cheers
Ian
Ian
Old 29th July 2012, 11:12 PM   #9
Davec113's Avatar
Cheers
Ian
I would agree, I had a mu follower pre using 6DJ8s and it had 28 dB gain very little distortion.
Old 30th July 2012, 03:06 AM   #10
Cheers
Ian
Put a CCS on the plate of the voltage amplifier, bias it with LEDs, direct couple the two halves, and a put CCS on the mu follower. You will have a nice preamp.
6N8S (6SN7) tubes with metal base, hole plates. MELZ Crown8219 Swap Meet 7 31st March 2013 04:58 AM
6N8S / 6SN7 Metal Base for Sale Komsomolec Swap Meet 2 18th February 2012 07:48 AM
6SN7 SRPP preamp BadassBob Tubes / Valves 9 28th September 2010 10:47 PM
Help with 6SN7 preamp tubedude63 Tubes / Valves 7 9th October 2006 12:31 AM
6N6P and 6SN7 Operating point suggestions dsavitsk Tubes / Valves 2 17th September 2006 12:50 AM
Copyright ©1999-2013 diyAudio
